#1 2020-11-28 19:21:22
Eaglet
I solve issue with jitterentropy-rngd package
Hello, comrades!
I solve issue with use jitterentropy-rngd package after installation. Developers, Please add this code to script /etc/init.d/jitterentropy-rngd for solve current issue with this service:
if  [ ! $(lsmod | grep jitterentropy_rng) ]; then
        modprobe jitterentropy-rng
        echo "Sucess load jitterentropy_rng module..."
        if  [ ! $(cat /etc/modules | grep jitterentropy_rng) ]; then
                echo "jitterentropy_rng" >> /etc/modules
                echo "Sucess add module jitterentropy_rng for autoload by start system..."
        fi
fi
do_restart()
start-stop-daemon --stop --quiet --retry=TERM/2/KILL/5 --pidfile $PIDFILE --exec $DAEMON
start-stop-daemon --start --quiet --retry=TERM/2/KILL/5 --pidfile $PIDFILE --exec $DAEMON
do_start()
do_stop()
Please repack installation package jitterentropy-rngd with this code!
#2 2020-11-28 19:54:11
Re: I solve issue with jitterentropy-rngd package
The package is drawn from Debian's repositories (using amprolla) so if you want the init script to be modified then you will have to ask the Debian package maintainer instead.
And your modifications have some issues:
No need to use the [ test and no need for lsmod:
if ! grep -q jitterentropy_rng /proc/modules; then
Useless use of cat and again, no need for [:
if ! grep -q jitterentropy_rng /etc/modules; then
HTH
EDIT: on reflection I really don't think an init script should be changing system configuration files. Just the modprobe should be sufficient.
Black Lives Matter
#3 2020-11-29 13:50:21
Eaglet
Ok, comrade!
I send my and your information to Debian bug report.
Thank you for your comment!
