#1 2020-11-09 11:36:44
devian
bash-completion not enabled by default after installation
As title, I've installed bash-completion and finding that it does not do autocomplete with git. e.g.
git chec***tab***
Then nothing. Same for
apt-get inst***tab***
I note that this is solved by doing
. /usr/share/bash-completion/completions/git
or
. /etc/bash_completion
but why is this not setup by default when you install the bash-completion package? Surely one of these scripts should automatically be run when opening bash?
#2 2020-11-10 17:08:11
Re: bash-completion not enabled by default after installation
Does it work if you log in to the console (TTY) screen?
EDIT: un-comment the section in ~/.bashrc (for just your user) or /etc/bash.bashrc (for all users).
#3 2020-11-10 17:15:30
devian
Yes, if I ctrl-alt-f1, login and try tabbing out commands then completion works fine.
Uncomment which section?
Thanks
#4 2020-11-10 17:22:03
It doesn't work on the desktop because SLiM doesn't read ~/.profile or /etc/profile{,.d/*}.
This bit:
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if ! shopt -oq posix; then
  if [ -f /usr/share/bash-completion/bash_completion ]; then
    . /usr/share/bash-completion/bash_completion
  elif [ -f /etc/bash_completion ]; then
  fi
fi
#5 2020-11-10 17:30:13
devian
I don't have that in my .profile file. Should I have it in there do you think?
I did
apt-get install --reinstall bash-completion
but there is still nothing in .profile.
#6 2020-11-10 17:40:49
#7 2020-11-10 17:46:45
devian
I do not have anything related to bash-completion in my .profile or .bashrc
I note that on Debian it does automatically insert the code you quoted into .bashrc when you install the package.
What a strange issue...
#8 2020-11-10 17:55:23
How about in /etc/skel/.bashrc? It should be the final stanza in that file and that file should be copied to $HOME when your user is created.
I don't think so.
#9 2020-11-10 18:07:58
devian
Yes, the bash-completion setup code exists in /etc/skel/.bashrc. I created a new user and yes, the correct code is in their bashrc.
I admit defeat - all I will say is I think that these issues arose because I have been using Devuan for a while so gone through at least one upgrade cycle.
Is it possible that in the previous major release of Devuan these problems I mentioned were present and have been carried across to my current setup?
#10 2020-11-10 18:11:01
It's certainly possible that the bash-completion package worked differently in the past and so your old ~/.bashrc doesn't work with it now.
#11 2020-11-10 18:12:40
devian
Okay, let's go with that then. Even Debian has issues when you upgrade between versions as opposed to doing an installation from fresh.
