#1 2020-09-19 16:24:26
mexsudo
Beowulf Mate - no sound [solved]
fresh install using devuan_beowulf_3.0.0_amd64-desktop.iso
Mate selected, without the "default desktop"
I am not getting a sound widget in the Notification Area
using mate-volume-control hardware tab, I see HDA Intel PCH Mono, but still no sound
Ideas?
BTW: with Debian Mate this all works transparently "it just works"
#2 2020-09-19 16:36:12
Re: Beowulf Mate - no sound [solved]
Have you read the Devuan beowulf release notes or searched these boards? This is a common problem.
Black Lives Matter
#3 2020-09-19 16:40:09
mexsudo
I have read everything I could find, where is Sound with the Mate desktop mentioned?
#4 2020-09-19 16:48:23
Read the "Pulseaudio" section in the release notes.
Black Lives Matter
#5 2020-09-19 17:09:52
mexsudo
Thank you Sir. That worked
#6 2020-09-19 17:11:25
mexsudo
