#1 2020-10-07 12:00:08
[SOLVED] BackInTime / rsync log error
I make scheduled back-ups via a cron job running BackInTime.
Works well enough and has saved me from a couple of disasters.
But ever since I generated a sudoers file, I started to get an error message:
Error: rsync: send_files failed to open "/home/groucho/sudoers": Permission denied (13)
I understand that access to /home/groucho/sudoers needs root access.
But I never wanted BackInTime to run as root so I left things as they were but there has to be a solution to this.
My user is part of the all the relevant groups ie: adm lp mail dialout fax cdrom floppy tape sudo backup staff lpadmin and has read and write access to the drive/folders where the back-up is stored by BackInTime.
Maybe a sudoers entry?
Any ideas?
Thanks in advance,
#2 2020-10-07 15:15:15
xinomilo
Unknown
Re: [SOLVED] BackInTime / rsync log error
why is there a sudoers file under /home/ ?
should be /etc/sudoers
in any case, it's probably perms : 440 / root:root, so rsync error is normal behavior..
#3 2020-10-07 16:46:16
xinomilo wrote:
why is there a sudoers file under /home/?
Absolutely embarrased cannot describe how I feel.
My only excuse is not having had my café au lait when I posted.    8^*
Of course it should not be there.
And the original is exactly where it should be:
groucho@devuan:~$ locate sudoers
/etc/sudoers
I think it was a left-over from when I was setting up the sudoers file, playing with visudo.
Somehow got created in /home/groucho, it is empty.
Thanks a lot for your input.
