#1 2020-10-12 15:34:55
[Solved] LibreOffice question
I'm slowly starting to loathe LibreOffice almost as much as MSOffice, which I had always used till I finally moved to a Linux environment, not without a lot of grief and getting used to.
I'll make it quick as this is dangerously off-topic:
Does anyone know how to disable the Data Validation of LibreCalc?
This POS application keeps putting a number I do not want to put in a cell but I have not been able to find a way to get rid of this feature.
I'm working on a very long and complicated 20+ year monthly expense expense sheet which I have to keep up to date and I want to be able to audit it myself.
I do not trust LO to do anything but sum up columns the same way I did not trust MSO.
Thanks in advance,
#2 2020-10-12 16:26:11
Re: [Solved] LibreOffice question
... disable the Data Validation of LibreCalc?
It's not Data Validation, it is something else that these DHs enable by default, à la Microsoft Office.
Incredible that they have not learned anything from their nemesis' shortcomings ...
This is yet another feature called, not surpringly, autoreplace.
To answer my question: one turns off autoreplace by going to the menu bar, selecting Tools > AutoCorrect Options...
You then click on the Options tab and uncheck the "Use replacement table".
My apologies for the noise.
Cheers,
