#1 2020-10-30 07:53:20
Klmjab
[SOLVED] Beowulf: Xserver native mode in AMD Ryzen 5 Pro 4650G
I've managed to install Beowulf on a machine with the following components: MB Asus Prime B550M-A + AMD Ryzen 5 Pro 4650G APU (Radeon Vega with GPU Cores Vega 7 RENOIR) + stock linux-image-4.19.0-12 + Mate Desktop. The system works well, but Xserver is running in VESA mode. To try to solve this,
I done :
1.- Upgrade firmware of the motherboard to the last version available on the web (I think date is 10-22-2020) => NO RESULT
2.- Install the last linux image from backports (linux-image-5.8.0-0.bpo.2-amd64) => System does not boot until you pass "nomodeset" in the GRUB_CMDLINE_LINUX_DEFAULT of the /etc/default/grub file. Booting with Kernel Image 5.8.0 NO RESULT, Xserver still run on VESA mode
Questions:
1.- What do I have to do to get the system work with Xserver in native mode?
2.- Why do I have to pass the "nomodeset" parameter to kernel 5.8 if in 4.19 I don't have to?
3.- Does anybody has a similar system working with Xserver in native mode?
klmjab
@amanda:~$ dpkg -l | grep AMD
ii  amd64-microcode                       3.20181128.1                                 amd64        Processor microcode firmware for AMD CPUs
ii  firmware-amd-graphics                 20190114-2                                   all          Binary firmware for AMD/ATI graphics chips
ii  xserver-xorg-video-amdgpu             18.1.99+git20190207-1                        amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-ati                1:19.0.1-1                                   amd64        X.Org X server -- AMD/ATI display driver wrapper
ii  xserver-xorg-video-radeon             1:19.0.1-1                                   amd64        X.Org X server -- AMD/ATI Radeon display driver
[    10.608]
X.Org X Server 1.20.4
[    10.608] Build Operating System: Linux 4.19.0-10-amd64 x86_64 Debian
[    10.608] Current Operating System: Linux amanda 5.8.0-0.bpo.2-amd64 #1 SMP Debian 5.8.10-1~bpo10+1 (2020-09-26) x86_64
[    10.608] Kernel command line: BOOT_IMAGE=/vmlinuz-5.8.0-0.bpo.2-amd64 root=/dev/mapper/amanda--vg-root ro quiet splash nomodeset
[    10.608] Build Date: 27 August 2020  08:51:48AM
[    10.608] xorg-server 2:1.20.4-1+deb10u1 (https://www.debian.org/support)
[    10.608] Current version of pixman: 0.36.0
[    10.608] 	Before reporting problems, check http://wiki.x.org
[    10.608] Markers: (--) probed, (**) from config file, (==) default setting,
[    10.608] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 30 07:13:11 2020
[    10.609] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    10.609] (==) No Layout section.  Using the first Screen section.
[    10.609] (==) No screen section available. Using defaults.
[    10.609] (**) |-->Screen "Default Screen Section" (0)
[    10.609] (**) |   |-->Monitor "<default monitor>"
[    10.610] (==) No monitor specified for screen "Default Screen Section".
[    10.610] (==) Automatically adding devices
[    10.610] (==) Automatically enabling devices
[    10.610] (==) Automatically adding GPU devices
[    10.610] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    10.611] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    10.611] 	Entry deleted from font path.
[    10.612] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    10.612] (==) ModulePath set to "/usr/lib/xorg/modules"
[    10.612] (II) The server relies on udev to provide the list of input devices.
[    10.612] (II) Loader magic: 0x5601abcace20
[    10.612] (II) Module ABI versions:
[    10.612] 	X.Org ANSI C Emulation: 0.4
[    10.612] 	X.Org Video Driver: 24.0
[    10.612] 	X.Org XInput driver : 24.1
[    10.612] 	X.Org Server Extension : 10.0
[    10.612] (++) using VT number 7
[    10.612] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    10.614] (--) PCI:*(11@0:0:0) 1002:1636:1043:87e1 rev 217, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfcc00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[    10.614] (II) LoadModule: "glx"
[    10.614] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    10.616] (II) Module glx: vendor="X.Org Foundation"
[    10.616] 	compiled for 1.20.4, module version = 1.0.0
[    10.616] 	ABI class: X.Org Server Extension, version 10.0
[    10.616] (==) Matched ati as autoconfigured driver 0
[    10.616] (==) Matched modesetting as autoconfigured driver 1
[    10.616] (==) Matched fbdev as autoconfigured driver 2
[    10.616] (==) Matched vesa as autoconfigured driver 3
[    10.616] (==) Assigned the driver to the xf86ConfigLayout
[    10.616] (II) LoadModule: "ati"
[    10.616] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    10.616] (II) Module ati: vendor="X.Org Foundation"
[    10.616] 	compiled for 1.20.4, module version = 19.0.1
[    10.616] 	Module class: X.Org Video Driver
[    10.616] 	ABI class: X.Org Video Driver, version 24.0
[    10.678] (II) LoadModule: "radeon"
[    10.678] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[    10.680] (II) Module radeon: vendor="X.Org Foundation"
[    10.680] 	compiled for 1.20.4, module version = 19.0.1
[    10.680] 	Module class: X.Org Video Driver
[    10.680] 	ABI class: X.Org Video Driver, version 24.0
[    10.680] (II) LoadModule: "modesetting"
[    10.680] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    10.680] (II) Module modesetting: vendor="X.Org Foundation"
[    10.680] 	compiled for 1.20.4, module version = 1.20.4
[    10.680] (II) LoadModule: "fbdev"
[    10.680] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    10.681] (II) Module fbdev: vendor="X.Org Foundation"
[    10.681] 	compiled for 1.20.0, module version = 0.5.0
[    10.681] 	Module class: X.Org Video Driver
[    10.681] 	ABI class: X.Org Video Driver, version 24.0
[    10.681] (II) LoadModule: "vesa"
[    10.681] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    10.681] (II) Module vesa: vendor="X.Org Foundation"
[    10.681] 	compiled for 1.20.1, module version = 2.4.0
[    10.681] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[    10.682] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    10.682] (II) FBDEV: driver for framebuffer: fbdev
[    10.682] (II) VESA: driver for VESA chipsets: vesa
[    10.683] (EE) open /dev/dri/card0: No such file or directory
[    10.683] (WW) Falling back to old probe method for modesetting
[    10.683] (II) Loading sub module "fbdevhw"
[    10.683] (II) LoadModule: "fbdevhw"
[    10.683] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    10.683] (II) Module fbdevhw: vendor="X.Org Foundation"
[    10.683] 	compiled for 1.20.4, module version = 0.0.2
[    10.683] 	ABI class: X.Org Video Driver, version 24.0
[    10.684] (EE) Unable to find a valid framebuffer device
[    10.684] (WW) Falling back to old probe method for fbdev
[    10.684] (II) Loading sub module "fbdevhw"
[    10.684] (II) LoadModule: "fbdevhw"
[    10.684] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    10.684] (II) Module fbdevhw: vendor="X.Org Foundation"
[    10.684] 	compiled for 1.20.4, module version = 0.0.2
[    10.684] 	ABI class: X.Org Video Driver, version 24.0
[    10.684] (EE) open /dev/fb0: No such file or directory
[    10.684] (EE) Screen 0 deleted because of no matching config section.
[    10.684] (II) UnloadModule: "modesetting"
[    10.684] (II) UnloadModule: "fbdev"
[    10.684] (II) UnloadSubModule: "fbdevhw"
[    10.684] (II) Loading sub module "vbe"
[    10.684] (II) LoadModule: "vbe"
[    10.684] (II) Loading /usr/lib/xorg/modules/libvbe.so
[    10.684] (II) Module vbe: vendor="X.Org Foundation"
[    10.684] 	compiled for 1.20.4, module version = 1.1.0
[    10.684] (II) Loading sub module "int10"
[    10.684] (II) LoadModule: "int10"
[    10.684] (II) Loading /usr/lib/xorg/modules/libint10.so
[    10.685] (II) Module int10: vendor="X.Org Foundation"
[    10.685] 	compiled for 1.20.4, module version = 1.0.0
[    10.685] 	ABI class: X.Org Video Driver, version 24.0
[    10.685] (II) VESA(0): initializing int10
[    10.685] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[    10.685] (II) VESA(0): VESA BIOS detected
[    10.685] (II) VESA(0): VESA VBE Version 3.0
[    10.685] (II) VESA(0): VESA VBE Total Mem: 49152 kB
[    10.685] (II) VESA(0): VESA VBE OEM: AMD ATOMBIOS
[    10.685] (II) VESA(0): VESA VBE OEM Software Rev: 17.10
[    10.685] (II) VESA(0): VESA VBE OEM Vendor: (C) 1988-2018, Advanced Micro Devices, Inc.
[    10.685] (II) VESA(0): VESA VBE OEM Product: RENOIR
[    10.685] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[    10.695] (II) VESA(0): Creating default Display subsection in Screen section
[    10.695] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[    10.695] (==) VESA(0): RGB weight 888
[    10.695] (==) VESA(0): Default visual is TrueColor
[    10.695] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[    10.695] (II) Loading sub module "ddc"
[    10.695] (II) LoadModule: "ddc"
[    10.695] (II) Module "ddc" already built-in
[    10.695] (II) VESA(0): VESA VBE DDC supported
[    10.695] (II) VESA(0): VESA VBE DDC Level 2
[    10.695] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
[    10.798] (II) VESA(0): VESA VBE DDC read successfully
[    10.798] (II) VESA(0): Manufacturer: LEN  Model: 60f3  Serial#: 0
[    10.798] (II) VESA(0): Year: 2017  Week: 17
[    10.798] (II) VESA(0): EDID Version: 1.4
[    10.798] (II) VESA(0): Digital Display Input
[    10.798] (II) VESA(0): 8 bits per channel
[    10.798] (II) VESA(0): Digital interface is DisplayPort
[    10.798] (II) VESA(0): Max Image Size [cm]: horiz.: 51  vert.: 29
[    10.798] (II) VESA(0): Gamma: 2.20
[    10.798] (II) VESA(0): DPMS capabilities: StandBy Suspend Off
[    10.798] (II) VESA(0): Supported color encodings: RGB 4:4:4
[    10.798] (II) VESA(0): First detailed timing is preferred mode
[    10.798] (II) VESA(0): Preferred mode is native pixel format and refresh rate
[    10.798] (II) VESA(0): redX: 0.632 redY: 0.337   greenX: 0.330 greenY: 0.631
[    10.798] (II) VESA(0): blueX: 0.159 blueY: 0.041   whiteX: 0.313 whiteY: 0.329
[    10.798] (II) VESA(0): Supported established timings:
[    10.798] (II) VESA(0): 720x400@70Hz
[    10.798] (II) VESA(0): 640x480@60Hz
[    10.798] (II) VESA(0): 640x480@72Hz
[    10.798] (II) VESA(0): 640x480@75Hz
[    10.798] (II) VESA(0): 800x600@56Hz
[    10.798] (II) VESA(0): 800x600@60Hz
[    10.798] (II) VESA(0): 800x600@72Hz
[    10.798] (II) VESA(0): 800x600@75Hz
[    10.798] (II) VESA(0): 832x624@75Hz
[    10.798] (II) VESA(0): 1024x768@60Hz
[    10.798] (II) VESA(0): 1024x768@70Hz
[    10.798] (II) VESA(0): 1024x768@75Hz
[    10.798] (II) VESA(0): 1280x1024@75Hz
[    10.798] (II) VESA(0): Manufacturer's mask: 0
[    10.798] (II) VESA(0): Supported standard timings:
[    10.798] (II) VESA(0): #0: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    10.798] (II) VESA(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    10.798] (II) VESA(0): #2: hsize: 1280  vsize 1024  refresh: 70  vid: 35457
[    10.798] (II) VESA(0): #3: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    10.798] (II) VESA(0): #4: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[    10.798] (II) VESA(0): #5: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[    10.798] (II) VESA(0): #6: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    10.798] (II) VESA(0): Supported detailed timing:
[    10.798] (II) VESA(0): clock: 138.5 MHz   Image Size:  510 x 287 mm
[    10.798] (II) VESA(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[    10.798] (II) VESA(0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1111 v_border: 0
[    10.798] (II) VESA(0): Ranges: V min: 50 V max: 75 Hz, H min: 30 H max: 81 kHz, PixClock max 215 MHz
[    10.798] (II) VESA(0): Monitor name: LEN T2324dC
[    10.798] (II) VESA(0): Serial No: VN-A1V0WW
[    10.798] (II) VESA(0): Number of EDID sections to follow: 1
[    10.798] (II) VESA(0): EDID (in hex):
[    10.798] (II) VESA(0): 	00ffffffffffff0030aef36000000000
[    10.798] (II) VESA(0): 	111b0104a5331d78e2dae5a15654a128
[    10.798] (II) VESA(0): 	0a5054afef00714f8180818a9500a9c0
[    10.798] (II) VESA(0): 	a9c0b30001011a3680a070381f403020
[    10.798] (II) VESA(0): 	3500fe1f1100001a000000fd00324b1e
[    10.798] (II) VESA(0): 	5115000a202020202020000000fc004c
[    10.798] (II) VESA(0): 	454e20543233323464430a20000000ff
[    10.798] (II) VESA(0): 	00564e2d4131563057570a2020200176
[    10.798] (II) VESA(0): EDID vendor "LEN", prod id 24819
[    10.798] (II) VESA(0): Using EDID range info for horizontal sync
[    10.798] (II) VESA(0): Using EDID range info for vertical refresh
[    10.798] (II) VESA(0): Printing DDC gathered Modelines:
[    10.798] (II) VESA(0): Modeline "1920x1080"x0.0  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz eP)
[    10.798] (II) VESA(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    10.798] (II) VESA(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    10.798] (II) VESA(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    10.798] (II) VESA(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    10.798] (II) VESA(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    10.798] (II) VESA(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    10.798] (II) VESA(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    10.798] (II) VESA(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    10.798] (II) VESA(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    10.798] (II) VESA(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    10.798] (II) VESA(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    10.798] (II) VESA(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    10.798] (II) VESA(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    10.798] (II) VESA(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    10.798] (II) VESA(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    10.798] (II) VESA(0): Modeline "1280x1024"x70.0  128.94  1280 1368 1504 1728  1024 1025 1028 1066 -hsync +vsync (74.6 kHz e)
[    10.798] (II) VESA(0): Modeline "1440x900"x0.0  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    10.798] (II) VESA(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[    10.798] (II) VESA(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[    10.799] (II) VESA(0): Searching for matching VESA mode(s):
[    10.799] Mode: 110 (640x480)
[    10.799] 	ModeAttributes: 0xbb
[    10.799] 	WinAAttributes: 0x7
[    10.799] 	WinBAttributes: 0x0
[    10.799] 	WinGranularity: 64
[    10.799] 	WinSize: 64
[    10.799] 	WinASegment: 0xa000
[    10.799] 	WinBSegment: 0x0
[    10.799] 	WinFuncPtr: 0xc0004caf
[    10.799] 	BytesPerScanline: 1280
[    10.799] 	XResolution: 640
[    10.799] 	YResolution: 480
[    10.799] 	XCharSize: 8
[    10.799] 	YCharSize: 16
[    10.799] 	NumberOfPlanes: 1
[    10.799] 	BitsPerPixel: 16
[    10.799] 	NumberOfBanks: 1
[    10.799] 	MemoryModel: 6
[    10.799] 	BankSize: 0
[    10.799] 	NumberOfImages: 75
[    10.799] 	RedMaskSize: 5
[    10.799] 	RedFieldPosition: 10
[    10.799] 	GreenMaskSize: 5
[    10.799] 	GreenFieldPosition: 5
[    10.799] 	BlueMaskSize: 5
[    10.799] 	BlueFieldPosition: 0
[    10.799] 	RsvdMaskSize: 0
[    10.799] 	RsvdFieldPosition: 0
[    10.799] 	DirectColorModeInfo: 0
[    10.799] 	PhysBasePtr: 0xd0000000
[    10.799] 	LinBytesPerScanLine: 1280
[    10.799] 	BnkNumberOfImagePages: 75
[    10.799] 	LinNumberOfImagePages: 75
[    10.799] 	LinRedMaskSize: 5
[    10.799] 	LinRedFieldPosition: 10
[    10.799] 	LinGreenMaskSize: 5
[    10.799] 	LinGreenFieldPosition: 5
[    10.799] 	LinBlueMaskSize: 5
[    10.799] 	LinBlueFieldPosition: 0
[    10.799] 	LinRsvdMaskSize: 0
[    10.799] 	LinRsvdFieldPosition: 0
[    10.799] 	MaxPixelClock: 400000000
[    10.799] Mode: 111 (640x480)
[    10.800] 	WinASegment: 0xa000
[    10.800] 	WinBSegment: 0x0
[    10.800] 	WinFuncPtr: 0xc0004caf
[    10.800] 	BytesPerScanline: 1280
[    10.800] 	XResolution: 640
[    10.800] 	YResolution: 480
[    10.800] 	XCharSize: 8
[    10.800] 	YCharSize: 16
[    10.800] 	NumberOfPlanes: 1
[    10.800] 	BitsPerPixel: 16
[    10.800] 	NumberOfBanks: 1
[    10.800] 	MemoryModel: 6
[    10.800] 	BankSize: 0
[    10.800] 	NumberOfImages: 75
[    10.800] 	RedMaskSize: 5
[    10.800] 	RedFieldPosition: 11
[    10.800] 	GreenMaskSize: 6
[    10.800] 	GreenFieldPosition: 5
[    10.800] 	BlueMaskSize: 5
[    10.800] 	BlueFieldPosition: 0
[    10.800] 	RsvdMaskSize: 0
[    10.800] 	RsvdFieldPosition: 0
[    10.800] 	DirectColorModeInfo: 0
[    10.800] 	PhysBasePtr: 0xd0000000
[    10.800] 	LinBytesPerScanLine: 1280
[    10.800] 	BnkNumberOfImagePages: 75
[    10.800] 	LinNumberOfImagePages: 75
[    10.800] 	LinRedMaskSize: 5
[    10.800] 	LinRedFieldPosition: 11
[    10.800] 	LinGreenMaskSize: 6
[    10.800] 	LinGreenFieldPosition: 5
[    10.800] 	LinBlueMaskSize: 5
[    10.800] 	LinBlueFieldPosition: 0
[    10.800] 	LinRsvdMaskSize: 0
[    10.800] 	LinRsvdFieldPosition: 0
[    10.800] 	MaxPixelClock: 400000000
[    10.800] *Mode: 121 (640x480)
[    10.800] 	ModeAttributes: 0xbb
[    10.800] 	WinAAttributes: 0x7
[    10.800] 	WinBAttributes: 0x0
[    10.800] 	WinGranularity: 64
[    10.800] 	WinSize: 64
[    10.800] 	BytesPerScanline: 2560
[    10.800] 	BitsPerPixel: 32
[    10.800] 	NumberOfImages: 39
[    10.800] 	RedMaskSize: 8
[    10.800] 	RedFieldPosition: 16
[    10.800] 	GreenMaskSize: 8
[    10.800] 	GreenFieldPosition: 8
[    10.800] 	BlueMaskSize: 8
[    10.800] 	LinBytesPerScanLine: 2560
[    10.800] 	BnkNumberOfImagePages: 39
[    10.800] 	LinNumberOfImagePages: 39
[    10.800] 	LinRedMaskSize: 8
[    10.800] 	LinRedFieldPosition: 16
[    10.800] 	LinGreenMaskSize: 8
[    10.800] 	LinGreenFieldPosition: 8
[    10.800] 	LinBlueMaskSize: 8
[    10.801] Mode: 113 (800x600)
[    10.801] 	ModeAttributes: 0xbb
[    10.801] 	WinAAttributes: 0x7
[    10.801] 	WinBAttributes: 0x0
[    10.801] 	WinGranularity: 64
[    10.801] 	WinSize: 64
[    10.801] 	WinASegment: 0xa000
[    10.801] 	WinBSegment: 0x0
[    10.801] 	WinFuncPtr: 0xc0004caf
[    10.801] 	BytesPerScanline: 1664
[    10.801] 	XResolution: 800
[    10.801] 	YResolution: 600
[    10.801] 	XCharSize: 8
[    10.801] 	YCharSize: 14
[    10.801] 	NumberOfPlanes: 1
[    10.801] 	BitsPerPixel: 16
[    10.801] 	NumberOfBanks: 1
[    10.801] 	MemoryModel: 6
[    10.801] 	BankSize: 0
[    10.801] 	NumberOfImages: 47
[    10.801] 	RedMaskSize: 5
[    10.801] 	RedFieldPosition: 10
[    10.801] 	GreenMaskSize: 5
[    10.801] 	GreenFieldPosition: 5
[    10.801] 	BlueMaskSize: 5
[    10.801] 	BlueFieldPosition: 0
[    10.801] 	RsvdMaskSize: 0
[    10.801] 	RsvdFieldPosition: 0
[    10.801] 	DirectColorModeInfo: 0
[    10.801] 	PhysBasePtr: 0xd0000000
[    10.801] 	LinBytesPerScanLine: 1664
[    10.801] 	BnkNumberOfImagePages: 47
[    10.801] 	LinNumberOfImagePages: 47
[    10.801] 	LinRedMaskSize: 5
[    10.801] 	LinRedFieldPosition: 10
[    10.801] 	LinGreenMaskSize: 5
[    10.801] 	LinGreenFieldPosition: 5
[    10.801] 	LinBlueMaskSize: 5
[    10.801] 	LinBlueFieldPosition: 0
[    10.801] 	LinRsvdMaskSize: 0
[    10.801] 	LinRsvdFieldPosition: 0
[    10.801] 	MaxPixelClock: 400000000
[    10.801] Mode: 114 (800x600)
[    10.801] 	RedFieldPosition: 11
[    10.801] 	GreenMaskSize: 6
[    10.801] 	LinRedFieldPosition: 11
[    10.801] 	LinGreenMaskSize: 6
[    10.802] *Mode: 122 (800x600)
[    10.802] 	ModeAttributes: 0xbb
[    10.802] 	WinAAttributes: 0x7
[    10.802] 	WinBAttributes: 0x0
[    10.802] 	WinGranularity: 64
[    10.802] 	WinSize: 64
[    10.802] 	WinASegment: 0xa000
[    10.802] 	WinBSegment: 0x0
[    10.802] 	WinFuncPtr: 0xc0004caf
[    10.802] 	BytesPerScanline: 3328
[    10.802] 	XResolution: 800
[    10.802] 	YResolution: 600
[    10.802] 	XCharSize: 8
[    10.802] 	YCharSize: 14
[    10.802] 	NumberOfPlanes: 1
[    10.802] 	BitsPerPixel: 32
[    10.802] 	NumberOfBanks: 1
[    10.802] 	MemoryModel: 6
[    10.802] 	BankSize: 0
[    10.802] 	NumberOfImages: 23
[    10.802] 	RedMaskSize: 8
[    10.802] 	RedFieldPosition: 16
[    10.802] 	GreenMaskSize: 8
[    10.802] 	GreenFieldPosition: 8
[    10.802] 	BlueMaskSize: 8
[    10.802] 	BlueFieldPosition: 0
[    10.802] 	RsvdMaskSize: 0
[    10.802] 	RsvdFieldPosition: 0
[    10.802] 	DirectColorModeInfo: 0
[    10.802] 	PhysBasePtr: 0xd0000000
[    10.802] 	LinBytesPerScanLine: 3328
[    10.802] 	BnkNumberOfImagePages: 23
[    10.802] 	LinNumberOfImagePages: 23
[    10.802] 	LinRedMaskSize: 8
[    10.802] 	LinRedFieldPosition: 16
[    10.802] 	LinGreenMaskSize: 8
[    10.802] 	LinGreenFieldPosition: 8
[    10.802] 	LinBlueMaskSize: 8
[    10.802] 	LinBlueFieldPosition: 0
[    10.802] 	LinRsvdMaskSize: 0
[    10.802] 	LinRsvdFieldPosition: 0
[    10.802] 	MaxPixelClock: 400000000
[    10.802] Mode: 116 (1024x768)
[    10.802] 	BytesPerScanline: 2048
[    10.802] 	XResolution: 1024
[    10.802] 	YResolution: 768
[    10.802] 	YCharSize: 16
[    10.802] 	BitsPerPixel: 16
[    10.802] 	NumberOfImages: 29
[    10.802] 	RedMaskSize: 5
[    10.802] 	RedFieldPosition: 10
[    10.802] 	GreenMaskSize: 5
[    10.802] 	GreenFieldPosition: 5
[    10.802] 	BlueMaskSize: 5
[    10.802] 	LinBytesPerScanLine: 2048
[    10.802] 	BnkNumberOfImagePages: 29
[    10.802] 	LinNumberOfImagePages: 29
[    10.802] 	LinRedMaskSize: 5
[    10.802] 	LinRedFieldPosition: 10
[    10.802] 	LinGreenMaskSize: 5
[    10.802] 	LinGreenFieldPosition: 5
[    10.802] 	LinBlueMaskSize: 5
[    10.803] Mode: 117 (1024x768)
[    10.803] 	ModeAttributes: 0xbb
[    10.803] 	WinAAttributes: 0x7
[    10.803] 	WinBAttributes: 0x0
[    10.803] 	WinGranularity: 64
[    10.803] 	WinSize: 64
[    10.803] 	WinASegment: 0xa000
[    10.803] 	WinBSegment: 0x0
[    10.803] 	WinFuncPtr: 0xc0004caf
[    10.803] 	BytesPerScanline: 2048
[    10.803] 	XResolution: 1024
[    10.803] 	YResolution: 768
[    10.803] 	XCharSize: 8
[    10.803] 	YCharSize: 16
[    10.803] 	NumberOfPlanes: 1
[    10.803] 	BitsPerPixel: 16
[    10.803] 	NumberOfBanks: 1
[    10.803] 	MemoryModel: 6
[    10.803] 	BankSize: 0
[    10.803] 	NumberOfImages: 29
[    10.803] 	RedMaskSize: 5
[    10.803] 	RedFieldPosition: 11
[    10.803] 	GreenMaskSize: 6
[    10.803] 	GreenFieldPosition: 5
[    10.803] 	BlueMaskSize: 5
[    10.803] 	BlueFieldPosition: 0
[    10.803] 	RsvdMaskSize: 0
[    10.803] 	RsvdFieldPosition: 0
[    10.803] 	DirectColorModeInfo: 0
[    10.803] 	PhysBasePtr: 0xd0000000
[    10.803] 	LinBytesPerScanLine: 2048
[    10.803] 	BnkNumberOfImagePages: 29
[    10.803] 	LinNumberOfImagePages: 29
[    10.803] 	LinRedMaskSize: 5
[    10.803] 	LinRedFieldPosition: 11
[    10.803] 	LinGreenMaskSize: 6
[    10.803] 	LinGreenFieldPosition: 5
[    10.803] 	LinBlueMaskSize: 5
[    10.803] 	LinBlueFieldPosition: 0
[    10.803] 	LinRsvdMaskSize: 0
[    10.803] 	LinRsvdFieldPosition: 0
[    10.803] 	MaxPixelClock: 400000000
[    10.803] *Mode: 123 (1024x768)
[    10.803] 	BytesPerScanline: 4096
[    10.803] 	BitsPerPixel: 32
[    10.803] 	NumberOfImages: 14
[    10.803] 	RedMaskSize: 8
[    10.803] 	RedFieldPosition: 16
[    10.803] 	GreenMaskSize: 8
[    10.803] 	GreenFieldPosition: 8
[    10.803] 	BlueMaskSize: 8
[    10.803] 	LinBytesPerScanLine: 4096
[    10.803] 	BnkNumberOfImagePages: 14
[    10.803] 	LinNumberOfImagePages: 14
[    10.803] 	LinRedMaskSize: 8
[    10.803] 	LinRedFieldPosition: 16
[    10.803] 	LinGreenMaskSize: 8
[    10.803] 	LinGreenFieldPosition: 8
[    10.803] 	LinBlueMaskSize: 8
[    10.804] Mode: 165 (1280x960)
[    10.804] 	ModeAttributes: 0xbb
[    10.804] 	WinAAttributes: 0x7
[    10.804] 	WinBAttributes: 0x0
[    10.804] 	WinGranularity: 64
[    10.804] 	WinSize: 64
[    10.804] 	WinASegment: 0xa000
[    10.804] 	WinBSegment: 0x0
[    10.804] 	WinFuncPtr: 0xc0004caf
[    10.804] 	BytesPerScanline: 2560
[    10.804] 	XResolution: 1280
[    10.804] 	YResolution: 960
[    10.804] 	XCharSize: 8
[    10.804] 	YCharSize: 16
[    10.804] 	NumberOfPlanes: 1
[    10.804] 	BitsPerPixel: 16
[    10.804] 	NumberOfBanks: 1
[    10.804] 	MemoryModel: 6
[    10.804] 	BankSize: 0
[    10.804] 	NumberOfImages: 19
[    10.804] 	RedMaskSize: 5
[    10.804] 	RedFieldPosition: 11
[    10.804] 	GreenMaskSize: 6
[    10.804] 	GreenFieldPosition: 5
[    10.804] 	BlueMaskSize: 5
[    10.804] 	BlueFieldPosition: 0
[    10.804] 	RsvdMaskSize: 0
[    10.804] 	RsvdFieldPosition: 0
[    10.804] 	DirectColorModeInfo: 0
[    10.804] 	PhysBasePtr: 0xd0000000
[    10.804] 	LinBytesPerScanLine: 2560
[    10.804] 	BnkNumberOfImagePages: 19
[    10.804] 	LinNumberOfImagePages: 19
[    10.804] 	LinRedMaskSize: 5
[    10.804] 	LinRedFieldPosition: 11
[    10.804] 	LinGreenMaskSize: 6
[    10.804] 	LinGreenFieldPosition: 5
[    10.804] 	LinBlueMaskSize: 5
[    10.804] 	LinBlueFieldPosition: 0
[    10.804] 	LinRsvdMaskSize: 0
[    10.804] 	LinRsvdFieldPosition: 0
[    10.804] 	MaxPixelClock: 400000000
[    10.804] *Mode: 166 (1280x960)
[    10.804] 	BytesPerScanline: 5120
[    10.804] 	BitsPerPixel: 32
[    10.804] 	NumberOfImages: 9
[    10.804] 	RedMaskSize: 8
[    10.804] 	RedFieldPosition: 16
[    10.804] 	GreenMaskSize: 8
[    10.804] 	GreenFieldPosition: 8
[    10.804] 	BlueMaskSize: 8
[    10.804] 	LinBytesPerScanLine: 5120
[    10.804] 	BnkNumberOfImagePages: 9
[    10.804] 	LinNumberOfImagePages: 9
[    10.804] 	LinRedMaskSize: 8
[    10.804] 	LinRedFieldPosition: 16
[    10.804] 	LinGreenMaskSize: 8
[    10.804] 	LinGreenFieldPosition: 8
[    10.804] 	LinBlueMaskSize: 8
[    10.804] Mode: 119 (1280x1024)
[    10.804] 	YResolution: 1024
[    10.804] 	NumberOfImages: 17
[    10.804] 	RedFieldPosition: 10
[    10.804] 	GreenMaskSize: 5
[    10.804] 	BnkNumberOfImagePages: 17
[    10.804] 	LinNumberOfImagePages: 17
[    10.804] 	LinRedFieldPosition: 10
[    10.804] 	LinGreenMaskSize: 5
[    10.805] 	LinGreenFieldPosition: 5
[    10.805] 	LinBlueMaskSize: 5
[    10.805] 	LinBlueFieldPosition: 0
[    10.805] 	LinRsvdMaskSize: 0
[    10.805] 	LinRsvdFieldPosition: 0
[    10.805] 	MaxPixelClock: 400000000
[    10.805] Mode: 11a (1280x1024)
[    10.805] 	ModeAttributes: 0xbb
[    10.805] 	WinAAttributes: 0x7
[    10.805] 	WinBAttributes: 0x0
[    10.805] 	WinGranularity: 64
[    10.805] 	WinSize: 64
[    10.805] 	WinASegment: 0xa000
[    10.805] 	WinBSegment: 0x0
[    10.805] 	WinFuncPtr: 0xc0004caf
[    10.805] 	BytesPerScanline: 2560
[    10.805] 	XResolution: 1280
[    10.805] 	YResolution: 1024
[    10.805] 	XCharSize: 8
[    10.805] 	YCharSize: 16
[    10.805] 	NumberOfPlanes: 1
[    10.805] 	BitsPerPixel: 16
[    10.805] 	NumberOfBanks: 1
[    10.805] 	MemoryModel: 6
[    10.805] 	BankSize: 0
[    10.805] 	NumberOfImages: 17
[    10.805] 	RedMaskSize: 5
[    10.805] 	RedFieldPosition: 11
[    10.805] 	GreenMaskSize: 6
[    10.805] 	GreenFieldPosition: 5
[    10.805] 	BlueMaskSize: 5
[    10.805] 	BlueFieldPosition: 0
[    10.805] 	RsvdMaskSize: 0
[    10.805] 	RsvdFieldPosition: 0
[    10.805] 	DirectColorModeInfo: 0
[    10.805] 	PhysBasePtr: 0xd0000000
[    10.805] 	LinBytesPerScanLine: 2560
[    10.805] 	BnkNumberOfImagePages: 17
[    10.805] 	LinNumberOfImagePages: 17
[    10.805] 	LinRedMaskSize: 5
[    10.805] 	LinRedFieldPosition: 11
[    10.805] 	LinGreenMaskSize: 6
[    10.805] *Mode: 124 (1280x1024)
[    10.805] 	BytesPerScanline: 5120
[    10.805] 	BitsPerPixel: 32
[    10.805] 	NumberOfImages: 8
[    10.805] 	RedMaskSize: 8
[    10.805] 	RedFieldPosition: 16
[    10.805] 	GreenMaskSize: 8
[    10.805] 	GreenFieldPosition: 8
[    10.805] 	BlueMaskSize: 8
[    10.805] 	LinBytesPerScanLine: 5120
[    10.805] 	BnkNumberOfImagePages: 8
[    10.805] 	LinNumberOfImagePages: 8
[    10.805] 	LinRedMaskSize: 8
[    10.805] 	LinRedFieldPosition: 16
[    10.805] 	LinGreenMaskSize: 8
[    10.805] 	LinGreenFieldPosition: 8
[    10.805] 	LinBlueMaskSize: 8
[    10.806] Mode: 145 (1400x1050)
[    10.806] 	ModeAttributes: 0xbb
[    10.806] 	WinAAttributes: 0x7
[    10.806] 	WinBAttributes: 0x0
[    10.806] 	WinGranularity: 64
[    10.806] 	WinSize: 64
[    10.806] 	WinASegment: 0xa000
[    10.806] 	WinBSegment: 0x0
[    10.806] 	WinFuncPtr: 0xc0004caf
[    10.806] 	BytesPerScanline: 2816
[    10.806] 	XResolution: 1400
[    10.806] 	YResolution: 1050
[    10.806] 	XCharSize: 8
[    10.806] 	YCharSize: 16
[    10.806] 	NumberOfPlanes: 1
[    10.806] 	BitsPerPixel: 16
[    10.806] 	NumberOfBanks: 1
[    10.806] 	MemoryModel: 6
[    10.806] 	BankSize: 0
[    10.806] 	NumberOfImages: 15
[    10.806] 	RedMaskSize: 5
[    10.806] 	RedFieldPosition: 11
[    10.806] 	GreenMaskSize: 6
[    10.806] 	GreenFieldPosition: 5
[    10.806] 	BlueMaskSize: 5
[    10.806] 	BlueFieldPosition: 0
[    10.806] 	RsvdMaskSize: 0
[    10.806] 	RsvdFieldPosition: 0
[    10.806] 	DirectColorModeInfo: 0
[    10.806] 	PhysBasePtr: 0xd0000000
[    10.806] 	LinBytesPerScanLine: 2816
[    10.806] 	BnkNumberOfImagePages: 15
[    10.806] 	LinNumberOfImagePages: 15
[    10.806] 	LinRedMaskSize: 5
[    10.806] 	LinRedFieldPosition: 11
[    10.806] 	LinGreenMaskSize: 6
[    10.806] 	LinGreenFieldPosition: 5
[    10.806] 	LinBlueMaskSize: 5
[    10.806] 	LinBlueFieldPosition: 0
[    10.806] 	LinRsvdMaskSize: 0
[    10.806] 	LinRsvdFieldPosition: 0
[    10.806] 	MaxPixelClock: 400000000
[    10.806] *Mode: 146 (1400x1050)
[    10.806] 	BytesPerScanline: 5632
[    10.806] 	BitsPerPixel: 32
[    10.806] 	NumberOfImages: 7
[    10.806] 	RedMaskSize: 8
[    10.806] 	RedFieldPosition: 16
[    10.806] 	GreenMaskSize: 8
[    10.806] 	GreenFieldPosition: 8
[    10.806] 	BlueMaskSize: 8
[    10.806] 	LinBytesPerScanLine: 5632
[    10.806] 	BnkNumberOfImagePages: 7
[    10.806] 	LinNumberOfImagePages: 7
[    10.806] 	LinRedMaskSize: 8
[    10.806] 	LinRedFieldPosition: 16
[    10.806] 	LinGreenMaskSize: 8
[    10.806] 	LinGreenFieldPosition: 8
[    10.806] 	LinBlueMaskSize: 8
[    10.807] Mode: 175 (1600x1200)
[    10.807] 	ModeAttributes: 0xba
[    10.807] 	WinAAttributes: 0x7
[    10.807] 	WinBAttributes: 0x0
[    10.807] 	WinGranularity: 64
[    10.807] 	WinSize: 64
[    10.807] 	WinASegment: 0xa000
[    10.807] 	WinBSegment: 0x0
[    10.807] 	WinFuncPtr: 0xc0004caf
[    10.807] 	BytesPerScanline: 3200
[    10.807] 	XResolution: 1600
[    10.807] 	YResolution: 1200
[    10.807] 	XCharSize: 8
[    10.807] 	YCharSize: 16
[    10.807] 	NumberOfPlanes: 1
[    10.807] 	BitsPerPixel: 16
[    10.807] 	NumberOfBanks: 1
[    10.807] 	MemoryModel: 6
[    10.807] 	BankSize: 0
[    10.807] 	NumberOfImages: 12
[    10.807] 	RedMaskSize: 5
[    10.807] 	RedFieldPosition: 11
[    10.807] 	GreenMaskSize: 6
[    10.807] 	GreenFieldPosition: 5
[    10.807] 	BlueMaskSize: 5
[    10.807] 	BlueFieldPosition: 0
[    10.807] 	RsvdMaskSize: 0
[    10.807] 	RsvdFieldPosition: 0
[    10.807] 	DirectColorModeInfo: 0
[    10.807] 	PhysBasePtr: 0xd0000000
[    10.807] 	LinBytesPerScanLine: 3200
[    10.807] 	BnkNumberOfImagePages: 12
[    10.807] 	LinNumberOfImagePages: 12
[    10.807] 	LinRedMaskSize: 5
[    10.807] 	LinRedFieldPosition: 11
[    10.807] 	LinGreenMaskSize: 6
[    10.807] 	LinGreenFieldPosition: 5
[    10.807] 	LinBlueMaskSize: 5
[    10.807] 	LinBlueFieldPosition: 0
[    10.807] 	LinRsvdMaskSize: 0
[    10.807] 	LinRsvdFieldPosition: 0
[    10.807] 	MaxPixelClock: 400000000
[    10.807] Mode: 176 (1600x1200)
[    10.807] 	BytesPerScanline: 6400
[    10.807] 	BitsPerPixel: 32
[    10.807] 	NumberOfImages: 5
[    10.807] 	RedMaskSize: 8
[    10.807] 	RedFieldPosition: 16
[    10.807] 	GreenMaskSize: 8
[    10.807] 	GreenFieldPosition: 8
[    10.807] 	BlueMaskSize: 8
[    10.807] 	LinBytesPerScanLine: 6400
[    10.807] 	BnkNumberOfImagePages: 5
[    10.807] 	LinNumberOfImagePages: 5
[    10.807] 	LinRedMaskSize: 8
[    10.807] 	LinRedFieldPosition: 16
[    10.807] 	LinGreenMaskSize: 8
[    10.807] 	LinGreenFieldPosition: 8
[    10.807] 	LinBlueMaskSize: 8
[    10.808] Mode: 1a5 (1920x1080)
[    10.808] 	ModeAttributes: 0xbb
[    10.808] 	WinAAttributes: 0x7
[    10.808] 	WinBAttributes: 0x0
[    10.808] 	WinGranularity: 64
[    10.808] 	WinSize: 64
[    10.808] 	WinASegment: 0xa000
[    10.808] 	WinBSegment: 0x0
[    10.808] 	WinFuncPtr: 0xc0004caf
[    10.808] 	BytesPerScanline: 3840
[    10.808] 	XResolution: 1920
[    10.808] 	YResolution: 1080
[    10.808] 	XCharSize: 8
[    10.808] 	YCharSize: 16
[    10.808] 	NumberOfPlanes: 1
[    10.808] 	BitsPerPixel: 16
[    10.808] 	NumberOfBanks: 1
[    10.808] 	MemoryModel: 6
[    10.808] 	BankSize: 0
[    10.808] 	NumberOfImages: 11
[    10.808] 	RedMaskSize: 5
[    10.808] 	RedFieldPosition: 11
[    10.808] 	GreenMaskSize: 6
[    10.808] 	GreenFieldPosition: 5
[    10.808] 	BlueMaskSize: 5
[    10.808] 	BlueFieldPosition: 0
[    10.808] 	RsvdMaskSize: 0
[    10.808] 	RsvdFieldPosition: 0
[    10.808] 	DirectColorModeInfo: 0
[    10.808] 	PhysBasePtr: 0xd0000000
[    10.808] 	LinBytesPerScanLine: 3840
[    10.808] 	BnkNumberOfImagePages: 11
[    10.808] 	LinNumberOfImagePages: 11
[    10.808] 	LinRedMaskSize: 5
[    10.808] 	LinRedFieldPosition: 11
[    10.808] 	LinGreenMaskSize: 6
[    10.808] 	LinGreenFieldPosition: 5
[    10.808] 	LinBlueMaskSize: 5
[    10.808] 	LinBlueFieldPosition: 0
[    10.808] 	LinRsvdMaskSize: 0
[    10.808] 	LinRsvdFieldPosition: 0
[    10.808] 	MaxPixelClock: 400000000
[    10.808] *Mode: 1a6 (1920x1080)
[    10.808] 	BytesPerScanline: 7680
[    10.808] 	BitsPerPixel: 32
[    10.808] 	NumberOfImages: 5
[    10.808] 	RedMaskSize: 8
[    10.808] 	RedFieldPosition: 16
[    10.808] 	GreenMaskSize: 8
[    10.808] 	GreenFieldPosition: 8
[    10.808] 	BlueMaskSize: 8
[    10.808] 	LinBytesPerScanLine: 7680
[    10.808] 	BnkNumberOfImagePages: 5
[    10.808] 	LinNumberOfImagePages: 5
[    10.808] 	LinRedMaskSize: 8
[    10.808] 	LinRedFieldPosition: 16
[    10.808] 	LinGreenMaskSize: 8
[    10.808] 	LinGreenFieldPosition: 8
[    10.808] 	LinBlueMaskSize: 8
[    10.809] Mode: 1d2 (1366x768)
[    10.809] 	ModeAttributes: 0xbb
[    10.809] 	WinAAttributes: 0x7
[    10.809] 	WinBAttributes: 0x0
[    10.809] 	WinGranularity: 64
[    10.809] 	WinSize: 64
[    10.809] 	WinASegment: 0xa000
[    10.809] 	WinBSegment: 0x0
[    10.809] 	WinFuncPtr: 0xc0004caf
[    10.809] 	BytesPerScanline: 2816
[    10.809] 	XResolution: 1366
[    10.809] 	YResolution: 768
[    10.809] 	XCharSize: 8
[    10.809] 	YCharSize: 16
[    10.809] 	NumberOfPlanes: 1
[    10.809] 	BitsPerPixel: 16
[    10.809] 	NumberOfBanks: 1
[    10.809] 	MemoryModel: 6
[    10.809] 	BankSize: 0
[    10.809] 	NumberOfImages: 21
[    10.809] 	RedMaskSize: 5
[    10.809] 	RedFieldPosition: 11
[    10.809] 	GreenMaskSize: 6
[    10.809] 	GreenFieldPosition: 5
[    10.809] 	BlueMaskSize: 5
[    10.809] 	BlueFieldPosition: 0
[    10.809] 	RsvdMaskSize: 0
[    10.809] 	RsvdFieldPosition: 0
[    10.809] 	DirectColorModeInfo: 0
[    10.809] 	PhysBasePtr: 0xd0000000
[    10.809] 	LinBytesPerScanLine: 2816
[    10.809] 	BnkNumberOfImagePages: 21
[    10.809] 	LinNumberOfImagePages: 21
[    10.809] 	LinRedMaskSize: 5
[    10.809] 	LinRedFieldPosition: 11
[    10.809] 	LinGreenMaskSize: 6
[    10.809] 	LinGreenFieldPosition: 5
[    10.809] 	LinBlueMaskSize: 5
[    10.809] 	LinBlueFieldPosition: 0
[    10.809] 	LinRsvdMaskSize: 0
[    10.809] 	LinRsvdFieldPosition: 0
[    10.809] 	MaxPixelClock: 400000000
[    10.809] *Mode: 1d4 (1366x768)
[    10.809] 	BytesPerScanline: 5632
[    10.809] 	BitsPerPixel: 32
[    10.809] 	NumberOfImages: 10
[    10.809] 	RedMaskSize: 8
[    10.809] 	RedFieldPosition: 16
[    10.809] 	GreenMaskSize: 8
[    10.809] 	GreenFieldPosition: 8
[    10.809] 	BlueMaskSize: 8
[    10.809] 	LinBytesPerScanLine: 5632
[    10.809] 	BnkNumberOfImagePages: 10
[    10.809] 	LinNumberOfImagePages: 10
[    10.809] 	LinRedMaskSize: 8
[    10.809] 	LinRedFieldPosition: 16
[    10.809] 	LinGreenMaskSize: 8
[    10.809] 	LinGreenFieldPosition: 8
[    10.809] 	LinBlueMaskSize: 8
[    10.810] Mode: 1d8 (1600x900)
[    10.810] 	ModeAttributes: 0xbb
[    10.810] 	WinAAttributes: 0x7
[    10.810] 	WinBAttributes: 0x0
[    10.810] 	WinGranularity: 64
[    10.810] 	WinSize: 64
[    10.810] 	WinASegment: 0xa000
[    10.810] 	WinBSegment: 0x0
[    10.810] 	WinFuncPtr: 0xc0004caf
[    10.810] 	BytesPerScanline: 3200
[    10.810] 	XResolution: 1600
[    10.810] 	YResolution: 900
[    10.810] 	XCharSize: 8
[    10.810] 	YCharSize: 16
[    10.810] 	NumberOfPlanes: 1
[    10.810] 	BitsPerPixel: 16
[    10.810] 	NumberOfBanks: 1
[    10.810] 	MemoryModel: 6
[    10.810] 	BankSize: 0
[    10.810] 	NumberOfImages: 16
[    10.810] 	RedMaskSize: 5
[    10.810] 	RedFieldPosition: 11
[    10.810] 	GreenMaskSize: 6
[    10.810] 	GreenFieldPosition: 5
[    10.810] 	BlueMaskSize: 5
[    10.810] 	BlueFieldPosition: 0
[    10.810] 	RsvdMaskSize: 0
[    10.810] 	RsvdFieldPosition: 0
[    10.810] 	DirectColorModeInfo: 0
[    10.810] 	PhysBasePtr: 0xd0000000
[    10.810] 	LinBytesPerScanLine: 3200
[    10.810] 	BnkNumberOfImagePages: 16
[    10.810] 	LinNumberOfImagePages: 16
[    10.810] 	LinRedMaskSize: 5
[    10.810] 	LinRedFieldPosition: 11
[    10.810] 	LinGreenMaskSize: 6
[    10.810] 	LinGreenFieldPosition: 5
[    10.810] 	LinBlueMaskSize: 5
[    10.810] 	LinBlueFieldPosition: 0
[    10.810] 	LinRsvdMaskSize: 0
[    10.810] 	LinRsvdFieldPosition: 0
[    10.810] 	MaxPixelClock: 400000000
[    10.810] *Mode: 1d9 (1600x900)
[    10.810] 	BytesPerScanline: 6400
[    10.810] 	BitsPerPixel: 32
[    10.810] 	NumberOfImages: 7
[    10.810] 	RedMaskSize: 8
[    10.810] 	RedFieldPosition: 16
[    10.810] 	GreenMaskSize: 8
[    10.810] 	GreenFieldPosition: 8
[    10.810] 	BlueMaskSize: 8
[    10.810] 	LinBytesPerScanLine: 6400
[    10.810] 	BnkNumberOfImagePages: 7
[    10.810] 	LinNumberOfImagePages: 7
[    10.810] 	LinRedMaskSize: 8
[    10.810] 	LinRedFieldPosition: 16
[    10.810] 	LinGreenMaskSize: 8
[    10.810] 	LinGreenFieldPosition: 8
[    10.810] 	LinBlueMaskSize: 8
[    10.810]
[    10.810] (II) VESA(0): Total Memory: 768 64KB banks (49152kB)
[    10.810] (II) VESA(0): <default monitor>: Using hsync range of 30.00-81.00 kHz
[    10.810] (II) VESA(0): <default monitor>: Using vrefresh range of 50.00-75.00 Hz
[    10.810] (II) VESA(0): <default monitor>: Using maximum pixel clock of 215.00 MHz
[    10.810] (WW) VESA(0): Unable to estimate virtual size
[    10.810] (II) VESA(0): Not using built-in mode "1400x1050" (no mode of this name)
[    10.810] (II) VESA(0): Not using built-in mode "1280x960" (no mode of this name)
[    10.810] (II) VESA(0): Not using built-in mode "1366x768" (no mode of this name)
[    10.810] (II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
[    10.810] (II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
[    10.810] (II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
[    10.810] (II) VESA(0): Virtual size is 1920x1080 (pitch 1920)
[    10.810] (**) VESA(0): *Built-in mode "1920x1080"
[    10.810] (**) VESA(0): *Built-in mode "1600x900"
[    10.810] (**) VESA(0): *Built-in mode "1280x1024"
[    10.810] (**) VESA(0): Display dimensions: (510, 290) mm
[    10.810] (**) VESA(0): DPI set to (95, 94)
[    10.810] (**) VESA(0): Using "Shadow Framebuffer"
[    10.810] (II) Loading sub module "shadow"
[    10.810] (II) LoadModule: "shadow"
[    10.810] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    10.811] (II) Module shadow: vendor="X.Org Foundation"
[    10.811] 	compiled for 1.20.4, module version = 1.1.0
[    10.811] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    10.811] (II) Loading sub module "fb"
[    10.811] (II) LoadModule: "fb"
[    10.811] (II) Loading /usr/lib/xorg/modules/libfb.so
[    10.811] (II) Module fb: vendor="X.Org Foundation"
[    10.811] 	compiled for 1.20.4, module version = 1.0.0
[    10.811] (II) UnloadModule: "radeon"
[    10.811] (II) Unloading radeon
[    10.811] (II) Loading sub module "int10"
[    10.811] (II) LoadModule: "int10"
[    10.811] (II) Loading /usr/lib/xorg/modules/libint10.so
[    10.811] (II) Module int10: vendor="X.Org Foundation"
[    10.811] 	ABI class: X.Org Video Driver, version 24.0
[    10.811] (II) VESA(0): initializing int10
[    10.811] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[    10.811] (II) VESA(0): VESA BIOS detected
[    10.811] (II) VESA(0): VESA VBE Version 3.0
[    10.811] (II) VESA(0): VESA VBE Total Mem: 49152 kB
[    10.811] (II) VESA(0): VESA VBE OEM: AMD ATOMBIOS
[    10.811] (II) VESA(0): VESA VBE OEM Software Rev: 17.10
[    10.811] (II) VESA(0): VESA VBE OEM Vendor: (C) 1988-2018, Advanced Micro Devices, Inc.
[    10.811] (II) VESA(0): VESA VBE OEM Product: RENOIR
[    10.811] (II) VESA(0): VESA VBE OEM Product Rev: 01.00
[    10.811] (II) VESA(0): virtual address = 0x7f9e708e4000, VGAbase = 0x7f9e73d54000
	physical address = 0xd0000000, size = 50331648
[    10.818] (II) VESA(0): Setting up VESA Mode 0x1A6 (1920x1080)
[    10.818] (II) VESA(0): VBESetVBEMode failed, mode set without customized refresh.
[    10.833] (==) VESA(0): Default visual is TrueColor
[    10.834] (==) VESA(0): Backing store enabled
[    10.834] (==) VESA(0): DPMS enabled
[    10.834] (II) Initializing extension Generic Event Extension
[    10.834] (II) Initializing extension SHAPE
[    10.834] (II) Initializing extension MIT-SHM
[    10.834] (II) Initializing extension XInputExtension
[    10.834] (II) Initializing extension XTEST
[    10.834] (II) Initializing extension BIG-REQUESTS
[    10.834] (II) Initializing extension SYNC
[    10.834] (II) Initializing extension XKEYBOARD
[    10.835] (II) Initializing extension XC-MISC
[    10.835] (II) Initializing extension SECURITY
[    10.835] (II) Initializing extension XFIXES
[    10.835] (II) Initializing extension RENDER
[    10.835] (II) Initializing extension RANDR
[    10.835] (II) Initializing extension COMPOSITE
[    10.835] (II) Initializing extension DAMAGE
[    10.835] (II) Initializing extension MIT-SCREEN-SAVER
[    10.835] (II) Initializing extension DOUBLE-BUFFER
[    10.835] (II) Initializing extension RECORD
[    10.835] (II) Initializing extension DPMS
[    10.835] (II) Initializing extension Present
[    10.835] (II) Initializing extension DRI3
[    10.835] (II) Initializing extension X-Resource
[    10.835] (II) Initializing extension XVideo
[    10.836] (II) Initializing extension XVideo-MotionCompensation
[    10.836] (II) Initializing extension SELinux
[    10.836] (II) SELinux: Disabled on system
[    10.836] (II) Initializing extension GLX
[    10.836] (II) AIGLX: Screen 0 is not DRI2 capable
[    10.898] (II) IGLX: Loaded and initialized swrast
[    10.898] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    10.898] (II) Initializing extension XFree86-VidModeExtension
[    10.898] (II) Initializing extension XFree86-DGA
[    10.898] (II) Initializing extension XFree86-DRI
[    10.898] (II) Initializing extension DRI2
[    10.921] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    10.921] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    10.921] (II) LoadModule: "libinput"
[    10.921] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    10.924] (II) Module libinput: vendor="X.Org Foundation"
[    10.924] 	compiled for 1.20.4, module version = 0.28.2
[    10.924] 	Module class: X.Org XInput Driver
[    10.924] 	ABI class: X.Org XInput driver, version 24.1
[    10.924] (II) Using input driver 'libinput' for 'Power Button'
[    10.924] (**) Power Button: always reports core events
[    10.924] (**) Option "Device" "/dev/input/event3"
[    10.924] (**) Option "_source" "server/udev"
[    10.926] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    10.926] (II) event3  - Power Button: device is a keyboard
[    10.926] (II) event3  - Power Button: device removed
[    10.971] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    10.971] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    10.971] (**) Option "xkb_model" "pc105"
[    10.971] (**) Option "xkb_layout" "es"
[    10.971] (**) Option "xkb_variant" "cat"
[    10.981] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    10.981] (II) event3  - Power Button: device is a keyboard
[    10.981] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    10.981] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    10.981] (II) Using input driver 'libinput' for 'Power Button'
[    10.981] (**) Power Button: always reports core events
[    10.981] (**) Option "Device" "/dev/input/event2"
[    10.981] (**) Option "_source" "server/udev"
[    10.981] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    10.981] (II) event2  - Power Button: device is a keyboard
[    10.981] (II) event2  - Power Button: device removed
[    11.023] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    11.023] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    11.023] (**) Option "xkb_model" "pc105"
[    11.023] (**) Option "xkb_layout" "es"
[    11.023] (**) Option "xkb_variant" "cat"
[    11.023] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    11.023] (II) event2  - Power Button: device is a keyboard
[    11.024] (II) config/udev: Adding input device HD Pro Webcam C920 (/dev/input/event12)
[    11.024] (**) HD Pro Webcam C920: Applying InputClass "libinput keyboard catchall"
[    11.024] (II) Using input driver 'libinput' for 'HD Pro Webcam C920'
[    11.024] (**) HD Pro Webcam C920: always reports core events
[    11.024] (**) Option "Device" "/dev/input/event12"
[    11.024] (**) Option "_source" "server/udev"
[    11.024] (II) event12 - HD Pro Webcam C920: is tagged by udev as: Keyboard
[    11.024] (II) event12 - HD Pro Webcam C920: device is a keyboard
[    11.024] (II) event12 - HD Pro Webcam C920: device removed
[    11.059] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.1/0000:01:00.0/usb1/1-2/1-2:1.0/input/input12/event12"
[    11.059] (II) XINPUT: Adding extended input device "HD Pro Webcam C920" (type: KEYBOARD, id 8)
[    11.059] (**) Option "xkb_model" "pc105"
[    11.059] (**) Option "xkb_layout" "es"
[    11.059] (**) Option "xkb_variant" "cat"
[    11.060] (II) event12 - HD Pro Webcam C920: is tagged by udev as: Keyboard
[    11.060] (II) event12 - HD Pro Webcam C920: device is a keyboard
[    11.060] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event6)
[    11.060] (II) No input driver specified, ignoring this device.
[    11.060] (II) This device may have been added with another device file.
[    11.060] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/event0)
[    11.060] (**) PixArt Lenovo USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[    11.060] (II) Using input driver 'libinput' for 'PixArt Lenovo USB Optical Mouse'
[    11.060] (**) PixArt Lenovo USB Optical Mouse: always reports core events
[    11.060] (**) Option "Device" "/dev/input/event0"
[    11.060] (**) Option "_source" "server/udev"
[    11.060] (II) event0  - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[    11.060] (II) event0  - PixArt Lenovo USB Optical Mouse: device is a pointer
[    11.060] (II) event0  - PixArt Lenovo USB Optical Mouse: device removed
[    11.099] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.4/usb5/5-1/5-1:1.0/0003:17EF:608D.0001/input/input0/event0"
[    11.099] (II) XINPUT: Adding extended input device "PixArt Lenovo USB Optical Mouse" (type: MOUSE, id 9)
[    11.099] (**) Option "AccelerationScheme" "none"
[    11.099] (**) PixArt Lenovo USB Optical Mouse: (accel) selected scheme none/0
[    11.099] (**) PixArt Lenovo USB Optical Mouse: (accel) acceleration factor: 2.000
[    11.099] (**) PixArt Lenovo USB Optical Mouse: (accel) acceleration threshold: 4
[    11.100] (II) event0  - PixArt Lenovo USB Optical Mouse: is tagged by udev as: Mouse
[    11.100] (II) event0  - PixArt Lenovo USB Optical Mouse: device is a pointer
[    11.100] (II) config/udev: Adding input device PixArt Lenovo USB Optical Mouse (/dev/input/mouse0)
[    11.100] (II) No input driver specified, ignoring this device.
[    11.100] (II) This device may have been added with another device file.
[    11.100] (II) config/udev: Adding input device Hewlett-Packard Company HP USB CCID Smartcard Keyboard (/dev/input/event1)
[    11.100] (**) Hewlett-Packard Company HP USB CCID Smartcard Keyboard: Applying InputClass "libinput keyboard catchall"
[    11.100] (II) Using input driver 'libinput' for 'Hewlett-Packard Company HP USB CCID Smartcard Keyboard'
[    11.100] (**) Hewlett-Packard Company HP USB CCID Smartcard Keyboard: always reports core events
[    11.100] (**) Option "Device" "/dev/input/event1"
[    11.100] (**) Option "_source" "server/udev"
[    11.100] (II) event1  - Hewlett-Packard Company HP USB CCID Smartcard Keyboard: is tagged by udev as: Keyboard
[    11.100] (II) event1  - Hewlett-Packard Company HP USB CCID Smartcard Keyboard: device is a keyboard
[    11.100] (II) event1  - Hewlett-Packard Company HP USB CCID Smartcard Keyboard: device removed
[    11.131] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.4/usb5/5-2/5-2:1.0/0003:03F0:0036.0002/input/input1/event1"
[    11.131] (II) XINPUT: Adding extended input device "Hewlett-Packard Company HP USB CCID Smartcard Keyboard" (type: KEYBOARD, id 10)
[    11.131] (**) Option "xkb_model" "pc105"
[    11.131] (**) Option "xkb_layout" "es"
[    11.131] (**) Option "xkb_variant" "cat"
[    11.132] (II) event1  - Hewlett-Packard Company HP USB CCID Smartcard Keyboard: is tagged by udev as: Keyboard
[    11.132] (II) event1  - Hewlett-Packard Company HP USB CCID Smartcard Keyboard: device is a keyboard
[    11.132] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event10)
[    11.132] (II) No input driver specified, ignoring this device.
[    11.132] (II) This device may have been added with another device file.
[    11.132] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event11)
[    11.132] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event7)
[    11.132] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event8)
[    11.132] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event9)
[    11.132] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event5)
[    11.132] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    11.132] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[    11.132] (**) Eee PC WMI hotkeys: always reports core events
[    11.132] (**) Option "Device" "/dev/input/event5"
[    11.132] (**) Option "_source" "server/udev"
[    11.132] (II) event5  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[    11.132] (II) event5  - Eee PC WMI hotkeys: device is a keyboard
[    11.132] (II) event5  - Eee PC WMI hotkeys: device removed
[    11.163] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input5/event5"
[    11.163] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 11)
[    11.163] (**) Option "xkb_model" "pc105"
[    11.163] (**) Option "xkb_layout" "es"
[    11.163] (**) Option "xkb_variant" "cat"
[    11.163] (II) event5  - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[    11.163] (II) event5  - Eee PC WMI hotkeys: device is a keyboard
[    11.164] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[    11.164] (II) No input driver specified, ignoring this device.
[    11.164] (II) This device may have been added with another device file.
[    11.164] (II) config/udev: Adding input device BRLTTY 5.6 Linux Screen Driver Keyboard (/dev/input/event13)
[    11.164] (**) BRLTTY 5.6 Linux Screen Driver Keyboard: Applying InputClass "libinput keyboard catchall"
[    11.164] (II) Using input driver 'libinput' for 'BRLTTY 5.6 Linux Screen Driver Keyboard'
[    11.164] (**) BRLTTY 5.6 Linux Screen Driver Keyboard: always reports core events
[    11.164] (**) Option "Device" "/dev/input/event13"
[    11.164] (**) Option "_source" "server/udev"
[    11.164] (II) event13 - BRLTTY 5.6 Linux Screen Driver Keyboard: is tagged by udev as: Keyboard
[    11.164] (II) event13 - BRLTTY 5.6 Linux Screen Driver Keyboard: device is a keyboard
[    11.164] (II) event13 - BRLTTY 5.6 Linux Screen Driver Keyboard: device removed
[    11.195] (**) Option "config_info" "udev:/sys/devices/virtual/input/input13/event13"
[    11.195] (II) XINPUT: Adding extended input device "BRLTTY 5.6 Linux Screen Driver Keyboard" (type: KEYBOARD, id 12)
[    11.195] (**) Option "xkb_model" "pc105"
[    11.195] (**) Option "xkb_layout" "es"
[    11.195] (**) Option "xkb_variant" "cat"
[    11.195] (II) event13 - BRLTTY 5.6 Linux Screen Driver Keyboard: is tagged by udev as: Keyboard
[    11.195] (II) event13 - BRLTTY 5.6 Linux Screen Driver Keyboard: device is a keyboard
Pathetic!!
@amanda:~$ glxgears
17698 frames in 5.0 seconds = 3539.449 FPS
17993 frames in 5.0 seconds = 3598.534 FPS
18020 frames in 5.0 seconds = 3603.992 FPS
18019 frames in 5.0 seconds = 3603.762 FPS
18063 frames in 5.0 seconds = 3612.523 FPS
17999 frames in 5.0 seconds = 3599.649 FPS
18030 frames in 5.0 seconds = 3605.947 FPS
18004 frames in 5.0 seconds = 3600.735 FPS
18063 frames in 5.0 seconds = 3612.469 FPS
17945 frames in 5.0 seconds = 3588.833 FPS
17872 frames in 5.0 seconds = 3574.306 FPS
17885 frames in 5.0 seconds = 3576.953 FPS
17860 frames in 5.0 seconds = 3571.879 FPS
18006 frames in 5.0 seconds = 3601.125 FPS
#2 2020-10-30 12:13:21
Re: [SOLVED] Beowulf: Xserver native mode in AMD Ryzen 5 Pro 4650G
First of all you should load the latest fimware-linux-nonfree from backports. I guess that is missing, your amd-graphics firmware package is outdated for this new HW.
What do you mean by:
What package is that?
#3 2020-10-30 16:45:06
Klmjab
https://www.asus.com/es/Motherboards-Co … pDesk_BIOS
#4 2020-10-30 16:55:56
Klmjab
I can't install from backports is the same version as the production one. The only way is using Chimaera. And for now I'd rather wait a bit
#5 2020-10-30 16:59:46
blackhole
This is very very new hardware. Build the latest stable kernel from git or kernel.org and ensure you install firmware, if that gives the same result fetch the mainline kernel and do the same.  Don't expect miracles on few months old hardware though...
#6 2020-10-30 17:21:04
The package you need is the firmware-amd-graphics version in the beowulf-backports repository (dated 2020-09-18). You will also need the kernel metapackage from beowulf-backports to keep the newer kernel version updated, there will probably be several fixes for the 4650 soon.
#7 2020-10-30 17:27:33
Installing the 5.8 kernel from backports is a good approach, but only 50% of the job. When you can install the backports kernel, what hinders you to perform the other 50% and enter:
apt -t beowulf-backports install firmware-linux-nonfree
Edith: in the top right hand corner of this page is a button labelled Packages. Open this page, enter firmware-linux-nonfree and look at the output.
#8 2020-10-30 17:29:09
Ahh you mean the bios.
#9 2020-10-30 17:58:06
blackhole
The kernel in backpors has been attemped:
nomodeset effectively prevents that module loading, as it requires KMS, so loading it results in an unbootable or unusable system and not loading it results in X loading the vesa driver. Hence my advice to builld the latest stable (5.9.x) and then onto mainline if needed.
The missing firmware wont make any difference there.
#10 2020-11-01 09:51:52
Klmjab
@Head_on_a_Stick, @Rolfie
No luck, i'll have to wait a while. Installed from backports :
firmware-misc-nonfree
linux-compiler-gcc-8-x86
linux-headers-amd64
linux-image-amd64
firmware-realtek
Running in VESA Mode, native AMD RENOIR support is not yet included in the firmware
Thanks to both of you
@blackhole,
I think recompiling a new kernel does not solve the problem until we have the necessary additional packages(i.e firmware-amd-graphics, firmware-linux-nonfree...)
Thank you very much for your recommendations
Anyway, patience sad
#11 2020-11-01 10:28:31
blackhole
I you get kernel source from kernel.org, you will get the firmware regardless.
#12 2020-11-01 10:40:48
There are Renoir blobs in the backported firmware-amd-graphics package. Have you tried booting with the backported kernel & firmware but without the nomodeset kernel paramater? AMD graphics cards require KMS.
Or just grab the firmware from https://git.kernel.org/pub/scm/linux/ke … ree/amdgpu and copy it to /lib/firmware/amdgpu/.
#13 2020-11-01 12:40:06
If you copy the fimware manually, a manual update-initramfs -u -k all is mandatory.
#14 2020-11-02 13:58:19
Klmjab
It's working!!!! lol lol thank you very much, I had not deleted the "nomodeset" parameter from / etc / default / grub. Thank you.
Although I have noticed that the performance in "glxgears" is identical to that obtained with the VESA driver.I don't understand, years ago, the performance was incredible superior with the proprietary driver... hmm
#15 2020-11-02 19:33:02
Yeah, glxgears isn't a benchmark. Perhaps try https://benchmark.unigine.com/ instead?
Anyway, please mark the thread [SOLVED] to help others who encounter this problem.
#16 2020-11-03 09:07:51
Klmjab
Ok, i'll do. One more thing, anybody knows why Direct Rendering and 2D and 3D Accel is disabled?
[    11.298] (II) LoadModule: "glx"
[    11.299] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.300] (II) Module glx: vendor="X.Org Foundation"
[    11.300] 	compiled for 1.20.4, module version = 1.0.0
[    11.300] 	ABI class: X.Org Server Extension, version 10.0
[    11.300] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[    11.300] 	loading driver: amdgpu
[    11.300] (==) Matched amdgpu as autoconfigured driver 0
[    11.300] (==) Matched ati as autoconfigured driver 1
[    11.300] (==) Matched modesetting as autoconfigured driver 2
[    11.300] (==) Matched fbdev as autoconfigured driver 3
[    11.300] (==) Matched vesa as autoconfigured driver 4
[    11.300] (==) Assigned the driver to the xf86ConfigLayout
[    11.300] (II) LoadModule: "amdgpu"
[    11.300] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[    11.301] (II) Module amdgpu: vendor="X.Org Foundation"
[    11.301] 	compiled for 1.20.3, module version = 18.1.99
[    11.301] 	Module class: X.Org Video Driver
[    11.301] 	ABI class: X.Org Video Driver, version 24.0
[    11.301] (II) LoadModule: "ati"
[    11.301] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[    11.301] (II) Module ati: vendor="X.Org Foundation"
[    11.301] 	compiled for 1.20.4, module version = 19.0.1
[    11.330] (II) LoadModule: "modesetting"
[    11.330] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.330] (II) Module modesetting: vendor="X.Org Foundation"
[    11.330] 	compiled for 1.20.4, module version = 1.20.4
[    11.330] 	Module class: X.Org Video Driver
[    11.330] 	ABI class: X.Org Video Driver, version 24.0
[    11.330] (II) LoadModule: "fbdev"
[    11.330] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    11.331] (II) Module fbdev: vendor="X.Org Foundation"
[    11.331] 	compiled for 1.20.0, module version = 0.5.0
[    11.331] 	Module class: X.Org Video Driver
[    11.331] 	ABI class: X.Org Video Driver, version 24.0
[    11.331] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[    11.331] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.331] (II) FBDEV: driver for framebuffer: fbdev
[    11.331] (II) VESA: driver for VESA chipsets: vesa
[    11.349] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[    11.365] (WW) Falling back to old probe method for modesetting
[    11.365] (WW) Falling back to old probe method for fbdev
[    11.365] (II) Loading sub module "fbdevhw"
[    11.365] (II) LoadModule: "fbdevhw"
[    11.365] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    11.365] (II) Module fbdevhw: vendor="X.Org Foundation"
[    11.365] 	compiled for 1.20.4, module version = 0.0.2
[    11.365] 	ABI class: X.Org Video Driver, version 24.0
[    11.365] (II) AMDGPU(0): Creating default Display subsection in Screen section
[    11.365] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[    11.365] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    11.365] (==) AMDGPU(0): Default visual is TrueColor
[    11.365] (==) AMDGPU(0): RGB weight 888
[    11.365] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[    11.365] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1636)
[    11.365] (II) Loading sub module "fb"
[    11.365] (II) LoadModule: "fb"
[    11.365] (II) Loading /usr/lib/xorg/modules/libfb.so
[    11.366] (II) Module fb: vendor="X.Org Foundation"
[    11.366] 	compiled for 1.20.4, module version = 1.0.0
[    11.366] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.366] (II) Loading sub module "dri2"
[    11.366] (II) LoadModule: "dri2"
[    11.366] (II) Module "dri2" already built-in
[    11.441] (II) Loading sub module "glamoregl"
[    11.441] (II) LoadModule: "glamoregl"
[    11.441] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    11.444] (II) Module glamoregl: vendor="X.Org Foundation"
[    11.444] 	compiled for 1.20.4, module version = 1.0.1
[    11.444] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.456] (II) AMDGPU(0): Refusing to try glamor on llvmpipe
[    11.457] (EE) AMDGPU(0): glamor detected, failed to initialize EGL.
[    11.457] (WW) AMDGPU(0): amdgpu_glamor_pre_init returned FALSE, using ShadowFB
[    11.457] (II) Loading sub module "shadow"
[    11.457] (II) LoadModule: "shadow"
[    11.457] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    11.457] (II) Module shadow: vendor="X.Org Foundation"
[    11.457] 	compiled for 1.20.4, module version = 1.1.0
[    11.457] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.457] (II) AMDGPU(0): KMS Pageflipping: enabled
[    11.457] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[    11.457] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[    11.458] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[    11.463] (II) AMDGPU(0): EDID for output HDMI-A-0
[    11.464] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[    11.464] (II) Loading sub module "ramdac"
[    11.464] (II) LoadModule: "ramdac"
[    11.464] (II) Module "ramdac" already built-in
[    11.464] (II) UnloadModule: "modesetting"
[    11.464] (II) Unloading modesetting
[    11.464] (II) UnloadModule: "fbdev"
[    11.464] (II) Unloading fbdev
[    11.464] (II) UnloadSubModule: "fbdevhw"
[    11.464] (II) Unloading fbdevhw
[    11.464] (II) UnloadModule: "vesa"
[    11.464] (II) Unloading vesa
[    11.466] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[    11.466] (==) AMDGPU(0): DRI3 disabled
[    11.466] (==) AMDGPU(0): Backing store enabled
[    11.466] (WW) AMDGPU(0): Direct rendering disabled
[    11.466] (II) AMDGPU(0): 2D and 3D acceleration disabled
[    11.466] (==) AMDGPU(0): DPMS enabled
[    11.466] (==) AMDGPU(0): Silken mouse enabled
golinux edited at HoaS's suggestion.
#17 2020-11-03 19:01:27
Please use code tags rather than quote tags when posting terminal output, it greatly aids readability.
Do you have any libnvidia-* packages installed? If so then remove them.
aptitude search '?narrow(?installed, libnvidia)'
Reference: https://bugs.freedesktop.org/show_bug.cgi?id=104928 ← that was the third result when I entered the X.Org log errors into a search engine.
This will provide a full rundown of hardware acceleration support on your machine:
glxinfo -B
The command is supplied by the mesa-utils package.
#18 2020-11-04 09:17:01
Klmjab
There's not libnvidia package installed
@amanda:~/Scripts$ dpkg -l | grep libnvidia
@amanda:~/Scripts$ aptitude search '?narrow(?installed, libnvidia)'
@amanda:~/Scripts$
Output of glxinfo -B command
@amanda:~$ cat glxinfo.txt
name of display: :0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: VMware, Inc. (0xffffffff)
    Device: llvmpipe (LLVM 7.0, 128 bits) (0xffffffff)
    Version: 18.3.6
    Accelerated: no
    Video memory: 31486MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 3.3
    Max compat profile version: 3.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.0
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 7.0, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 18.3.6
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 3.1 Mesa 18.3.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 18.3.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
In https://bugs.freedesktop.org/show_bug.cgi?id=104928 there are two users that who recommend one to uninstall the nvidia libraries (this is not the case) and the other to update the libegl-mesa0 libraries with those from the experimental repository, this last option scares me a bit sad
#19 2020-11-04 17:29:07
You have no hardware rendering at all. Perhaps blackhole is right about the kernel.
We can take a look at the kernel ring buffer, that might have some clues. Run this command and post the URL it returns:
# dmesg | curl -F 'f:1=<-' ix.io
#20 2020-11-04 18:27:38
Klmjab
@amanda:~$ sudo dmesg | curl -F 'f:1=<-' ix.io
[url]http://ix.io/2D1c[/url]
#21 2020-11-04 18:56:11
Well the Renoir firmware is loaded so it must be the Mesa version.
MX Linux have backported the Mesa packages to a beowulf-compatible base so you could try those:
http://forums.debian.net/viewtopic.php?f=16&t=146083
#22 2020-11-04 20:28:57
To encourage you, have a read of this thread: https://dev1galaxy.org/viewtopic.php?id=3811
#23 2020-11-05 11:53:25
Klmjab
Solved !!
@HOAS,
Thank you for your suggestion!
@Rolfie
thanks for the encouragement!
Finally:
@amanda:~$ glxinfo -B
name of display: :0
    Vendor: X.Org (0x1002)
    Device: AMD RENOIR (DRM 3.38.0, 5.8.0-0.bpo.2-amd64, LLVM 10.0.0) (0x1636)
    Version: 20.1.8
    Accelerated: yes
    Video memory: 512MB
    Unified memory: no
    Max core profile version: 4.6
    Max compat profile version: 4.6
    Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
    VBO free memory - total: 340 MB, largest block: 340 MB
    VBO free aux. memory - total: 3043 MB, largest block: 3043 MB
    Texture free memory - total: 340 MB, largest block: 340 MB
    Texture free aux. memory - total: 3043 MB, largest block: 3043 MB
    Renderbuffer free memory - total: 340 MB, largest block: 340 MB
    Renderbuffer free aux. memory - total: 3043 MB, largest block: 3043 MB
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 512 MB
    Total available memory: 3584 MB
    Currently available dedicated video memory: 340 MB
OpenGL vendor string: X.Org
OpenGL renderer string: AMD RENOIR (DRM 3.38.0, 5.8.0-0.bpo.2-amd64, LLVM 10.0.0)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.1.8
OpenGL core profile shading language version string: 4.60
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.1.8
OpenGL shading language version string: 4.60
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.1.8
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
List of installed/updated packages from MX Linux AHS Repo
@amanda:~$ dpkg -l | grep mx
ii  firmware-amd-graphics                 20200918-1~mx19+1                            all          Binary firmware for AMD/ATI graphics chips
ii  firmware-linux-nonfree                20200918-1~mx19+1                            all          Binary firmware for various drivers in the Linux kernel (meta-package)
ii  firmware-misc-nonfree                 20200918-1~mx19+1                            all          Binary firmware for various drivers in the Linux kernel
ii  firmware-realtek                      20200918-1~mx19+1                            all          Binary firmware for Realtek wired/wifi/BT adapters
ii  libdrm-amdgpu1:amd64                  2.4.102-1~mx19ahs+1                          amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-common                         2.4.102-1~mx19ahs+1                          all          Userspace interface to kernel DRM services -- common files
ii  libdrm2:amd64                         2.4.102-1~mx19ahs+1                          amd64        Userspace interface to kernel DRM services -- runtime
ii  libegl-mesa0:amd64                    20.1.8-1~mx19ahs+1                           amd64        free implementation of the EGL API -- Mesa vendor library
ii  libegl1-mesa:amd64                    20.1.8-1~mx19ahs+1                           amd64        transitional dummy package
ii  libgbm1:amd64                         20.1.8-1~mx19ahs+1                           amd64        generic buffer management API -- runtime
ii  libgl1-mesa-dri:amd64                 20.1.8-1~mx19ahs+1                           amd64        free implementation of the OpenGL API -- DRI modules
ii  libglapi-mesa:amd64                   20.1.8-1~mx19ahs+1                           amd64        free implementation of the GL API -- shared library
ii  libglx-mesa0:amd64                    20.1.8-1~mx19ahs+1                           amd64        free implementation of the OpenGL API -- GLX vendor library
ii  libllvm10:amd64                       1:10.0.0-4~mx19+1                            amd64        Modular compiler and toolchain technologies, runtime library
ii  libvulkan1:amd64                      1.2.148.1-1~mx19ahs+1                        amd64        Vulkan loader library
ii  libx11-xcb1:amd64                     2:1.6.12-1~mx19ahs+1                         amd64        Xlib/XCB interface library
ii  libxatracker2:amd64                   20.1.8-1~mx19ahs+1                           amd64        X acceleration library -- runtime
ii  linux-compiler-gcc-8-x86              5.8.14-1~mx19+2                              amd64        Compiler for Linux on x86 (meta-package)
ii  linux-kbuild-5.8                      5.8.14-1~mx19+2                              amd64        Kbuild infrastructure for Linux 5.8
ii  mesa-va-drivers:amd64                 20.1.8-1~mx19ahs+1                           amd64        Mesa VA-API video acceleration drivers
ii  mesa-vdpau-drivers:amd64              20.1.8-1~mx19ahs+1                           amd64        Mesa VDPAU video acceleration drivers
ii  mesa-vulkan-drivers:amd64             20.1.8-1~mx19ahs+1                           amd64        Mesa Vulkan graphics drivers
ii  mx19-archive-keyring                  2019.5.31                                    all          GnuPG archive keys of the MX-19 Linux archive
#24 2021-03-22 11:41:37
devujan
A quick reply to this thread.
To me stability, and low administrative workload generation is a target I pursue with every laptop I configure for my clients (family mostly). Also privacy and usability are important to me.
The last 30 years I learned that the operating system should ripe and age with the hardware in use - to keep administration effort on the lowest possible level.
I recently got a Tuxedo "Aura 15"  (a Clevo OEM)  with AMD Ryzen 4700U and thus RENOIR graphic integrated.
As there is no (at least I didn't find it) ISO for chimera I booted a beowulf 3.1 iso and installed a fde chimera on it.
I painstakingly installed all the necessary firmware packages and the graphics just worked out of the box.
Ok chimera is testing ... (but a lot better the the preinstalled Ubuntu Frankendebian).
I only found that the KDE akonadi was even more crap than expected ('apt-mark hold "akonadi* packages"' helps to keep that uninstalled stuff out)- but I guess the overall workload to keep that laptop patched and functional the next 5 years is significantly lower than starting with (a heavily patched MX-Franken-)beowulf - and because of that reinstalling a chimera once it is officially released.
Your mileage may vary.
I just want to point out installing minimal beowulf and migrating it to chimera is an option for that brand new hardware.
