#1 2020-10-09 10:29:51
samhain
ISO to test: Devuan + Exegnulinux + LinuxCNC + stuff remaster
Hi friends of Devuan and it's desendents!
This is my remaster of Exegnulinux + LinuxCNC 2.8 + HTML Docs, NCAM, PREEMPT Kernel, smictrl, ... and a whole toolkit with
F-Engrave, dmap2gcode, g-Code_Ripper, pycam 0.7, dxf2gcode, pcb2gcode & pcb2gcodeGUI, KiCad, Gimp, Inkscape, Slic3r, Printrun, OpenScad ... and some more smile
Architecture: amd64
https://github.com/zwieblum/devuan-imag … 8_2302.iso
https://github.com/zwieblum/devuan-imag … iso.sha256
Please feel free to test an give feedback smile
PWD/UID: root/root and user/user
Nik
#2 2020-10-11 16:02:41
dzz
Re: ISO to test: Devuan + Exegnulinux + LinuxCNC + stuff remaster
Cheers Nik..
Your exegnu remaster boots fine and fast here from usb. A short cmdline addition e.g. lang=en_GB sets both locale and keyboard for en_US/GB or ES on boot. I just discovered your rt kernel runs well on one old hp laptop here, better than the standard kernel which did not.
Although I don't need some of your special applications included, this is a good test ISO for some of the core exegnu functions, in particular internationalisation, installer and some live-config scripts (which maybe need some updating). It's also a good, successful test for refractasnapshot.
Well done and thanks!
D
#3 2021-03-29 08:17:12
samhain
Just uploaded the spring 2021 update: newest devuan beowulf, linuxcnc 2.8.1, all tools upgraded to latest version and most noticable: TDE 14.1. Enjoy smile
PREEMPT RT:
    ISO: https://github.com/zwieblum/devuan-imag … 021-04.iso
    SHA256: https://github.com/zwieblum/devuan-imag … iso.sha256
RTAI Kernel:
Release 2021.04 and up: root / toor and user / user.
#4 2021-03-30 15:45:49
samhain
I just finished uploading the image for RaspberryPi3+. It is based on Devuan Chimaera + TDE 14.1:
https://github.com/zwieblum/devuan-imag … tde.img.xz
