#1 2020-10-11 11:48:46
kapqa
(Beowulf)(AMD RX550) AMD Firmware Bug?
Hello,
i upgraded my computer from internal graphics by adding a Graphics Card AMD RX 550.
Now when i start the boot process shows somehting like
Firmware Bug: AMD-VI: IOAPIC(1) not in IVRS Table
is there something wrong?
i had installed the AMD GRaphics Firmware already i believe.
thank you.
#2 2020-10-11 11:58:20
kapqa
Re: (Beowulf)(AMD RX550) AMD Firmware Bug?
there is additional line
AMD-VI: disabling interrupt remapping
i am using devuan beowulf
Linux Office-PC 4.19.0-11-amd64 #1 SMP Debian 4.19.146-1 (2020-09-17) x86_64 GNU/Linux
graphics card seems recognized by "lspci"
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Lexa PRO [Radeon RX 550/550X] (rev c7)
#3 2020-10-11 12:14:40
kapqa wrote:
... by adding a Graphics Card AMD RX 550.
... when i start the boot process ...
Firmware Bug - AMD_VI IOAPIC(1) not in IVRS Table
See this post https://forums.linuxmint.com/viewtopic.php?t=326047
Questions:
Does your system work properly?
Are you using VirtualBox or VMware?
Any issues?
Do you have the latest BIOS available for your laptop?
Is this the same Fujitsu Worksation Laptop with Nvidia Quadro FX770m Graphics you were installing Nvidia legacy drivers for?
If so and most important: are you certain that the graphics card you have added is compatible/supported?
Cheers,
#4 2020-10-11 15:17:22
kapqa
Hello Altoid,
thanks for your replay,
no, it is no laptop, just an non-OEM-desktop with an AM4 Motherboard (lowcost) and A10-9700 APU.
The system is functioning, but the graphics i thought would be more responsive -
infact, there are no issues besides one with SVP4Linux, but this could well be related to an older Python version, but i suspect also the Open Source AMD Driver for the poor performance -
actually the same error comes up in Ubuntu 18.04, even with the AMD Graphics Pro Driver Stack installed for the RX550,
so most probably the error [Firmware BUG] is not related to the Graphics card, but to the APU itself?
i read somewhere that the Bristol Ridge is somehow unsupoorted, on Linux, as it is on Windows 8.1 (definitely unsupported)
it is functioning, yes, but the error message made me wonder if there is something going wrong here with the graphics.
#5 2020-10-11 15:28:06
larsH
Hi
Do you have firmware-amd-graphics installed ??
Have a nice day
Lars H
#6 2020-10-11 15:50:32
^ Yes, they mentioned that in the OP.
The open source amdgpu driver outperforms the proprietary version for almost all tasks and anyway AMD themselves only recommend the proprietary driver for their PRO cards (hence the name).
Read Altoid's link, it has the answer you need. Here is a more direct version: https://superuser.com/questions/1052023 … ivrs-table
#7 2020-10-11 15:56:52
Give firmware-amd-graphics and the 5.7 kernel from backports a try.
#8 2020-10-11 15:57:21
kapqa
larsH wrote:
Hi
Have a nice day
Lars H
yes,
firmware-amd-graphics is already the newest version (20190114-2).
#9 2020-10-11 15:59:53
kapqa
hello,
i did use the link from rolfie's last post here
https://dev1galaxy.org/viewtopic.php?id=3358
and did  the suggested
sudo apt install git
git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
cd linux-firmware/
sudo cp -va amdgpu/ /lib/firmware/
sudo update-initramfs -u
reboot
but things would remain the same.
#10 2020-10-11 16:01:34
kapqa
rolfie wrote:
Give firmware-amd-graphics nad the 5.7 kernel from backports a try.
thanks rolfie,
but how could i do that?
there is no "ukuu" on devuan?
don't find any mentioning of beowulf backports?
how to easily upgrade the kernel then?
#11 2020-10-11 16:09:14
kapqa
i had used fglrx driver before and also use the proprietary driver on ubuntu as i found it more responsive than the opensource,
also some features enable to use AMD VCE encoding in Handbrake (which is similare to quicksync and nvidia enc)
which opensource don't yet enable.
#12 2020-10-11 16:19:04
kapqa
alright,
now i tried with
kernel 5.7 and newer linux-amd-graphics from backports (thanks rolfie)
Linux Office-PC 5.7.0-0.bpo.2-amd64 #1 SMP Debian 5.7.10-1~bpo10+1 (2020-07-30) x86_64 GNU/Linux
firmware-amd-graphics is already the newest version (20200918-1~bpo10+1).
but the error remains
(0.00000) (Firmware Bug): (AMD-Vi) : IOAPIC(1) not in IVRS Table
          (0.00000) (AMD-Vi) : Disabling interrupt remapping
but it seems there is no major issues so i can live with that;
going to upgrade to Matisse soon, so maybe the error goes then away; the Bios is already quite the latest if i am not mistaken.
#13 2020-10-11 16:25:38
Read https://devuan.org/os/packages, in the bottom backports are mentioned.
Once they are enabled in the sources.list, do an apt update, then apt -t beowulf-backports install firmware-amd-graphics.
For the kernel list what is available, then select the one you want, e.g.:
apt list linux-image-5*
apt install linux-image-5.7.0-0.bpo.2-amd64
#14 2020-10-11 18:36:58
https://en.wikipedia.org/wiki/Confirmation_bias
Check the Phoronix site, their benchmarks are not susceptible to psychological distortion wink
It's better to install the kernel metapackage, that will always depend on the latest kernel version so that it will be kept updated:
# apt install linux-image-amd64/beowulf-backports
