#1 2020-11-10 13:13:45
ribcage
NETDEV WATCHDOG: enp2s1 (r8169): transmit queue 0 timed out
Hello, I hope you won't kick me out for using Debian 10? It's impossible to register on Debian forums, so I thought maybe someone could help me here. I did consider changing to Devuan though.
So here's the problem, I have a PCI NIC and sometimes in dmesg I get this message:
[245059.532807] ------------[ cut here ]------------
[245059.532813] NETDEV WATCHDOG: enp2s1 (r8169): transmit queue 0 timed out
[245059.532855] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:461 dev_watchdog+0x1b6/0x1c0
[245059.532857] Modules linked in: tcp_diag udp_diag inet_diag unix_diag msr binfmt_misc hid_generic usbhid hid iTCO_wdt pcspkr iTCO_vendor_support serio_raw intel_rng rng_core evdev sg nfsd auth_rpcgss lm85 nfs_acl hwmon_vid lockd grace parport_pc ppdev sunrpc lp parport ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 crc32c_generic uas usb_storage fscrypto ecb crypto_simd cryptd aes_i586 sd_mod ata_generic ata_piix libata uhci_hcd ehci_pci ehci_hcd r8169 psmouse usbcore scsi_mod realtek i2c_i801 libphy lpc_ich usb_common button
[245059.532930] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.19.0-6-686-pae #1 Debian 4.19.67-2
[245059.532931] Hardware name:  /D865PERL                       , BIOS RL86510A.86A.0069.P12.0310231435 10/23/2003
[245059.532936] EIP: dev_watchdog+0x1b6/0x1c0
[245059.532940] Code: 8b 50 3c 89 f8 e8 62 cc 10 00 8b 7e f0 eb a3 89 f8 c6 05 6b 03 93 d2 01 e8 c7 de fc ff 53 50 57 68 c4 3d 85 d2 e8 0e e4 ad ff <0f> 0b 83 c4 10 eb c9 8d 76 00 3e 8d 74 26 00 55 89 e5 57 56 89 d6
[245059.532942] EAX: 0000003b EBX: 00000000 ECX: f6fcb56c EDX: 00000007
[245059.532944] ESI: f68cb2e8 EDI: f68cb000 EBP: f68c1f68 ESP: f68c1f40
[245059.532946] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 EFLAGS: 00210292
[245059.532948] CR0: 80050033 CR2: b7df2530 CR3: 2c784000 CR4: 000006f0
[245059.532950] Call Trace:
[245059.532953]  <SOFTIRQ>
[245059.532960]  ? pfifo_fast_enqueue+0xf0/0xf0
[245059.532965]  call_timer_fn+0x2f/0x130
[245059.532968]  ? pfifo_fast_enqueue+0xf0/0xf0
[245059.532971]  run_timer_softirq+0x3b5/0x400
[245059.532977]  __do_softirq+0xb2/0x275
[245059.532981]  ? __softirqentry_text_start+0x8/0x8
[245059.532986]  call_on_stack+0x45/0x50
[245059.532987]  </SOFTIRQ>
[245059.532991]  ? irq_exit+0xc5/0xd0
[245059.532995]  ? smp_apic_timer_interrupt+0x6c/0x130
[245059.532997]  ? apic_timer_interrupt+0xd5/0xdc
[245059.533000]  ? __cpuidle_text_start+0x8/0x8
[245059.533003]  ? native_safe_halt+0x11/0x20
[245059.533005]  ? default_idle+0x1f/0x150
[245059.533010]  ? arch_cpu_idle+0x12/0x20
[245059.533012]  ? default_idle_call+0x2d/0x30
[245059.533016]  ? do_idle+0x1bf/0x240
[245059.533019]  ? __do_sys_reboot+0x3b/0x210
[245059.533022]  ? cpu_startup_entry+0x65/0x70
[245059.533026]  ? rest_init+0x88/0x8a
[245059.533029]  ? start_kernel+0x446/0x45f
[245059.533032]  ? i386_start_kernel+0xac/0xb0
[245059.533035]  ? startup_32_smp+0x164/0x168
[245059.533038] ---[ end trace e06e3df1061a1cfc ]---
Often I was able to trigger it by initiating a download with wget and nearly maxing out the bandwidth. When I would do it via SSH, the shell would hang for a few seconds, then return some time later. But not always, other times I could seemingly push the link to the max for a long time. It also recently happened with high activity on a BitTorrent client.
Could a BIOS update help? I'm hesitant to do it because the update process is very inconvenient and I've read about issues with later BIOS versions on this board.
A little more info:
root@debian:~# lspci -vvv
02:01.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8169 PCI Gigabit Ethernet Controller (rev 10)
	Subsystem: Realtek Semiconductor Co., Ltd. RTL8169/8110 Family PCI Gigabit Ethernet NIC
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 64 (8000ns min, 16000ns max), Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 22
	Region 0: I/O ports at b800 [size=256]
	Region 1: Memory at ff9ffc00 (32-bit, non-prefetchable) [size=256]
	Expansion ROM at ff9c0000 [disabled] [size=128K]
	Capabilities: [dc] Power Management version 2
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	Kernel driver in use: r8169
	Kernel modules: r8169
Could this have something to do with power management or IRQ? This is the only PCI card on this board.
root@debian:~# ip -d link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 promiscuity 0 minmtu 0 maxmtu 0 addrgenmode eui64 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
2: enp2s1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether (mac removed) brd ff:ff:ff:ff:ff:ff promiscuity 0 minmtu 60 maxmtu 7152 addrgenmode none numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
The message in dmesg mentions "[245059.532960]  ? pfifo_fast_enqueue+0xf0/0xf0", could I try a different queue algorithm, if that's what it is?
root@debian:~# modinfo r8169
filename:       /lib/modules/4.19.0-6-686-pae/kernel/drivers/net/ethernet/realtek/r8169.ko
firmware:       rtl_nic/rtl8107e-2.fw
firmware:       rtl_nic/rtl8107e-1.fw
firmware:       rtl_nic/rtl8168h-2.fw
firmware:       rtl_nic/rtl8168h-1.fw
firmware:       rtl_nic/rtl8168g-3.fw
firmware:       rtl_nic/rtl8168g-2.fw
firmware:       rtl_nic/rtl8106e-2.fw
firmware:       rtl_nic/rtl8106e-1.fw
firmware:       rtl_nic/rtl8411-2.fw
firmware:       rtl_nic/rtl8411-1.fw
firmware:       rtl_nic/rtl8402-1.fw
firmware:       rtl_nic/rtl8168f-2.fw
firmware:       rtl_nic/rtl8168f-1.fw
firmware:       rtl_nic/rtl8105e-1.fw
firmware:       rtl_nic/rtl8168e-3.fw
firmware:       rtl_nic/rtl8168e-2.fw
firmware:       rtl_nic/rtl8168e-1.fw
firmware:       rtl_nic/rtl8168d-2.fw
firmware:       rtl_nic/rtl8168d-1.fw
license:        GPL
softdep:        pre: realtek
description:    RealTek RTL-8169 Gigabit Ethernet driver
author:         Realtek and the Linux r8169 crew <netdev@vger.kernel.org>
alias:          pci:v00000001d00008168sv*sd00002410bc*sc*i*
alias:          pci:v00001737d00001032sv*sd00000024bc*sc*i*
alias:          pci:v000016ECd00000116sv*sd*bc*sc*i*
alias:          pci:v00001259d0000C107sv*sd*bc*sc*i*
alias:          pci:v00001186d00004302sv*sd*bc*sc*i*
alias:          pci:v00001186d00004300sv*sd*bc*sc*i*
alias:          pci:v00001186d00004300sv00001186sd00004B10bc*sc*i*
alias:          pci:v000010ECd00008169sv*sd*bc*sc*i*
alias:          pci:v000010FFd00008168sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008168sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008167sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008161sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008136sv*sd*bc*sc*i*
alias:          pci:v000010ECd00008129sv*sd*bc*sc*i*
alias:          pci:v000010ECd00002600sv*sd*bc*sc*i*
alias:          pci:v000010ECd00002502sv*sd*bc*sc*i*
depends:        libphy
retpoline:      Y
intree:         Y
vermagic:       4.19.0-6-686-pae SMP mod_unload modversions 686
sig_id:         PKCS#7
signer:         Debian Secure Boot CA
sig_key:        A7:46:8D:EF
sig_hashalgo:   sha256
signature:      78:24:91:CC:A6:D0:5C:2D:EE:3A:FE:32:1D:76:8A:5E:50:BE:93:1B:
		03:8F:21:5E:F9:4A:14:D6:8F:07:D0:7D:12:A5:FE:64:3A:29:A3:87:
		3D:C5:62:F6:C0:68:E0:57:A1:9E:19:20:05:4A:80:63:7B:39:87:6B:
		49:2D:E8:A2:CA:E3:5F:EF:50:8C:B7:16:33:D9:CC:E8:34:AA:80:A0:
		82:DE:E9:6F:2B:C3:39:8A:A3:38:66:D8:8A:A1:E5:08:0B:5F:6F:FD:
		80:54:23:46:EF:96:A8:CE:0E:36:E8:AB:CA:BF:BD:87:19:A7:7D:12:
		20:E6:40:F6:30:72:77:1C:A6:D2:C7:EC:FC:81:17:C1:77:4C:D3:BA:
		0E:F8:44:A6:9D:93:9E:76:9E:C8:8C:D0:89:5B:34:D9:C7:E1:FC:CB:
		CB:63:13:01:14:B3:5A:00:9B:C3:DD:8F:6E:C4:70:62:4E:2C:E0:58:
		43:28:AC:25:72:A2:7B:ED:39:03:B3:AE:F3:AE:53:D9:62:22:3C:ED:
		3C:52:DB:93:0E:0E:DB:EC:F5:58:DF:04:3A:66:D9:B1:69:A2:97:64:
		28:9B:A7:07:62:F2:57:DB:AA:2B:F8:D3:59:2E:B7:D6:68:A0:22:19:
		30:98:D1:5B:C4:59:62:C9:17:57:C7:01:86:6C:9A:B8
parm:           use_dac:Enable PCI DAC. Unsafe on 32 bit PCI slot. (int)
parm:           debug:Debug verbosity level (0=none, ..., 16=all) (int)
The second line from the last looks interesting. It says "Unsafe on 32 bit slot" and my slot is 32 bit as far as I know.
#2 2020-11-10 17:02:51
Re: NETDEV WATCHDOG: enp2s1 (r8169): transmit queue 0 timed out
Why? What happens when you try? I'm a moderator on the Debian forums so I might be able to help with that and you really shouldn't be posting a Debian problem here.
FWIW you can try the r8168 driver instead and see if that's any more stable:
https://packages.debian.org/buster/r8168-dkms
Black Lives Matter
#3 2020-11-10 17:43:56
ribcage
Thank you, I will try that.
I can't register because I am not receiving the verification email for six hours, I tried the re-send button. My mail is yahoo.com. As a side note, the confirmation code while registering is inhumanely difficult to read and SSL is not working.
#4 2020-11-10 17:48:53
Okay, I'll raise the issue with the administrators. We've had another user report the same problem so something must be wrong. Thanks for the feedback.
ribcage wrote:
SSL is not working
The boards have never supported https and they probably never will. It is not a problem unless you use the same password everywhere, which is a stupid thing to do.
Black Lives Matter
#5 2020-11-10 17:53:07
ribcage
ribcage wrote:
SSL is not working
Thank you. To be honest I don't care much about SSL, but may I ask why Debian forums choose not to use it?
Also, r8168-dkms description says "...for RealTek ... Gigabit Ethernet controllers with PCI-Express interface." while mine is PCI, not PCI-Express. Will this driver still work for me? And from what I see, I must compile it myself?
#6 2020-11-10 17:58:29
No idea, sorry. The boards are donated by a kind Debian developer so we don't look the gift horse in the mouth, so to speak.
Only one way to find out wink
Installing the package will run the compilation for you.
Black Lives Matter
