#1 2020-10-19 01:26:45
ve1drg
Execuable files not running...
I am operating ASCII software of Devuan.
And I am getting this error:
cannot execute binary file: Exec format error
when I try to execute a file I need to run,.
I cant find a fix?
Any help?
#2 2020-10-19 08:49:34
xinomilo
Unknown
Re: Execuable files not running...
more info perhaps... (?) what file?  ascii 64/32 ?
#3 2020-10-19 13:03:07
ve1drg
asc11 64.  And its any file I make up and make bootable. It wont work.
I get this error.
What a life, eh?  Must be a fix out there somewhere.
#4 2020-10-19 13:22:16
xinomilo
Unknown
still not helping to find a fix.
post here the output of :
uname -a
file /path/to/executable_file
and how you try to run it ...
#5 2020-10-19 15:08:33
Make bootable? Or did you mean "make executable"?
Are you trying to boot a 64-bit OS on a 32-bit system?
#6 2020-10-19 16:23:46
PedroReina
Quite sure smile Keep sending us information.
#7 2020-10-19 18:45:54
ve1drg
uname -a
Here is what uname -a shows:
Linux ve1drg 4.9.0-13-amd64 #1 SMP Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
And the file is any file I decide to make up and execute... or boot as I said.  No file will run or execute.  I get that error with any file that I set up and give it a chmod value of 755.  Chown is ve1drg.ve1drg
Hope this helps..
#8 2020-10-19 19:31:53
^ This is far too vague. Please give us a concrete example and include the entire contents of the file along with the exact method(s) you used to "run or execute" it. Also provide the output of the requested file command when run on your example executable.
#9 2020-10-19 23:10:25
ve1drg
OK.  Here is the file I would like to execute.  Or run.  Or whatever..
It is the file called linbpq found in the g8bpq directory. I can't post it here because I dont know how to attach it to this message.  Must be a way. But cant figure it out.
It is an executable file and is normally run using ./linbpq.
Of course when that file runs it brings up a G8BPQ BBS.
I even tried using 'source linbpq'  and that gave me the same error.
The file will not run.
But a few days ago it ran just fine. I had that program on another distribution (Jessie) and it worked there.
Maybe Ascii is just too tough for this little file, eh?
#10 2020-10-19 23:17:18
ve1drg
Just further to the above....here is what I see when I run this file.  It is a binary file.
bash: source: linbpq: cannot execute binary file
-rwxr-xr-x 1 root root 3487264 Oct  9 10:58 linbpq
#11 2020-10-20 05:35:21
It is rather frustrating that we have to ask this three times but can we please see the output of
file linbpq
And also explain from where you obtained this mysterious binary file.
EDIT: the output of this command would also be useful:
ldd linbpq
#12 2020-10-20 11:38:49
ComputerBob
Please forgive me if I'm asking a stupid question (it wouldn't be the first time), but does that line mean that the file is owned/must be run by root?
ComputerBob - Making Geek-Speak Chic (TM)
ComputerBob.com -6,000 Posts and over 23 Million Views since 1998
Help! (off-topic)
I Lost My Sports Car!
#13 2020-10-20 12:03:03
sgage
Nope, the 'x' at the end means that 'others' have execution privileges. rwxr-xr-x means owner has full privileges, group has read/execute, and other has read/execute.
#14 2020-10-20 12:40:50
xinomilo
Unknown
if the below is what you're trying to run, its 32bit only.. so install a ascii i386 (could also do that in a vm) and retry.. it won't run on x86_64.
https://www.cantab.net/users/john.wisem … INBPQ.html
#15 2020-10-20 17:31:09
bbatten
@ve1drg: Do you understand what you're being asked to do?
Enter "file linbpq"  at the command line prompt and post output here.
#16 2020-10-20 17:32:49
ve1drg
file linbpq
ldd linbpq
root@ve1drg:/BPQbbs/ve3bwm# ldd linbpq
    not a dynamic executable
??? what does that mean?  Other than,  is this why the program is not executable..
#17 2020-10-20 17:34:50
ve1drg
root@ve1drg:/BPQbbs/ve3bwm# file linbpq
linbpq: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=4634defa908c142e8292a701a0babd769a381cea, not stripped
Does this say that this is a 32 bit file?
I just downloaded it. Saying this was a 64bit file??
How..  how can I run a 32 bit file in a 64 bit machine?
#18 2020-10-20 17:54:53
Finally! That was like getting blood out of a stone roll
Use a VM or multiarch but for the latter you will need to know which 32-bit libraries are needed to run the executable so see https://superuser.com/questions/908377/ … ont-report for a way to get ldd working so you can find those.
#19 2020-10-20 18:03:54
ve1drg
I tried that line:
RTLDLIST="/lib/ld-linux.so.2 /lib64/ld-linux-x86-64.so.2 /libx32/ld-linux-x32.so.2"
and with the 32 bit change:
RTLDLIST="/lib32/ld-linux.so.2 /lib64/ld-linux-x86-64.so.2 /libx32/ld-linux-x32.so.2"
No change.
Those / that file will still not run,
#20 2020-10-20 18:19:45
So did you enable multiarch and install the 32-bit version of the libc-bin package? Those lines won't work if the files it references are not present in your system.
#21 2020-10-20 21:20:27
ComputerBob
Thank you! That makes sense!  wink
Help! (off-topic)
#22 2020-10-21 12:32:41
ve1drg
linbpq: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=0d6a50412cd7cfe0f477184bfb233016e360f5e4, not stripped
#23 2020-10-21 19:19:41
bbatten
Good. Now what is the output of "uname -m"? On my machine:
[6] bryan: uname -m
x86_64
[7] bryan:
If it turns out you have a 64 bit machine like mine, then I think you need to either get a 64 bit version of your file or install a multiarch capability - i.e the files and libraries needed to support 32 bit code on a 64 bit machine.
Good luck
