#1 2020-11-20 15:05:09
PengouinPdt
[Ceres + OpenRC] Opensmtpd not start during boot
Hi, I use Ceres with OpenRC.
For mail on console, I installed OpenSMTPD package and use without any problem.
But during the boot, OpenSMTPD not starts. I need to start it on the console myself.
It's not a problem with my config; in fact, when I start myself, it runs correctly, and can send emails.
Any idea?
#2 2020-11-20 18:03:35
Re: [Ceres + OpenRC] Opensmtpd not start during boot
Check the enabled services with
rc-update
If it's not listed then try to add it with
rc-update add opensmtpd
Black Lives Matter
#3 2020-11-21 12:50:27
PengouinPdt
rc-update | grep opensmtpd
            opensmtpd |      default
#4 2020-11-21 17:51:55
Can we see the entire (un-grep'd) output? I only use OpenRC with Alpine Linux so I'm not sure how Devuan order their services.
Otherwise check the logs for any clues.
Black Lives Matter
#5 2020-11-21 19:52:39
PengouinPdt
y!
see that:
# rc-update
           alsa-utils |                                              sysinit
              anacron |      default
             apparmor |                                              sysinit
         avahi-daemon |      default
             bootlogd |                                              sysinit
             bootlogs |      default               recovery
          bootmisc.sh |                                              sysinit
           brightness |                                              sysinit
              cgroups |                                              sysinit
           checkfs.sh |                                              sysinit
 checkroot-bootclean.sh |                                              sysinit
         checkroot.sh |                                              sysinit
     console-setup.sh |      default
                 cron |      default
                 cups |      default
         cups-browsed |      default
                 dbus |      default
              elogind |      default
                eudev |                                              sysinit
              hddtemp |      default
          hostname.sh |                                              sysinit
           hwclock.sh |                                              sysinit
    keyboard-setup.sh |                                              sysinit
            killprocs |                            recovery
                 kmod |                                              sysinit
           lm-sensors |                                              sysinit
       mount-configfs |                                              sysinit
 mountall-bootclean.sh |                                              sysinit
          mountall.sh |                                              sysinit
     mountdevsubfs.sh |                                              sysinit
       mountkernfs.sh |                                              sysinit
 mountnfs-bootclean.sh |                                              sysinit
          mountnfs.sh |                                              sysinit
      network-manager |      default
           networking |                                              sysinit
            opensmtpd |      default
             pppd-dns |                                              sysinit
               procps |                                              sysinit
 pulseaudio-enable-autospawn |      default
             rc.local |      default
            rmnologin |      default
                rsync |      default
              rsyslog |      default
                saned |      default
            savecache |                        off
             sendsigs |                        off
               single |                            recovery
                 slim |      default
        smartmontools |      default
        stop-bootlogd |      default
 stop-bootlogd-single |                                              sysinit
                 sudo |      default
             umountfs |                        off
         umountnfs.sh |                        off
           umountroot |                        off
              urandom |                                              sysinit
                uuidd |      default
                 wicd |      default
           x11-common |                                              sysinit
I found nothing on the logs.
#6 2020-11-22 15:14:33
Which logs did you check? Perhaps you should upload them to a pastebin and share the link here so that we can check to see if you missed anything.
If I had to guess I would suggest that the problem lies here:
^ That starts on the same runlevel as Opensmtpd so it might be running too late and causing the problem.
Perhaps try ifupdown (ie, /etc/network/interfaces & /etc/init.d/networking) instead of NetworkManager, that starts at the sysinit runlevel and so would ensure that the network is up before Opensmtpd starts.
See interfaces(5) & https://wiki.debian.org/WiFi/HowToUse#W … d_WPA2-PSK for the configuration methods.
Black Lives Matter
#7 2020-11-22 16:25:34
PengouinPdt
Which log? /var/log/daemon, /var/log/messages, /var/log/mail.log!
Actually, I set opensmtpd on the runlevel sysinit. Wait'n see.
If not run correctly, I will use interfaces(5). I prefere than Network Manager; interfaces are more simpliest or easy to configure. tongue
#8 2020-11-24 19:08:23
PengouinPdt wrote:
Which log?
No idea, sorry. FWIW the systemd journal is excellent for stuff like this. *dives for cover*
Black Lives Matter
#9 2020-11-24 22:31:40
PengouinPdt
I found one information on /var/log/boot. That's help me!
#10 2020-11-26 13:52:32
Geoff 42
Have you tried turning on logging in OpenRC?
In /etc/rc.conf you may find a line :-
#rc_logger="NO"
change that to
rc_logger="YES"
and you should get the logging as OpenRC does its stuff, in /var/log/rc.log, although the location can also be changed in /etc/rc.conf.
Also the command rc-status should show you what state each service is in.
Geoff
#11 2020-11-28 00:19:45
PengouinPdt
It was very simple. When I configure the smtpd file, for my needs, I chmoded my secret files on 0600. It was one error, because the group is opensmtpd. After chmoded at 0640, openstmpd can read it during the boot! ;-)
Another detail: I migrated to Devuan from Linux Mint. But, on LM, with have the account ciffred by ecrypts tools.
Before, when I was on Debian Sid, I had not my ciffred personal home. My secret files for opensmtpd is on my home.
Now, due to ciffred home, I put the secret file in other place, that can be read by system and service tongue
(thanks to the boot log than help me) big_smile
