#1 2020-11-09 08:18:09
AntoFox
A new desktop
Hi
I rebuilt gnome-shell for devuan beowulf, if anyone wants to try it  find the instructions here:
http://hezeh.org/Gnome-shell-on-devuan/
the sources unlike mate and cinnamon are those of debian, let me know if something is wrong
#2 2020-11-09 12:47:05
nixer
Re: A new desktop
If I may, the command to download and add the keyring is slightly off on the linked page above.  This worked:
wget http://hezeh.org/packages/antofox-keyrings && apt-key add antofox-keyrings
I have not seen or used gnome in over 5 years.  I will give it a test.  Thank you.
#3 2020-11-10 17:18:37
Re: A new desktop
The echo commands won't work because the root privileges conferred by sudo do not apply after the redirection (>>).
Use a here document instead:
sudo tee -a /etc/apt/sources.list <<!
deb http://hezeh.org/packages beowulf main contrib non-free
deb-src http://hezeh.org/packages beowulf main contrib non-free
And I'm also pretty sure you don't need the contrib & non-free components.
#4 2020-11-11 02:53:23
Re: A new desktop
Meh, I still wonder why people use DE's... apart from Lumina anyways.
But if you enjoy it well, alright.
I myself use i3-wm. smile
That all being said,  I hope you enjoy it.
#5 2020-11-11 07:58:54
AntoFox
Re: A new desktop
@Nixer retry
antofox@altair:~$ wget http://hezeh.org/packages/antofox-keyrings
--2020-11-11 08:54:49--  http://hezeh.org/packages/antofox-keyrings
Resolving hezeh.org (hezeh.org)... 167.99.203.149
Connecting to hezeh.org (hezeh.org)|167.99.203.149|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1745 (1,7K) [application/octet-stream]
Saving to: ‘antofox-keyrings’
antofox-keyrings    100%[===================>]   1,70K  --.-KB/s    in 0s
2020-11-11 08:54:49 (30,3 MB/s) - ‘antofox-keyrings’ saved [1745/1745]
_______________________________
In case wget does not run download form here:
