#1 2020-09-29 04:03:42
ofvergara
Beowulf: how to remove xfce and install mate, without breaking system
hello devuan team,
I have a virtualbox installation with beowulf xfce.
I want to try it with mate instead, however, as you can see above, xfce is already installed in this system.
what terminal commands or synaptic file selections do i have to add/choose/delete to remove/purge xfce and then install mate?
I hope this switch doesn't break the system.
waiting for your insightful input.
cheers.
#2 2020-09-29 05:12:38
Dutch_Master
Re: Beowulf: how to remove xfce and install mate, without breaking system
Find and install the mate-desktop meta-package in Synaptic. Mate and XFCE can happily co-exist, there's no conflict so no real reason to remove XFCE other then saving space on your virtual drive. If you still want to remove XFCE, there's an xfce-desktop package as well, see if that's installed then purge it and all of its dependencies. Synaptic is a smart tool (or rather, the underlying .deb packages) so it'll complain when you want to remove a package Mate relies on.
#3 2020-09-29 11:55:02
bgstack15
The way I would try to remove xfce-desktop would be with autoremove (or autopurge).
sudo apt-get autoremove xfce-desktop
The auto part will try to clean up any packages that were not manually selected, so that would include all the components that xfce-desktop had to bring in, that you had never named specifically (or did whatever the command is to mark them as not-manually-selected).
Beware that autoremove will try to remove all packages that are not manually selected, that are not dependencies of any manually-selected packages. So it could try to remove more than intended. So just be sure to look through the list of what it wants to remove before you say yes.
#4 2020-09-29 14:48:11
dev2cosmos
Drop to other tty like say tty2 and
sudo apt purge xfce4*
  then install mate.
Removing xfce4 this way probably take with it many dependence programs, so take note or uninstall one by one i think.
#5 2020-09-29 18:11:00
# aptitude install task-xfce-desktop- task-mate-desktop
