#1 2020-09-19 06:42:58
erdos
Kodi help
hi, i have kodi installed on beowulf and tried to use it to watch IPTVs.
but some live channels aren't playing and it seems i need to have enable rtmp support from 'VideoPlayer InputStream', but the latter doesn't appear in menu,  so i searched online and run the following commands :
sudo apt-get install kodi-inputstream-adaptive
sudo apt-get install kodi-inputstream-rtmp
it came back saying 'unable to locate package...'
question is how to install the packages needed to play live IPTV in kodi?
#2 2020-09-19 07:52:24
Re: Kodi help
Those package aren't available in the official repositories (AFAICT). The deb-multimedia repositories have them but we've had lots of problem threads over at forums.debian.net about dependency hell caused by those repositories so perhaps just install the .debs individually instead of adding the repositories.
https://www.deb-multimedia.org/pool/mai … _amd64.deb
EDIT: or add the deb-multimedia repositories then pin them to 100 (the same as backports) to prevent inadvertent upgrades.
#3 2020-09-19 10:05:29
HevyDevy
Re: Kodi help
offtopic but ive found it easier to use a dedicated multimedia distro like batocera linux to have kodi up and running on separate partition.
https://batocera.org/ is a retro gaming os and has kodi preinstalled.
Have a look at https://wiki.batocera.org/kodi
#4 2020-09-22 14:48:18
erdos
Re: Kodi help
Thanks for the reply!  This is what I need.
#5 2020-09-27 03:29:14
erdos
Re: Kodi help
It seems that dependency is not satisfied with direct installation of .deb package
erdos@htpc-devuan:~/Downloads$ sudo apt install ./kodi-inputstream-adaptive_2.4.5-dmo0+deb10u1_amd64.deb
Building dependency tree
Note, selecting 'kodi-inputstream-adaptive' instead of './kodi-inputstream-adaptive_2.4.5-dmo0+deb10u1_amd64.deb'
kodi-inputstream-adaptive : Depends: kodi (>= 5:18~) but 2:17.6+dfsg1-4+b1 is to be installed
Note, selecting 'kodi-inputstream-rtmp' instead of './kodi-inputstream-rtmp_2.0.9-dmo0+deb10u1_amd64.deb'
kodi-inputstream-rtmp : Depends: kodi (>= 5:18~) but 2:17.6+dfsg1-4+b1 is to be installed
#6 2020-09-27 03:44:10
Re: Kodi help
Not that I have kodi setup yet, but I managed to install these debian packages with,
dpkg -i --force-depends (packages location and name)
edit..this one needed "--force-depends". /home/glenn/Downloads/kodi-inputstream-adaptive_2.4.5-dmo0+deb10u1_amd64.deb
hope this helps
regards Glenn
I recreated the output...
root@GamesBox:~# dpkg -i --force-depends /home/glenn/Downloads/*.deb
Selecting previously unselected package kodi-inputstream-adaptive.
(Reading database ... 421747 files and directories currently installed.)
Preparing to unpack .../kodi-inputstream-adaptive_2.4.5-dmo0+deb10u1_amd64.deb ...
Unpacking kodi-inputstream-adaptive (2.4.5-dmo0+deb10u1) ...
Preparing to unpack .../kodi-inputstream-rtmp_2.0.9-dmo0+deb10u1_amd64.deb ...
Unpacking kodi-inputstream-rtmp (2.0.9-dmo0+deb10u1) over (2.0.9-dmo0+deb10u1) ...
dpkg: kodi-inputstream-adaptive: dependency problems, but configuring anyway as you requested:
 kodi-inputstream-adaptive depends on kodi (>= 5:18~); however:
  Version of kodi on system is 2:17.6+dfsg1-4+b1.
Setting up kodi-inputstream-adaptive (2.4.5-dmo0+deb10u1) ...
dpkg: kodi-inputstream-rtmp: dependency problems, but configuring anyway as you requested:
 kodi-inputstream-rtmp depends on kodi (>= 5:18~); however:
Setting up kodi-inputstream-rtmp (2.0.9-dmo0+deb10u1) ...
root@GamesBox:~#
#7 2020-09-27 14:17:01
Re: Kodi help
Does the plugin actually work with the Debian version of Kodi?
Looks like the add-on can be installed from Kodi without relying on the DMO package: https://kodi.wiki/view/Add-on:InputStream_Adaptive
#8 2020-09-27 21:51:18
Re: Kodi help
I'm not sure forcing the install is feasible. The packages are stopping the system until the broken packages are removed. So forcing the installations got me no-where, really.
#9 2020-09-28 17:11:30
PedroReina
Re: Kodi help
I don't know if my experience is convenient to do in your case, but I will explain it:
In a few boxes with Devuan Beowulf 64 bits I used a --force-all to install a deb file for an old printer. All the package management programs complained from this point on about not met dependencies. I edited by hand the file /var/lib/dpkg/status and removed the claimed dependencies. So far, so good.
#10 2020-09-29 18:27:15
Re: Kodi help
You could grab the DMO source and modify debian/control so the dependencies are satisfied by the beowulf Kodi version but the add-on might not work for that.
