#1 2020-11-14 12:07:46
swarfendor437
Is wicd needed for LXQt/Kwin?
Currently using KDE and LXQt DE's. Wicd is appearing in KDE alongside KDE's Network Manager Applet - any reason not to remove wicd? (Remember using it many years ago on earlier Linux Distros. wink
#2 2020-11-15 15:27:03
Re: Is wicd needed for LXQt/Kwin?
Probably not but you can check by simulating a removal:
aptitude --simulate purge wicd{,-cli,-curses,-daemon,-gtk}
Black Lives Matter
#3 2020-11-16 20:42:05
swarfendor437
Oh the Bliss of Devuan! Will give it a go. Thanks Head_on_a_Stick. wink
#4 2020-11-16 20:46:28
swarfendor437
Hmm! I think I will abstain from its removal! I can always remove the icon from the panel I guess!  This is the return of that command:
the following packages will be REMOVED:
  cjs{u} dnsutils{u} file-roller{u} gir1.2-accountsservice-1.0{u}
  gir1.2-caribou-1.0{u} gir1.2-clutter-1.0{u} gir1.2-cogl-1.0{u}
  gir1.2-coglpango-1.0{u} gir1.2-gdesktopenums-3.0{u} gir1.2-gkbd-3.0{u}
  gir1.2-gnomedesktop-3.0{u} gir1.2-gtkclutter-1.0{u} gir1.2-harfbuzz-0.0{u}
  gir1.2-json-1.0{u} gir1.2-keybinder-3.0{u} gir1.2-nm-1.0{u} gir1.2-nma-1.0{u}
  gir1.2-upowerglib-1.0{u} gir1.2-xapp-1.0{u} gir1.2-xkl-1.0{u} gist{u}
  gnome-backgrounds{u} gobject-introspection{u} gvfs-bin{u} hddtemp{u}
  icu-devtools{u} inxi{u} iso-flags-png-320x240{u} libatk-bridge2.0-dev{u}
  libatk1.0-dev{u} libatspi2.0-dev{u} libcairo-script-interpreter2{u}
  libcairo2-dev{u} libcaribou-common{u} libcaribou0{u} libcjs0{u} libdbus-1-dev{u}
  libdbus-glib-1-dev{u} libdbus-glib-1-dev-bin{u} libdrm-dev{u} libegl1-mesa-dev{u}
  libepoxy-dev{u} libexpat1-dev{u} libfontconfig1-dev{u} libfreetype6-dev{u}
  libfribidi-dev{u} libgarcon-common{u} libgirepository1.0-dev{u}
  libgl1-mesa-dev{u} libgles1{u} libglvnd-core-dev{u} libglvnd-dev{u}
  libgraphite2-dev{u} libgtk-3-dev{u} libharfbuzz-dev{u} libharfbuzz-gobject0{u}
  libice-dev{u} libicu-dev{u} libirs161{u} libkeybinder-3.0-0{u} liblzo2-2{u}
  libmozjs-52-0{u} libmozjs-52-dev{u} libmuparser2v5{u} libnemo-extension1{u}
  libnotify-bin{u} libopengl0{u} libpango1.0-dev{u} libpixman-1-dev{u} libsm-dev{u}
  libstatgrab10{u} libsysstat-qt5-0{u} libtagc0{u} libunique-1.0-0{u}
  libwayland-bin{u} libwayland-dev{u} libwnck-common{u} libwnck22{u}
  libx11-xcb-dev{u} libxapp1{u} libxcb-dri2-0-dev{u} libxcb-dri3-dev{u}
  libxcb-glx0-dev{u} libxcb-present-dev{u} libxcb-randr0-dev{u}
  libxcb-render0-dev{u} libxcb-shape0-dev{u} libxcb-shm0-dev{u} libxcb-sync-dev{u}
  libxcb-xfixes0-dev{u} libxcomposite-dev{u} libxcursor-dev{u} libxdamage-dev{u}
  libxext-dev{u} libxfixes-dev{u} libxft-dev{u} libxi-dev{u} libxinerama-dev{u}
  libxkbcommon-dev{u} libxnvctrl0{u} libxrandr-dev{u} libxrender-dev{u}
  libxshmfence-dev{u} libxtst-dev{u} libxxf86vm-dev{u} mesa-common-dev{u}
  pango1.0-tools{u} python-notify{u} python-wicd{u} python3-markdown{u}
  python3-pampy{u} python3-psutil{u} python3-pygments{u} python3-pyinotify{u}
  python3-setproctitle{u} python3-xapp{u} python3-xlib{u} python3-yaml{u} rfkill{u}
  ruby-json{u} tree{u} wayland-protocols{u} wicd{p} wicd-daemon{p} wicd-gtk{pu}
  wireless-tools{u} x11proto-composite-dev{u} x11proto-damage-dev{u}
  x11proto-fixes-dev{u} x11proto-randr-dev{u} x11proto-record-dev{u}
  x11proto-xext-dev{u} x11proto-xf86vidmode-dev{u} x11proto-xinerama-dev{u}
  xapps-common{u} xsane{u} xsane-common{u}
#5 2020-11-17 20:05:12
That's strange, the LXQt desktop metapackage only lists wicd as a Recommends and it also has network-manager-gnome or nm-tray as alternatives for that.
Does this work:
apt install --simulate nm-tray wicd{,-cli,-curses,-daemon,-gtk}-
If that still results in a mass removal then just disable wicd instead:
# update-rc.d wicd defaults-disabled
Black Lives Matter
#6 2020-11-18 22:42:33
swarfendor437
Thanks Head_on_a_Stick - I'll play safe and take the second option. wink
#7 2021-01-28 02:01:51
mckaygerhard
to remove wicd you must disable recommends, later force unninstall and later reinstall all network manager..
that wicd depends or install are triggered by debian changes in last two releases by example the Recommends on LXDE and LXQT are "wicd | network-manager-gnome" so due wicd are first is installed in task of packages..
