#1 2020-09-18 12:57:31
magicalsenpai
Can't update the chimaera-security repo
I decided to try testing (chimaera), so I replaced all the "beowulfs" in my /etc/apt/sources.list with "chimaera". However, when I try to update, the terminal says that it can't find the release file.
The input/output can be seen here:
➜  ~ sudo apt-get update
Hit:1 https://brave-browser-apt-dev.s3.brave.com stable InRelease
Hit:2 https://repo.nordvpn.com/deb/nordvpn/debian stable InRelease
Hit:3 http://download.opensuse.org/repositories/Emulators:/Wine:/Debian/Debian_10 ./ InRelease
Hit:4 http://deb.devuan.org/merged chimaera InRelease
Ign:5 http://deb.devuan.org/merged chimaera-security InRelease
Hit:6 http://deb.devuan.org/merged chimaera-updates InRelease
Err:7 http://deb.devuan.org/merged chimaera-security Release
  404  Not Found [IP: 54.36.142.183 80]
E: The repository 'http://deb.devuan.org/merged chimaera-security Release' does not have a Release file.
I'm sure I'm just missing something simple, but I can't seem to find any answers.
#2 2020-09-18 13:19:46
HevyDevy
Re: Can't update the chimaera-security repo
Chimaera aka testing does not have security updates, only the stable branch gets security updates.
#3 2020-09-18 21:29:06
brocashelm
Both Chimaera and Ceres get you closer to upstream versions of software, so all the security updates can come directly from them.
#4 2020-09-18 22:09:35
Note that chimaera is subject to a mandatory transition delay from ceres and so may be left vulnerable for a while[0] and any security updates for ceres depend on the package maintainers noticing them rather than the Security Team taking care of them[1].
To quote the Debian Security FAQ:
If you want to have a secure (and stable) server you are strongly encouraged to stay with stable.
#5 2020-09-19 05:49:09
magicalsenpai
Thanks everyone, I knew Ceres/Sid didn't receive security updates, but didn't know testing didn't either. I was further confused from others' sources lists having chimaera security on there. I changed it to Beowulf security after I made this post, so I could update, would it be wise to keep it as such?
#6 2020-09-19 07:31:13
None of your packages will be updated from the beowulf security repositories because the versions in there will be older.
#7 2020-09-19 07:49:51
magicalsenpai
That makes sense, thanks
