#1 2020-10-13 11:21:25
kapqa
Sony Camera not recognized
Hello ,
i would like to transfer the pictures from Camera Sony W830 to the laptop.
However, the PTP/MTP is not being recognized by Devuan 3.0 Beowulf and the Camera would not show up as an external storage (it should show from 30 to 32GB)
What am i doing wrong?
#2 2020-10-13 11:23:11
kapqa
Re: Sony Camera not recognized
i have upgraded the system on the laptop from Ascii to Beowulf, but that should not make a difference in recognizing the Camera;
the update process proceeded without any errors,
Thank you very much.
#3 2020-10-13 11:45:41
PedroReina
Have you tried gphoto2 -P?
#4 2020-10-13 12:05:46
kapqa
thank you,
i did not know this program,
and i don't like to download all fotos as it does now through terminal.
it like to show up the camera in file manager and select the photos myself.
#5 2020-10-13 12:24:45
Perhaps jmtpfs works for you.
#6 2020-10-14 12:31:10
kapqa
hmm, strange, the sony mp4 player gets recognized and is shown in file manager xfce , the camera however not.
will do some more testing.
thanks for your help.
#7 2020-10-14 14:36:06
Perhaps it needs exfat-fuse (and maybe exfat-utils) whcih I don't think are installed by default.
#8 2020-10-14 16:29:39
Isn't that camera an USB device? I would suggest first of all to check on the console if and how the camera re. its memory stick? shows up when plugged in. lsusb
Have you tried all available USB ports on the laptop?
#9 2020-10-14 17:40:57
kapqa
yes, both devices are usb-connected, and have proprietary cables (from what i understand > typically sony)
maybe i am doing something wrong wh, but i think the camera is instantly recognized on ubuntu with the same procedure.
the walkman has only internal flash installed (but can handle also additional micro-SD-card up to 2TB or maybe even more)
the camera has a 32gb old sd-card (the bigger ones) and probably no flash memory.
exfat-fuse and exfat-utils
seem already manually installed (maybe leftover from ascii installation?)
laptop T400 has 3 usb ports, it does not make a difference if ports are switched, camera not shown in filemanager.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 002: ID 17ef:1003 Lenovo Integrated Smart Card Reader
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 17ef:1004 Lenovo Integrated Webcam
Bus 001 Device 003: ID 054c:094b Sony Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
#10 2020-10-14 18:29:54
One topic per thread only please.
When I connect my Panasonic (don't own a Sony, never had) to the usb port I get a similar output. The memory isn't shown with lsusb.
Bus 002 Device 008: ID 04da:2372 Panasonic (Matsushita) Lumix Camera (Storage mode)
When I connect my camera I have to select a mode, either Pict Bridge (PTP) or PC. I only use the later. What about the Sony?
When the camera is connected with the correct mode selected, the SD memory card shows up in lsblk:
sdh                   8:112  1 119,1G  1 disk
└─sdh1                8:113  1 119,1G  1 part  /media/rolf/3663-6361
and is available on my Mate desktop as 128GB device. Caja shows "MATSHITA DC-TZ91: Datenträger 128 GB". I can copy images from the card to my home drive then as desired.
What is happening on your laptop? Is the memory shown in lsblk?
Edith: just tried the PTP mode for curiosity. Hey it also works in my configuration, same drive is present in lsblk and on the Caja screen, just named slightly different.
#11 2020-10-14 20:00:38
kapqa
sorry, but the camera shows only "USB-Mode   PTP/MTP"
                                                      "Speicherkarte - Wiederg. per "Wiedergabe" - Tastendruck" eg. "Memorycard - Playback via "Play" - Buttonpress"
if playbutton is pressed, the only think happens is that the internal display on the camera is being changed from the above message/statusscreen to the active fotomanager on the camera, eg. the photos are being displayed on-cam.
lsblk is giving the following output
lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 111.8G  0 disk
├─sda1   8:1    0 108.9G  0 part /
├─sda2   8:2    0     1K  0 part
└─sda5   8:5    0   2.9G  0 part [SWAP]
sr0     11:0    1  1024M  0 rom
will check the next days on ubuntu after iget my cmputer back to see if it behaves there differently, but i believe so.
#12 2020-10-14 20:44:46
That device, 054c:094b, does not appear to yet be listed among known devices, but it might work by identifying it explicitly for jmtpfs, i.e. if your mount point is /media/camera you'd use:
jmptfs -d 001,003 /media/camera
#13 2020-10-14 21:17:44
kapqa
jmtpfs -d 001,003 /media/camera
No mtp devices found.
#14 2020-10-16 03:06:58
ok ... seems to lead out of my comfort zone. The product id (0x094b) is not listed in http://www.linux-usb.org/usb.ids, and afaict it's also not among the entries for libmtp (http://libmtp.sourceforge.net/).
So it appears that making it work is slightly more than plug-n-play. I'm not aware of any possible shortcut, but maybe someone else knows better.
#15 2020-10-16 08:37:43
PedroReina
I downloaded the manual from Sony:
https://www.sony.com/electronics/suppor … 14571M.pdf
I can read on page 27 that the camera has around 27 MB of internal memory.
Could work for you just read the files from the sd-card? (As a workaround).
#16 2020-10-16 14:28:53
Magnus
#17 2020-10-16 18:16:33
When I summarize the feedback received on lsusb and lsblk, the camera is found on the usb subsystem, but the product id seems to be unknown. Contrary to my Panasonic which is working fine there is no sign of any memory. Looks like its not recognised at all. Strange for a product that is more that 6 years on the market. On the other hand I am not familiar with Sony products, I avoid them whereever I can.
@OP: when I read what you wrote in your first posts it is very interpretable if the camera worked under ASCII. I would assume when it worked under ASCII it also should under Beowulf. Buuuuut: we have the proof that there is no memory recognised. Very strange.
So  please give Magnus' suggestion a try. Maybe a dedicated udev rule fixes the issue (have you optimised something?).
#18 2020-10-17 08:17:05
Magnus
It seems that older hardware can be removed when "upgrades" occur. I came across this when a scanner I have stopped working. Then I had to write my own udev rule.
### /etc/udev/rules.d/60-canon-lide-25.rules
# Canon CanoScan LiDE25
ATTRS{idVendor}=="04a9", ATTRS{idProduct}=="2220", ENV{libsane_matched}="yes"
#19 2020-10-19 20:00:34
kapqa
i just checked on my older T60 running debian wheezy, and there the camera is perfectly recognized.
https://ibb.co/9rMKj8T
#20 2020-10-20 14:35:48
PedroReina
Please note that your Debian Wheezy is using gphoto2 to access to the camera. May be you are missing some package related with gphoto2 in your new box.
#21 2020-10-21 20:34:22
kapqa
Thank you Pedro, i have seen that this gphoto2 is active with Camera on Wheezy, too.
However, on Devuan it seems the package is not enough.
sudo apt install gphoto2*
[sudo] password for rich:
Building dependency tree
Note, selecting 'gphoto2' for glob 'gphoto2*'
gphoto2 is already the newest version (2.5.20-3).
EDIT:
after installing with
sudo apt install libgphoto2*
Note, selecting 'libgphoto2-port10' for glob 'libgphoto2*'
Note, selecting 'libgphoto2-port12' for glob 'libgphoto2*'
Note, selecting 'libgphoto2-6' for glob 'libgphoto2*'
Note, selecting 'libgphoto2-2-dev' for glob 'libgphoto2*'
Note, selecting 'libgphoto2-dev-doc' for glob 'libgphoto2*'
Note, selecting 'libgphoto2-l10n' for glob 'libgphoto2*'
Note, selecting 'libgphoto2-dev' for glob 'libgphoto2*'
libgphoto2-6 is already the newest version (2.5.22-3).
libgphoto2-6 set to manually installed.
libgphoto2-l10n is already the newest version (2.5.22-3).
libgphoto2-l10n set to manually installed.
libgphoto2-port12 is already the newest version (2.5.22-3).
libgphoto2-port12 set to manually installed.
  libexif-dev libexif-doc
  libexif-dev libexif-doc libgphoto2-dev libgphoto2-dev-doc
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
the camera is recognized and photos come up!
thank you very much - it seems however that when installing
gphoto2
with "sudo apt install gphoto2" it is not enough as it does not install the dependencies. maybe i am doing it wrong?
please indicate me a proper line for installing it correctly, and please include this software by default.
#22 2020-10-22 17:06:00
PedroReina
Good! smile
kapqa wrote:
it seems however that when installing gphoto2 ... is not enough as it does not install the dependencies.
I need to research a bit about that. I always just install gphoto2 and have no problems so far.
