#1 2020-09-26 19:06:32
samhain
Images for OrangePi
For all owners of OrangePi Zero (LTS) and OrangePi PC Plus: I've remastered the latest armbian images to use devuan.
https://github.com/zwieblum/devuan-images
#2 2020-10-06 14:23:07
tuxd3v
Re: Images for OrangePi
hello samhain,
does you have kernel .config files for 'OrangePi Zero (LTS) and OrangePi PC Plus'? smile
I would be interested in get them smile
Best Regards,
tux
#3 2020-12-09 19:05:15
samhain
oops, late reply smile
I think they should be included in the image, but I am not sure if they are worth the trouble: the realtime patchset is unmatained since some months and the armbian kernel only builds inside the armbian docker image or on the device itself - in both cases the .config is included.
