#1 2020-10-12 17:01:44
kapqa
Changing from amd to nvidia card
alright, now i have everything installed, and next problem comes up:
how can i properly switch to nvidia card?
i have two monitors setup, and triple boot /(devuan , windows 7, ubuntu 18.04).
after changing from amd to nvidia card, only devuan seems to boot.
now, i suppose, i need to just to deinstall the firmware-amd-graphics on devuan and install nvidia driver package?
but what to do on ubuntu, if it would not boot properly, and on windows?
do i need to put the other card back in and preopare already the machine with the nvidia drivers in place?
thank you.
EDIT: i understand that the nouveau driver functions also so as it is,
but i tried with display manager on xfce to change the monitor setup, and the result was that i could not longer access most part of the screens that seemed somhow frozen and could only be maneauvred by clicking in the leftover part, practically clicking blind over the place -
#2 2020-10-12 17:07:51
kapqa
Re: Changing from amd to nvidia card
the graphics is rtx 1650
 lspci -nn | egrep -i "3d|display|vga"
07:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:1f82] (rev a1)
and debian wiki says
The proprietary "NVIDIA Accelerated Linux Graphics Driver" provides optimized hardware acceleration of OpenGL and Vulkan applications through either Xorg or Wayland. It is a binary-only driver requiring a Linux kernel module for its use.
Multiple precompiled driver versions are available for Debian 10 "Buster":
    Version 450.66 (supported devices)
        Supports Kepler, Maxwell, Pascal, and all current Turing GPUs. Supports Vulkan 1.2 and OpenGL 4.6.
        Note that 450.66 is currently only available in buster-backports.
#3 2020-10-12 17:24:32
blackhole
Banned
That kind of output from lspci usually inidicates unsupported hardware.
You'll need the proprietary driver from backports and likely a new kernel as well... as this is recent hardware.
#4 2020-10-12 17:55:45
You should probably open a new thread for the NVIDIA card, it is off-topic for this one.
If you use the "report" button on your post and ask nicely @admin might split it out for you.
#5 2020-10-12 19:54:07
kapqa
@head_on_a_Stick, thanks, good suggestion.
@blackhole, yes, probably unsupported, as i just installed devuan beowulf anew (with nividia 1650)
and it would not go into "X"; so i was greeted with terminal window instead;
installing
nvidia-driver
does not resolve, well at least it gives a graphical desktop, but blocks the terminal thereafter with "nvidia-persistenced".
if i need backports, i will try those.
EDIT: tried also installing the drivers from bakcports,
i am still getting "nvidia-persistenced" error.
please someone write a small guide on how to properly install nvidia-drivers, not just the legacy ones.
#6 2020-10-12 22:08:24
Marjorie
Unless you want to use CUDA you don't need nvidia-persistenced. Delete or disable it.
I also have a fix for one of the problems you can have with it. Of course, your problem may be different.
See https://dev1galaxy.org/viewtopic.php?pid=24457#p24457
#7 2020-10-13 03:43:59
I've just put this together, I hope it helps :-)
Installing nVidia drivers from nVidia.com .run blob.
The first thing I do after installing a new kernel and headers (and sometimes the source too)
and any firmware packages you may require for your motherboard/chipset maker is
remove any nvidia packages... see Majorie's instuctions above to do that. Thank you Majorie :-)
get the nvidia binary blob...go to:
https://www.nvidia.com/Download/index.aspx?lang=en-us
(I'm in Australia, so US english is close to the language we use here ;-) ymmv
The latest one I have is: NVIDIA-Linux-x86_64-450.80.02.run
I have a GeForce GTX 1060 grapgics card
I'm running kernel version from Devuan 3.0 Beowulf back ports (bpo)
uname -a : Linux GamesBox 5.8.0-0.bpo.2-amd64 #1 SMP Debian 5.8.10-1~bpo10+1 (2020-09-26) x86_64 GNU/Linux
edit grub to nullify the nouveau driver (kernel module) and set the screen size so it's workable with out a gui.
I do that by editing grub at boot,
you will have to be quick to interupt the automagic booting of the system.
Just use the arrow key to interup it.
with the down arrow key (v) goto:
*Advanced Options for Devuan GNU/Linux
and hit enter
use the arrow again to select "your kernel (recovery mode)" line, mine is,
Devuan GNU/Linux, with Linux 5.8.0-0.bpo.2.amd64 (recovery mode)
and hit "e" to edit
Next thing you should see is the grub file... use the arrow key to move down to the "linux" line
it says something like this but your UUID and kernel name may be different,
linux	/boot/vmlinuz-5.8.0-0.bpo.2-amd64 root=UUID=c2e432ce-5ac7-46f7-a00d-1982f970d1d1 ro single
Add these commands to the end of the line:
nokmsboot nouveau.modeset=0 vga=794
then press ctrl-x or F10 to boot
login as root, type in the password and hit enter
ctrl-d will just let the system keep booting, so watch out for that.
cd to the directory where you saved the nvidia .run file
type
sh NVIDIA-Linux-x86_64-450.80.02.run
and hit enter and follow the directions.
reboot the system and hopefully you should be presented with your desktop gui.
note: I use this backup of the grub(2) default file in /etc after the system is running to keep the settings:
the file, /etc/default/grub
add these commands to the line GRUB_CMDLINE_LINUX_DEFAULT=
GRUB_CMDLINE_LINUX_DEFAULT="nokmsboot nouveau.modeset=0 console=tty12 vga=794"
you may not need the console=tty12 part, but I use it to see what's going on if something breaks.
rsync -avh /home/glenn/local/other/backup/backup-etc-sys/etc/default/grub /etc/default/
chown root:root /etc/default/grub
chmod a+rx /etc/default/grub
update-grub
any questions or errors? please post back here.
regards Glenn
#8 2020-10-13 06:42:51
Note that the kernel module will have to be rebuilt manually every time the kernel is updated. The nvidia-driver package in the repositories will do this automatically via DKMS (v450.66 is currently available from beowulf-backports).
#9 2020-10-13 11:36:11
The nvidia installer gives you an option to build with dkms support. :-) to aid when upgrading the kernel.
#10 2020-11-04 18:08:20
kapqa
@GlennW , thank you, i tried your method, and it brought me a functioning desktop. However there were some error messages, one notably
WARNING: Unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg-config and the libglvnd development libraries installed, or specify a path with --glvnd -egl -config-path.
#11 2021-09-08 01:15:15
install libglvnd-dev
