#1 2020-09-26 16:58:54
Devuman
File Save: missing options?
With Devuan Ascii, when doing a "File Save" there was:
- a "recently used" save location option & corresponding folders list
- folders before files sort order
How to configure these with Devuan Beowulf?
A right-mouse-click in a File Save window displays several options,
among which "sort folders before files" but selection is not permanent
between file saves.
WM: i3.
#2 2020-09-26 21:21:08
Re: File Save: missing options?
Install dconf-editor and find the setting in there. It seems to be more nearly permanent that way.
#3 2020-09-27 14:18:05
With which program are you attempting this operation?
#4 2020-09-27 15:33:06
Devuman
Chromium/Firefox browser (save as, save link as, print & save as pdf), Geany editor. The "Save As" window is identical.
Searched dconf-editor for "save" and there's no corresponding setting.
#5 2020-09-27 16:13:34
PedroReina
May be under org.gtk.Settings.FileChooser
#6 2020-09-27 16:33:03
^ This.
Or from the command line:
gsettings set org.gtk.Settings.FileChooser sort-directories-first true
#7 2020-09-27 16:50:25
Devuman
Nope.
That worked, thanks.
Remains: "recently used" save location option & corresponding folders list
#8 2020-09-27 17:02:05
Devuman wrote:
Nope.
Check again, my command just toggles the "sort-directories-first" option in the section suggested by PedroReina.
¯\_(ツ)_/¯
#9 2020-09-27 21:27:56
Devuman
2nd try, org.gtk.Settings.FileChooser options:
