#1 2020-10-06 14:46:58
erdos
'Zoom' crawls in beowulf
hi, i installed 'Zoom' with binary package download from their website.  it seems the apps is extremely slow with video skipping and no sound.  The menu fonts are displayed extra large size on the screen.  I use an old MS webcam.
does anyone have similar problem with using Zoom in Beowulf?
#2 2020-10-06 19:06:43
Re: 'Zoom' crawls in beowulf
The Zoom .debs work fine for me under Debian buster, even when run in a (KVM) virtual machine. I would be surprised if Devuan beowulf behaved differently.
You should probably share the exact URL from which you downloaded the package so that we can confirm you have the correct version.
Do you see any error messages if you start Zoom from a terminal?
#3 2020-10-06 19:52:52
Marjorie
Just as another data point.
I have Zoom installed, version 5.0.418682.0603 on a normal Beowulf installation. It installs in /opt. I have a old Logitech webcam (low res).
And it works fine.
I note that it seems to uses Qt. Could this be an issue?
#4 2020-10-07 00:17:38
erdos
this is the link i used to download binary package:
https://zoom.us/download?os=linux
#5 2020-10-09 02:45:52
erdos
here's the command prompt output, zoom version is 5.3.465578.0920
erdos@htpc-devuan:~/Downloads$ sudo zoom
[sudo] password for erdos:
ZoomLauncher started.
Zoom path is: /opt/zoom
cmd line:
CreateReportChannel bp_server_fd=4
$HOME = /root
Can't load/root/.config/zoomus.conf
export SSB_HOME=/root/.zoom; export QSG_INFO=1; export QT_AUTO_SCREEN_SCALE_FACTOR=1; export LD_LIBRARY_PATH=/opt/zoom; export BREAKPAD_CLIENT_FD=3; /opt/zoom/zoom ""
No PulseAudio daemon running, or not running as session daemon.
zoom started.
Client: Breakpad is using Client-Server Mode! client fd = 3
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[CZPClientLogMgr::LogClientEnvironment] [MacAddr: 00:23:54:95:BC:6A][client: Linux][OS: Devuan GNU/Linux 3 (beowulf)][Hardware: CPU Core:4 Frenquency:2.66 G Memory size:3946MB CPU Brand:Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz GPU Brand:][Req ID: ]
Linux Client Version is 5.3.465578.0920
QSG_RENDER_LOOP is
XDG_CURRENT_DESKTOP = ;   GDMSESSION =
Graphics Card Info:: 06:00.0 VGA compatible controller: NVIDIA Corporation G98 [GeForce 9300 GE] (rev a1)
Zoom package arch is 64bit, runing OS arch is x86_64
AppIconMgr::systemDesktopName log Desktop Name:
qt.scenegraph.general: threaded render loop
qt.scenegraph.general: Using sg animation driver
qt.scenegraph.general: Animation Driver: using vsync: 16.67 ms
qt.svg: link image0 hasn't been detected!
qt.svg: :/images/wechat.svg:10:6: Could not resolve property: pattern0
qt.scenegraph.general: texture atlas dimensions: 1024x512
qt.scenegraph.general: R/G/B/A Buffers:    8 8 8 8
qt.scenegraph.general: Depth Buffer:       24
qt.scenegraph.general: Stencil Buffer:     8
qt.scenegraph.general: Samples:            -1
qt.scenegraph.general: GL_VENDOR:          NVIDIA Corporation
qt.scenegraph.general: GL_RENDERER:        GeForce 9300 GE/PCIe/SSE2
qt.scenegraph.general: GL_VERSION:         3.3.0 NVIDIA 340.108
qt.scenegraph.general: GL_EXTENSIONS:      GL_ARB_texture_env_add GL_NV_explicit_multisample GL_ARB_explicit_attrib_location GL_ARB_enhanced_layouts GL_ARB_stencil_texturing GL_EXT_provoking_vertex GL_ARB_point_parameters GL_NV_fragment_program2 GL_EXT_texture_filter_anisotropic GL_ARB_draw_elements_base_vertex GL_ARB_texture_env_combine GL_EXT_texture_lod GL_EXT_draw_buffers2 GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_texture_sRGB GL_EXT_import_sync_object GL_NV_texture_rectangle GL_SGIS_generate_mipmap GL_NV_copy_depth_to_color GL_ARB_texture_view GL_EXT_draw_instanced GL_ARB_blend_func_extended GL_EXT_pixel_buffer_object GL_EXT_texture_env_dot3 GL_NV_float_buffer GL_NV_gpu_program4 GL_NV_point_sprite GL_SGIS_texture_lod GL_ARB_occlusion_query2 GL_ARB_depth_clamp GL_ARB_texture_compression_rgtc GL_ARB_vertex_shader GL_ARB_texture_mirrored_repeat GL_EXT_texture_lod_bias GL_NV_fence GL_ARB_half_float_pixel GL_ATI_draw_buffers GL_ARB_debug_output GL_EXT_texture_compression_rgtc GL_NV_depth_clamp GL_EXT_point_parameters GL_EXT_shader_integer_mix GL_NV_vertex_program2_option GL_ARB_framebuffer_sRGB GL_NV_vertex_array_range2 GL_ARB_fragment_program_shadow GL_EXT_texture_shared_exponent GL_ARB_shadow GL_EXT_blend_color GL_EXT_texture_compression_latc GL_ARB_texture_stencil8 GL_ARB_shading_language_packing GL_NV_packed_depth_stencil GL_ARB_texture_buffer_object GL_ARB_seamless_cube_map GL_ARB_ES3_compatibility GL_ARB_depth_texture GL_ARB_texture_rectangle GL_EXT_framebuffer_blit GL_ARB_timer_query GL_EXT_packed_pixels GL_ARB_depth_buffer_float GL_ARB_separate_shader_objects GL_ARB_vertex_array_bgra GL_ARB_texture_rgb10_a2ui GL_EXT_texture_env_combine GL_KHR_debug GL_NV_fragment_program_option GL_ARB_texture_non_power_of_two GL_ARB_robustness GL_EXT_texture_edge_clamp GL_IBM_texture_mirrored_repeat GL_ARB_map_buffer_alignment GL_NV_shader_buffer_load GL_EXT_separate_specular_color GL_EXT_texture_storage GL_NV_register_combiners GL_ATI_texture_mirror_once GL_EXT_multi_draw_arrays GL_ARB_copy_buffer GL_ARB_vertex_array_object GL_ARB_sync GL_ARB_copy_image GL_NV_occlusion_query GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_EXT_secondary_color GL_NV_vertex_program3 GL_EXT_framebuffer_sRGB GL_ARB_point_sprite GL_EXT_texture_sRGB_decode GL_EXT_texture_swizzle GL_EXT_framebuffer_object GL_ARB_imaging GL_EXT_depth_bounds_test GL_ARB_internalformat_query GL_ARB_map_buffer_range GL_ARB_texture_storage GL_NV_texgen_reflection GL_EXT_bgra GL_NV_texture_multisample GL_SGIX_shadow GL_ARB_texture_compression GL_ARB_texture_storage_multisample GL_EXT_compiled_vertex_array GL_EXT_blend_subtract GL_ARB_invalidate_subdata GL_EXT_vertex_array_bgra GL_EXT_shadow_funcs GL_EXT_fog_coord GL_ARB_texture_swizzle GL_ARB_uniform_buffer_object GL_NV_vdpau_interop GL_SUN_slice_accum GL_NV_fragment_program GL_ARB_shader_objects GL_ARB_multi_bind GL_NV_transform_feedback GL_EXT_packed_float GL_NV_path_rendering GL_ARB_compatibility GL_ARB_get_program_binary GL_NV_half_float GL_ARB_half_float_vertex GL_EXT_packed_depth_stencil GL_ARB_texture_border_clamp GL_EXT_vertex_array GL_NV_vertex_array_range GL_NV_ES1_1_compatibility GL_NV_light_max_exponent GL_NV_conditional_render GL_NV_parameter_buffer_object2 GL_ARB_texture_env_crossbar GL_ARB_draw_instanced GL_ARB_shader_bit_encoding GL_EXT_abgr GL_EXT_bindable_uniform GL_NV_primitive_restart GL_EXT_direct_state_access GL_NV_geometry_shader4 GL_EXT_texture3D GL_ARB_explicit_uniform_location GL_ARB_framebuffer_object GL_EXT_blend_minmax GL_NVX_conditional_render GL_ARB_robust_buffer_access_behavior GL_ARB_shading_language_420pack GL_NV_multisample_filter_hint GL_ARB_compressed_texture_pixel_storage GL_NVX_gpu_memory_info GL_SGIX_depth_texture GL_ARB_framebuffer_no_attachments GL_ARB_conservative_depth GL_EXT_texture_mirror_clamp GL_EXT_gpu_shader4 GL_EXT_draw_range_elements GL_IBM_rasterpos_clip GL_EXT_timer_query GL_NV_vertex_program GL_EXT_blend_func_separate GL_NV_parameter_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_x11_sync_object GL_NV_vertex_buffer_unified_memory GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_texture_compression_s3tc GL_ARB_texture_multisample GL_NV_fog_distance GL_EXT_Cg_shader GL_NV_texture_shader GL_ARB_fragment_program GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_rescale_normal GL_ARB_multitexture GL_ARB_multisample GL_ARB_vertex_attrib_binding GL_EXT_texture_object GL_EXT_stencil_two_side GL_ARB_draw_buffers GL_NV_texture_barrier GL_NV_register_combiners2 GL_S3_s3tc GL_ARB_geometry_shader4 GL_ATI_texture_float GL_ARB_color_buffer_float GL_EXT_blend_equation_separate GL_ARB_texture_cube_map GL_NV_texture_expand_normal GL_NV_texture_shader2 GL_ARB_program_interface_query GL_NV_texture_shader3 GL_NV_pixel_data_range GL_ARB_transpose_matrix GL_ARB_viewport_array GL_EXT_texture_buffer_object GL_ARB_fragment_coord_conventions GL_ARB_pixel_buffer_object GL_ARB_texture_buffer_range GL_ARB_provoking_vertex GL_NV_texture_env_combine4 GL_ARB_texture_mirror_clamp_to_edge GL_ARB_fragment_layer_viewport GL_NV_blend_square GL_EXT_stencil_wrap GL_EXT_gpu_program_parameters GL_NV_texture_compression_vtc GL_ARB_shader_texture_lod GL_ARB_texture_rg GL_EXT_texture_env_add GL_NV_framebuffer_multisample_coverage GL_ARB_sampler_objects GL_ARB_ES2_compatibility GL_ARB_arrays_of_arrays GL_EXT_geometry_shader4 GL_NV_depth_buffer_float GL_ARB_texture_env_dot3 GL_ARB_vertex_buffer_object GL_ARB_base_instance GL_KTX_buffer_region GL_EXTX_framebuffer_mixed_formats GL_EXT_texture_cube_map GL_EXT_framebuffer_multisample_blit_scaled GL_ARB_shading_language_100 GL_EXT_texture_integer GL_ARB_texture_query_levels GL_ARB_instanced_arrays GL_NV_copy_image GL_ARB_texture_float GL_ARB_fragment_shader GL_ARB_occlusion_query GL_NV_multisample_coverage GL_ARB_shading_language_include GL_EXT_framebuffer_multisample GL_ARB_internalformat_query2 GL_ARB_clear_buffer_object GL_EXT_separate_shader_objects
qt.scenegraph.general: Max Texture Size:  8192
qt.scenegraph.general: Debug context:     false
Error: Send error, 22 Invalid argument
qt.scenegraph.general: texture atlas dimensions: 512x512
#6 2020-10-09 07:26:48
xinomilo
Unknown
(never used zoom, but ) why are you running it with sudo permissions? zoom looks for configuration in /root/.config/ that seems wrong, just try running it as user :
$ zoom
#7 2020-10-09 09:22:54
PedroReina
erdos wrote:
no sound
Do you have PulseAudio installed?
If not, do you use apulse instead?; if so, you ned to launch your binary with apulse binary
#8 2020-10-09 12:11:38
Marjorie
Comparing your output, running as root with mine as local user, in addition to the lack of pulseaudio (which I have) I also note that you don't seem to have a desktop:
QSG_RENDER_LOOP is
whereas in mine:
Linux Client Version is 5.0.418682.0603
QSG_RENDER_LOOP is
XDG_CURRENT_DESKTOP = X-Cinnamon;   GDMSESSION = cinnamon
Also you've truncated the line that gives your PC spec. How much memory do you have? I have 8GiB. Zoom only seems to be using 57 MiB idling but I don't know how much it uses in a live session. I'd expect it would also use quite a bit of graphics memory.
Probably worth checking whether when zoom is active it's not driving you into using swap (disk) memory.
#9 2020-10-10 00:13:57
Danielsan
I use zoom through flatpak and it is fine.
#10 2020-10-10 14:41:55
Don't run zoom as root, that's just silly. https://en.wikipedia.org/wiki/Principle … _privilege
#11 2020-10-16 15:47:38
erdos
launching 'zoom' as regular user didn't work at first, but after a system reboot, i was able to launch the app from command line, no additional info was displayed once zoom was started from CLI though.
The issue remains:  live video in full screen mode lags, if i scaled it down, the video quality improves. and the menu as well as fonts display disproportionately large on the screen.
I was able to go into settings to get sound output once i logged in.
The system is a HP desktop with intel i7, 4G RAM, and nvidia 9300 video card.
#12 2020-10-16 16:11:13
xinomilo
Unknown
i don't think this is a problem for linux/devuan.. probably zoom related.. you might want to ask there for proprietary zoom support..
could be an issue with the old m$ webcam, the old video card, or connection related (?), or something other than that..
https://support.zoom.us/hc/en-us/articl … -and-Linux
