#1 2020-10-27 23:02:49
cretsiah
AMD-VI Page Fault device 2 and wifi
quick rant/story
Ok so Im here from Linux Mint, I tried the only one that I could get working effectively with wifi was LM XFCE version in compat mode, I think the Cinnamon Main and Debian suffer from the same problem when it comes to wifi.
trying to move away from win10
rant/story over
system:
AMD FX 8320 eight core black edition 125watt
Gigabyte 970A-D3P v2 motherboard bios v3 (FC)
Radeon RX 550 4gig
adata 800 SSD 500gig MBR mode
Western Digital HDD 1 TB MBR mode
Toshiba HDD 1 TB MBR mode
USB wifi adapter MediaTek 2.4ghz/ 5ghz
Gaming Headset G933
Under the LM distro's keep getting
I believe this is related to the via technologies USB 3 controller
because when you punch up
lsusb
i get returned with
USB 1.1 Linux Foundation
USB 2 Linux Foundation
but nothing for USB 3 (is there a USB 3 Linux Foundation) controller ?
will the DeVuan Live usb or the desktop installer, auto setup the wifi adapter during installer?
I know Devuan is not really meant for noobs but it is that or Artix Linux and I have played with aptitude / synaptic more than pacman.
does .gdeb packages work on devuan?
intended install type is
drive 0
- win10 120gig
- Devuan / 120gig
drive 1
- windows stuff
drive 2
- Devuan /home
sorry if my questions are all over the place
and i did read head-on-a-sticks suggestion about making sure backports were on from this thread
https://dev1galaxy.org/viewtopic.php?id=3881
#2 2020-10-28 05:23:28
Re: AMD-VI Page Fault device 2 and wifi
Yes there is a usb3.0 hub.
lsusb ... (snipette)
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
You may require a newer "kernel" and "firmware" from backports for the devices of your motherboard.
This usb3 read out from my box is running on kernel
5.8.0-0.bpo.2-amd64 #1 SMP Debian 5.8.10-1~bpo10+1 (2020-09-26) x86_64 GNU/Linux
Also the microcode for AMD64 processors may help too.
I think you can put the module for wifi on a separate memory stick for use during the install process but I can't remember how I did it when I was using Devuan ascii2.1 and upgrading to Devuan Beowulf3.0.
I also used the git download and install linux-firmware method shared in the other post.
I hope this helps you.
#3 2020-10-30 18:00:25
Can you be more specific? An exact model designation would be nice. Or you could open a terminal and run dmesg -w then plug the device in and post any new terminal output that appears afterwards.
I think that error message is related to IOMMU rather than your wireless device. Try adding iommu=soft as a kernel command line parameter to remove those errors: https://askubuntu.com/questions/805008/ … page-fault
lsusb
i get returned with
Please post the full, exact output of lsusb (with the device plugged in). Thanks.
You probably just need firmware for it but we need to know the chip ID first.
#4 2020-12-27 13:48:16
cretsiah
@Head_on_a_Stick
sorry about the delay
this is what Devuan KDE Bewoulf says about wifi device
Manufacturer: MediaTek
Vendor ID: 0xe8d
Product ID: 0x7610
Revision:0.00
after having moved adapter to a usb 2 port, Bewoulf found and ran wifi.
now to work on the other issue's
- missing usb 3 drivers
susb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 003: ID 045e:07f8 Microsoft Corp. Wired Keyboard 600 (model 1576)
Bus 007 Device 002: ID 04d9:fa56 Holtek Semiconductor, Inc.
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 003: ID 046d:0a5b Logitech, Inc. G933 Wireless Headset Dongle
Bus 005 Device 002: ID 046d:0a5d Logitech, Inc.
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 0e8d:7610 MediaTek Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
