#1 2020-09-14 09:51:02
package dqcache
The package dqcache comes without any init.d script so it thus needs hand crafting.
1) Edit /etc/default/dqcache by adding "export" to every variable setting. For example:
# dqcache runs chrooted in the directory specified
# by the $ROOT environment variable
export ROOT="/var/lib/dqcache/root"
# dqcache listens for incoming UDP packets and TCP connections
2) Create /etc/init.d/dqcache with the following:
#!/usr/bin/env /lib/init/init-d-script
### BEGIN INIT INFO
# Provides:          atd
# Required-Start:    $syslog $time $remote_fs
# Required-Stop:     $syslog $time $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: DNS Cacher
# Description:       Debian init script to start the dbcacher daemon
### END INIT INFO
DESC="DNS cacher daemon"
DAEMON=/usr/sbin/dqcache
PIDFILE=none
NAME=dqcache
START_ARGS=--background
export UID=$(id -u $NAME)
export GID=$(id -g $NAME)
3) Finalize with usual hands-on
# update-rc.d dqcache defaults
# update-rc.d dqcache enable
# service dqcache restart
#2 2020-09-22 20:36:19
xinomilo
Unknown
Re: package dqcache
nice, thanks for this smile
edit] just a note, make init script executable, after creating :
# chmod +x /etc/init.d/dqcache
also, init script change line 3 to :
# Provides:          dqcache
