#1 2020-12-06 02:17:53
Obmenu-generator problem
Continuing with my 1000HE Beowulf install ...
Trying to set up Openbox to my liking.
I read about it so off I went to https://miyolinux.weebly.com/obmenu-generator.html and followed the instructions for setting up the obmenu-generator.
But I cannot get it to work.
I get these errors:
groucho@eee-dev3:~$ obmenu-generator -p -i
mkdir /home/groucho/.config/obmenu-generator/icons: Permission denied at /usr/bin/obmenu-generator line 208.
groucho@eee-dev3:~$
if ($with_icons and not -d $icons_dir) {
    remove_database($cache_db);
    require File::Path;
    File::Path::make_path($icons_dir)   <-------------------------------- line 208 (according to jed)
      or warn "$0: can't create icon path `$icons_dir': $!\n";
groucho@eee-dev3:~$ obmenu-generator -s -c
Can't open file '/home/groucho/.config/obmenu-generator/config.pl' for write: Permission denied at /usr/bin/obmenu-generator line 265.
groucho@eee-dev3:~$
sub dump_configuration {
    require Data::Dump;
    open my $config_fh, '>', $config_file        <--------------------- line 265 (according to jed)
      or die "Can't open file '${config_file}' for write: $!";
    my $dumped_config = q{our $CONFIG = } . Data::Dump::dump(\%CONFIG) . "\n";
    $dumped_config =~ s/\Q$home_dir\E/\$ENV{HOME}/g if ($home_dir eq $ENV{HOME});
    print $config_fh $config_documentation, $dumped_config;
    close $config_fh;
No idea as how to deal with this.
Anyone used it?
Thanks in advance,
#2 2020-12-06 03:11:38
Re: Obmenu-generator problem
Hi, What are the permissions for the location "/home/groucho/.config/obmenu-generator"?
maybe the installer has left the permission to write as root or admin only.
if so, you could try as root to make the location available to write by the user groucho with
chown -hR groucho:groucho /home/groucho/.config/obmenu-generator
and
chmod -R 755 /home/groucho/.config/obmenu-generator
Then try again.
I hope this helps. :-)
#3 2020-12-06 10:13:24
GlennW wrote:
... permissions for the location "/home/groucho/.config/obmenu-generator"?
Hmmm ...
The wrong ones.
groucho@eee-dev3:~$ ls -l /home/groucho/.config/obmenu-generator
total 8
-rw-r--r-- 1 root root 4986 Dec  5 21:30 schema.pl
total 328
drwxr-xr-x 2 root    root      4096 Dec  5 21:30 obmenu-generator
groucho@eee-dev3:~$
GlennW wrote:
... installer has left the permission to write as root or admin only.
It seems so.
I did follow the instructions, specifically where it said not to use root.
Evidently I did something wrong.
GlennW wrote:
... make the location available to write by the user ...
and
That was it.
:: A dynamic menu has been successfully generated!
groucho@eee-dev3:~$
GlennW wrote:
I hope this helps.
It did.  8^D
Thanks a lot for your input.
Cheers,
#4 2020-12-06 10:25:56
Check the installation instructions on trizen's github site: https://github.com/trizen/obmenu-genera … INSTALL.md
That has a link to my Debian packages for obmenu-generator, which include a package for the DesktopEntry perl modules (if you add the repository then these will be installed as a dependency of the obmenu-generator package).
If you decide to use my packages then you should try to remove the perl modules that were installed by the cpanm commands listed in Miyo's guide:
# cpanm uninstall Linux::DesktopFiles Data::Dump File::DesktopEntry
If you decide not to use my packages then you should still remove the Linux::DesktopFiles & Data::Dump perl modules because installing them with cpanm means that they will not be updated if any vulnerabilities are found in them.
The Devuan repsositories already have packages for those modules and they will be updated if any vulnerabilities arise:
# apt install libfile-desktopentry-perl libdata-dump-perl
Although in my tests the libfile-desktopentry-perl package isn't actually needed to generate the menus.
HTH
EDIT: libfile-desktopentry-perl is an optional dependency to provide locale support, I'll add it to my package as a Recommends.
EDIT2: package updated, the current version is now 0.89-2.
#5 2020-12-06 13:09:53
dice
sort of off topic my post here but might be worth it.
I was on reddit unixporn a few days ago and their is this person creating an openbox menu in python3. Worth a look atleast if you are using openbox. Doesn't have all the functionality of obmenu-generator but i like where it is heading only using python libraries.
https://github.com/jruss06/boxmenu
https://www.reddit.com/r/unixporn/comme … generator/
#6 2020-12-06 16:27:49
Check the installation instructions ...
... link to my Debian packages ...
... decide to use my packages ...
Done.
I was having a hard time with the other install.
Took a while to week everything out.
But finally managed to get it done.
... try to remove the perl modules ...
It only worked with
# cpanm --uninstall Linux::DesktopFiles Data::Dump File::DesktopEntry
HTH
Yes ...
Much easier/straightforward to install.
But I think it may have a problem (?).
It would not pick up xfe, starting Firefox instead.
Again, after a while I managed to get a hold on editing schema.pl and fixed it.
Now I have a problem with a couple of Openbox entries I use frequently.
In my previous non-configurator menu, I had entries for reboot and shutdown.
execute --> lxterminal sudo -e shutdown -r now and execute --> lxterminal sudo -e shutdown -r now.
These still work perfectly well from the command line ie: sudo -e shutdown -r/h now but using the stanza in schema.pl won't work.
What am I missing?
dice wrote:
sort of off topic ...
Nah !
dice wrote:
Doesn't have all the functionality of obmenu-generator ...
Let me see if I can get my head around this one first.  8^7
Thanks for the heads up.
Thanks in advance,
#7 2020-12-06 17:25:00
You should show us exactly what you are adding to ~/.config/obmenu-generator/schema.pl.
This works for me:
{item => ['sudo shutdown -r now', 'Reboot']},
That entry doesn't have an icon but one can be added with a third item between the square brackets.
FWIW I prefer to use obsession to exit the openbox session.
#8 2020-12-06 18:33:23
You should show us exactly what you are adding ...
Right ...
It is the same stanza I used with the previous OB setup.
## This uses the 'oblogout' menu
{item => ['lxterminal sudo -e shutdown -r now', 'Reboot', 'applications-system']},
and
{item => ['lxterminal sudo -e shutdown -h now', 'Shutdown', 'applications-system']},
This works ...
... doesn't have an icon ...
Indeed ...
Works as intended.
I used one of the other available icons.
BTW: only those icons are available? ie: the ones with the UUID type names?
... prefer to use obsession to exit the openbox session.
I'm used to ctrl+alt+backspace, fast enough.
Thanks for your input.
Cheers,
#9 2020-12-06 19:13:39
and
I think you must be mistaken — the -e switch for sudo invokes it as an editor for the file named afterwards, check ~/.xsession-errors to confirm this. I think you meant to use
{item => ['lxterminal -e sudo shutdown -h now', 'Shutdown', 'applications-system']},
But you don't need to open a terminal emulator to run the command wink
Not sure, sorry. I would investigate but the snooker's on TV big_smile
#10 2020-12-06 21:35:44
... must be mistaken ...
Quite so.  8^/
Was without my coffee ...
Not sure, sorry. I would investigate ...
I'll have a look and see.
Snooker is a priority.  8^D
Thanks a lot for your help.
Cheers,
#11 2020-12-07 15:10:41
MiyoLinux
Not sure what the problem could be. The instructions on the MiyoLinux website always works for me...on Ascii, Beowulf, and Ceres.  ???
If HoaS's package works for you then, by all means use it. smile
Did you install the depends according to the "Debian-based" instructions on the website?
For Debian-based systems...
apt install make git cpanminus libgtk2-perl
You may now need to install libtgtk3-perl too. wink  I need to update the site.
I'm lazy and just open the file manager, go to ~/.config/ and create the obmenu-generator folder as myself...the regular user. wink Did you mistakenly create it as root instead?
What am I missing?
elogind commands...
Shutdown = loginctl poweroff
Reboot = loginctl reboot
#12 2020-12-07 18:58:02
Helllo:
... depends according to the "Debian-based" instructions ...
And added libtgtk3-perl just in case.  8^)
I don't think so ...
But given the results, I've been thinking it that I may have.
What am I missing?
MiyoLinux wrote:
elogind commands...
I'll have a look and see how I do with those.
Cheers,
