#1 2020-09-14 19:05:18
xinomilo
Unknown
[SOLVED] ceres repos "stuck" ?
haven't seen updates in a few days (2-3 i think.) in ceres, which is unusual....
maybe devuan amprolla wizards can take a look?  smile
eg. package : ffmpeg, was uploaded in debian sid on 12/9/2020. added debian repo just for checking with apt :
# apt policy ffmpeg
ffmpeg:
  Installed: 7:4.3.1-2
  Candidate: 7:4.3.1-3
  Version table:
     7:4.3.1-3 500
        500 http://deb.debian.org/debian sid/main amd64 Packages
*** 7:4.3.1-2 500
        500 http://deb.devuan.org/merged ceres/main amd64 Packages
thx.
#2 2020-09-14 19:17:30
brocashelm
Re: [SOLVED] ceres repos "stuck" ?
I'm also noticing this. Checking with the Debian Sid repository, there are a ton of packages that need to be upgraded, but I always want to be careful with mixing Debian and Ubuntu packages (the only exceptions include Boot-Repair and Mintstick, both of which were safely installed from separate DEB files).
Either way, I'm not too concerned. That it's quite stable itself is rather impressive and satisfies my use cases. Props to the team! smile
#3 2020-09-15 09:29:57
xinomilo
Unknown
all back to normal now, lots of updates came in today ... smile
#4 2020-09-15 21:08:16
thierrybo
yes all back and it wants to remove python if I do a full-upgrade mad (i' am on testing/chimaera)
#5 2020-09-16 06:22:32
larsH
Hi
Yes. To be aware and have some knowledge is sometimes required. Now it upgrades python as well :-)
Have a nice day
Lars H
#6 2020-09-16 18:02:55
thierrybo
not yet for me:
sudo apt full-upgrade
Building dependency tree
Calculating upgrade... Done
  libapt-inst2.0 libapt-pkg5.0 libkeybinder0 libpython-stdlib libqt5opengl5 libvpx5 linux-headers-5.7.0-2-amd64
  linux-headers-5.7.0-2-common linux-image-5.7.0-2-amd64 python-cairo python-configparser python-gi python-gi-cairo
  python-numpy python-pkg-resources python-setuptools python-six
  obmenu paprass python python-apt python-asn1crypto python-cffi-backend python-cryptography python-enum34
  python-fasteners python-future python-glade2 python-gobject python-gobject-2 python-gtk2 python-ipaddress
  python-keybinder python-lockfile python-monotonic python-notify python-openssl python-pexpect python-pil python-poppler
  python-psutil python-ptyprocess python-reportlab python-reportlab-accel python-sane python-support python-wxgtk3.0
  python-wxversion python-xdg python-xlib python-xpyb virtualbox-6.1
  gdebi libpython2-stdlib python2 python2-minimal synaptic
  cups-filters cups-filters-core-drivers libayatana-indicator3-7 libcupsfilters1 libfontembed1 libhttp-message-perl
  libjbig2dec0 libjson-glib-1.0-0 libjson-glib-1.0-common
9 upgraded, 0 newly installed, 35 to remove and 5 not upgraded.
Need to get 1379 kB of archives.
After this operation, 261 MB disk space will be freed.
#7 2020-09-16 18:07:17
larsH
Hi
Well wait to your local mirror gets updated. It can take some time. If it is not working tomorrow, then olease post your sources.list
Have a nice day
Lars H
#8 2020-09-16 21:27:16
thierrybo
Currently there is no python package in Debian testing:
https://packages.debian.org/search?keyw … ection=all
#9 2020-09-17 07:22:38
larsH
Hi
My mistake. but there are python2 and python3. My suggestion is to make sure both are installed. Later in the development proces python2 might be removed.
Have a nice day
Lars H
#10 2020-11-07 13:18:35
xinomilo
Unknown
just a note to the dev1 team, ceres seems "stuck" again..
thx.
