#1 2020-12-10 13:48:17
slashmais
beowulf repositry update problem [SOLVED]
The following happens:
sudo apt --fix-broken install
Building dependency tree
Correcting dependencies... Done
  fonts-freefont-ttf libaribb24-0 libbasicusageenvironment1 libcddb2 libdouble-conversion1
  libdvbpsi10 libebml4v5 libgles2 libgroupsock8 libixml10 liblivemedia64 liblua5.2-0 libmad0
  libmatroska6v5 libpcre2-16-0 libplacebo7 libprotobuf-lite17 libqt5core5a libqt5dbus5 libqt5gui5
  libqt5network5 libqt5svg5 libqt5widgets5 libqt5x11extras5 libresid-builder0c2a libsdl-image1.2
  libsidplay2 libspatialaudio0 libupnp13 libusageenvironment3 libva-wayland2 libxcb-icccm4
  libxcb-image0 libxcb-keysyms1 libxcb-randr0 libxcb-render-util0 libxcb-xinerama0 libxcb-xkb1
  libxcb-xv0 libxkbcommon-x11-0 qt5-gtk-platformtheme qttranslations5-l10n
  linux-libc-dev
  linux-libc-dev
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 1,353 kB of archives.
After this operation, 5,262 kB of additional disk space will be used.
Err:1 http://deb.devuan.org/merged beowulf/main amd64 linux-libc-dev amd64 4.19.118-2
  404  Not Found [IP: 131.188.12.211 80]
E: Failed to fetch http://deb.devuan.org/merged/pool/DEBIAN/main/l/linux/linux-libc-dev_4.19.118-2_amd64.deb  404  Not Found [IP: 131.188.12.211 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
and the man-page is no help
I did
    'apt-get install devuan-keyring'
and is told already latest
what do I need to do to fix this?
thx
My sources.list:
deb http://deb.devuan.org/merged/ beowulf main
deb-src http://deb.devuan.org/merged/ beowulf main
deb http://deb.devuan.org/merged/ beowulf-updates main
deb-src http://deb.devuan.org/merged/ beowulf-updates main
deb http://deb.devuan.org/merged/ beowulf-security main
deb-src http://deb.devuan.org/merged/ beowulf-security main
#2 2020-12-10 14:06:29
dice
Re: beowulf repositry update problem [SOLVED]
Possible mirror outage during update.
Wait awhile and do what apt says. Use apt-get. This happened to me when i upgraded from beowulf to chimaera.
#3 2020-12-10 14:18:13
slashmais
@dice:
now getting:
 libc6-dev : Depends: linux-libc-dev but it is not installed
tried installing the packages and still get the error
#4 2020-12-10 14:20:43
4.19.118-2
That version is no longer in the repo. Run apt update to update your package cache and try again. You should see linux-libc-dev_4.19.160-2
#5 2020-12-10 14:22:21
dice
what fsmithred said. Its just a matter of getting the update to work properly i think?
#6 2020-12-10 14:26:30
slashmais
@fsmithred:
THANKYOU!
that worked, got a bunch of  [y/N]'s to accept the changed repos
and is now updating properly
