#1 2020-09-10 16:09:36
erdos
Beowulf crashes often
hi,  it seems that Beowulf on my computer is crashing often.  typically the screen would freeze and keyboard is not responsive.  I use Beowulf on my HTPC and usually firefox and kodi are opened on the desktop.  It's installed on a HP computer with Nvidia card and solid state HD.
anyone else has beowulf crashing issues?
#2 2020-09-10 16:33:22
sgage
Re: Beowulf crashes often
No such problems here. In fact, Beowulf has been totally reliable on my system.  I, too, have an HP desktop with an SSD, but I run just the integrated Intel graphics. It wouldn't surprise me if your issue was Nvidia related. Are you using nouveau or the proprietary drivers?
#3 2020-09-10 17:16:31
erdos
I use nvidia proprietary driver installed through 'synaptics' on this computer.  i believe it's a 9300 series card from nvidia.
#4 2020-09-10 18:58:26
sgage
Perhaps you could try the open source nouveau driver, just to help narrow things down. I gave up on Nvidia when my last Nvidia card died a few years ago, but there seems to be no end of glitches and trouble and version mismatches and whatnot with the proprietary drivers. Hopefully an Nvidia expert will chime in...
#5 2020-09-10 20:44:46
Jupp, my X470/Ryzen7 2700X/RX580 also crashes on me time by time. I think the RX580 is the reason:
Sep 10 09:43:10 rh050 kernel: [ 4404.339863] pcieport 0000:00:03.1: AER: Multiple Corrected error received: 0000:00:00.0
Sep 10 09:43:10 rh050 kernel: [ 4404.339876] pcieport 0000:00:03.1: AER: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
Sep 10 09:43:10 rh050 kernel: [ 4404.339879] pcieport 0000:00:03.1: AER:   device [1022:1453] error status/mask=00001100/00006000
Sep 10 09:43:10 rh050 kernel: [ 4404.339881] pcieport 0000:00:03.1: AER:    [ 8] Rollover
Sep 10 09:43:10 rh050 kernel: [ 4404.339883] pcieport 0000:00:03.1: AER:    [12] Timeout
Sep 10 09:44:38 rh050 kernel: [ 4492.979566] pcieport 0000:00:03.1: AER: Multiple Uncorrected (Non-Fatal) error received: 0000:00:00.0
Sep 10 09:44:38 rh050 kernel: [ 4492.979575] pcieport 0000:00:03.1: AER: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Receiver ID)
Sep 10 09:44:38 rh050 kernel: [ 4492.979579] pcieport 0000:00:03.1: AER:   device [1022:1453] error status/mask=00200000/04400000
Sep 10 09:44:38 rh050 kernel: [ 4492.979581] pcieport 0000:00:03.1: AER:    [21] ACSViol                (First)
Sep 10 09:44:38 rh050 kernel: [ 4492.979585] amdgpu 0000:0c:00.0: AER: can't recover (no error_detected callback)
Sep 10 09:44:38 rh050 kernel: [ 4492.979586] snd_hda_intel 0000:0c:00.1: AER: can't recover (no error_detected callback)
Sep 10 09:44:38 rh050 kernel: [ 4492.979605] pcieport 0000:00:03.1: AER: device recovery failed
Sep 10 09:44:38 rh050 kernel: [ 4492.990594] pcieport 0000:00:03.1: AER: Multiple Uncorrected (Non-Fatal) error received: 0000:00:00.0
Sep 10 09:44:38 rh050 kernel: [ 4492.990601] pcieport 0000:00:03.1: AER: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, (Receiver ID)
Sep 10 09:44:38 rh050 kernel: [ 4492.990604] pcieport 0000:00:03.1: AER:   device [1022:1453] error status/mask=00200000/04400000
Sep 10 09:44:38 rh050 kernel: [ 4492.990606] pcieport 0000:00:03.1: AER:    [21] ACSViol                (First)
Sep 10 09:44:38 rh050 kernel: [ 4492.990609] amdgpu 0000:0c:00.0: AER: can't recover (no error_detected callback)
Sep 10 09:44:38 rh050 kernel: [ 4492.990610] snd_hda_intel 0000:0c:00.1: AER: can't recover (no error_detected callback)
Sep 10 09:44:38 rh050 kernel: [ 4492.990621] pcieport 0000:00:03.1: AER: device recovery failed
Sep 10 09:44:49 rh050 kernel: [ 4503.189629] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=34669, emitted seq=34671
Sep 10 09:44:49 rh050 kernel: [ 4503.189730] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1642, emitted seq=1643
Sep 10 09:44:49 rh050 kernel: [ 4503.189832] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:44:49 rh050 kernel: [ 4503.189846] [drm:drm_atomic_helper_wait_for_flip_done [drm_kms_helper]] *ERROR* [CRTC:47:crtc-0] flip_done timed out
Sep 10 09:44:49 rh050 kernel: [ 4503.189849] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:44:49 rh050 kernel: [ 4503.189948] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:44:49 rh050 kernel: [ 4503.189951] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:44:59 rh050 kernel: [ 4503.189953] [drm] Bailing on TDR for s_job:83f6, as another already in progress
Sep 10 09:44:59 rh050 kernel: [ 4513.429441] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [CRTC:47:crtc-0] flip_done timed out
Sep 10 09:45:09 rh050 kernel: [ 4523.669346] [drm:drm_atomic_helper_wait_for_dependencies [drm_kms_helper]] *ERROR* [PLANE:45:plane-5] flip_done timed out
Sep 10 09:45:10 rh050 kernel: [ 4524.273536] amdgpu 0000:0c:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_2.1.0 test failed (-110)
Sep 10 09:45:10 rh050 kernel: [ 4524.273619] [drm:gfx_v8_0_hw_fini [amdgpu]] *ERROR* KCQ disable failed
Sep 10 09:45:10 rh050 kernel: [ 4524.548390] cp is busy, skip halt cp
Sep 10 09:45:10 rh050 kernel: [ 4524.823113] rlc is busy, skip halt rlc
Sep 10 09:45:10 rh050 kernel: [ 4524.824133] amdgpu 0000:0c:00.0: GPU BACO reset
Sep 10 09:45:11 rh050 kernel: [ 4525.125145] amdgpu 0000:0c:00.0: GPU reset succeeded, trying to resume
Sep 10 09:45:11 rh050 kernel: [ 4525.126894] [drm] PCIE GART of 256M enabled (table at 0x000000F400300000).
Sep 10 09:45:11 rh050 kernel: [ 4525.126906] [drm] VRAM is lost due to GPU reset!
Sep 10 09:45:11 rh050 kernel: [ 4525.453490] amdgpu 0000:0c:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring gfx test failed (-110)
Sep 10 09:45:11 rh050 kernel: [ 4525.453561] [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <gfx_v8_0> failed -110
Sep 10 09:45:11 rh050 kernel: [ 4525.453593] amdgpu 0000:0c:00.0: GPU reset(1) failed
Sep 10 09:45:11 rh050 kernel: [ 4525.453597] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453599] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453603] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453604] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453607] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453608] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453609] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453613] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453615] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453616] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453618] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453619] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453620] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453621] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453623] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453628] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453630] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453631] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453636] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453638] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453642] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453643] amdgpu 0000:0c:00.0: GPU reset end with ret = -110
Sep 10 09:45:11 rh050 kernel: [ 4525.453650] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453654] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453658] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453659] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453662] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453667] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453673] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453676] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453680] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453682] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453685] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453686] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453687] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453688] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453689] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453690] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453691] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453692] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453693] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453695] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453696] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453698] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453699] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453700] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453702] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453704] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453705] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453706] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453707] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453708] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453710] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453711] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453712] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453714] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453715] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453716] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453718] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453719] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453720] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453721] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453722] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453723] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453724] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453726] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453727] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453728] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453730] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453731] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453732] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453735] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453736] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453737] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453738] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453739] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453741] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453742] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453743] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453745] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453747] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453748] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453749] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453750] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453751] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453754] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453755] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453756] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453758] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453759] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453760] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453762] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453763] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453765] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453766] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453767] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453768] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453771] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453774] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453775] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453777] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453781] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453784] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453787] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.453791] [drm] Skip scheduling IBs!
Sep 10 09:45:11 rh050 kernel: [ 4525.454036] [drm] scheduler sdma0 is not ready, skipping
Sep 10 09:45:11 rh050 kernel: [ 4525.454037] [drm] scheduler sdma1 is not ready, skipping
Sep 10 09:45:11 rh050 kernel: [ 4525.454114] [drm:amdgpu_gem_va_ioctl [amdgpu]] *ERROR* Couldn't update BO_VA (-2)
Sep 10 09:45:11 rh050 kernel: [ 4525.454145] BUG: kernel NULL pointer dereference, address: 0000000000000008
Sep 10 09:45:11 rh050 kernel: [ 4525.454147] #PF: supervisor read access in kernel mode
Sep 10 09:45:11 rh050 kernel: [ 4525.454148] #PF: error_code(0x0000) - not-present page
Sep 10 09:45:11 rh050 kernel: [ 4525.454150] PGD 0 P4D 0
Sep 10 09:45:11 rh050 kernel: [ 4525.454153] Oops: 0000 [#1] SMP NOPTI
Sep 10 09:45:11 rh050 kernel: [ 4525.454156] CPU: 9 PID: 4151 Comm: Xorg Tainted: G           OE     5.7.0-0.bpo.2-amd64 #1 Debian 5.7.10-1~bpo10+1
Sep 10 09:45:11 rh050 kernel: [ 4525.454157] Hardware name: System manufacturer System Product Name/PRIME X470-PRO, BIOS 5406 11/13/2019
Sep 10 09:45:11 rh050 kernel: [ 4525.454234] RIP: 0010:amdgpu_vm_sdma_commit+0x50/0x1f0 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454237] Code: 8b 47 20 80 7f 10 00 48 8b a8 88 01 00 00 48 8b 47 08 4c 8d a0 e0 00 00 00 75 07 4c 8d a0 98 01 00 00 49 8b 44 24 10 8b 55 08 <48> 8b 40 08 48 8d 78 88 85 d2 0f 84 42 01 00 00 48 8b 40 90 48 89
Sep 10 09:45:11 rh050 kernel: [ 4525.454239] RSP: 0018:ffffaeb301cebb50 EFLAGS: 00010246
Sep 10 09:45:11 rh050 kernel: [ 4525.454240] RAX: 0000000000000000 RBX: ffffaeb301cebba0 RCX: 0000000000108000
Sep 10 09:45:11 rh050 kernel: [ 4525.454242] RDX: 0000000000000080 RSI: ffffaeb301cebc48 RDI: ffffaeb301cebba0
Sep 10 09:45:11 rh050 kernel: [ 4525.454243] RBP: ffff9da25c513de8 R08: ffff9da22b80e6c8 R09: 0000000000000000
Sep 10 09:45:11 rh050 kernel: [ 4525.454244] R10: 000000000000007d R11: 0000000000000000 R12: ffff9da2727d8198
Sep 10 09:45:11 rh050 kernel: [ 4525.454245] R13: ffffaeb301cebc48 R14: 0000000000107600 R15: 0000000000000002
Sep 10 09:45:11 rh050 kernel: [ 4525.454247] FS:  00007fc5e6855a80(0000) GS:ffff9da27ea40000(0000) knlGS:0000000000000000
Sep 10 09:45:11 rh050 kernel: [ 4525.454248] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 10 09:45:11 rh050 kernel: [ 4525.454249] CR2: 0000000000000008 CR3: 00000007f5370000 CR4: 00000000003406e0
Sep 10 09:45:11 rh050 kernel: [ 4525.454250] Call Trace:
Sep 10 09:45:11 rh050 kernel: [ 4525.454327]  amdgpu_vm_bo_update_mapping+0x1d4/0x200 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454403]  amdgpu_vm_clear_freed+0xe8/0x230 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454477]  amdgpu_gem_va_ioctl+0x3c4/0x4d0 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454551]  ? amdgpu_gem_va_map_flags+0x60/0x60 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454567]  drm_ioctl_kernel+0xac/0xf0 [drm]
Sep 10 09:45:11 rh050 kernel: [ 4525.454583]  drm_ioctl+0x201/0x3a0 [drm]
Sep 10 09:45:11 rh050 kernel: [ 4525.454655]  ? amdgpu_gem_va_map_flags+0x60/0x60 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454725]  amdgpu_drm_ioctl+0x49/0x80 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.454730]  ksys_ioctl+0x86/0xc0
Sep 10 09:45:11 rh050 kernel: [ 4525.454732]  __x64_sys_ioctl+0x16/0x20
Sep 10 09:45:11 rh050 kernel: [ 4525.454736]  do_syscall_64+0x52/0x170
Sep 10 09:45:11 rh050 kernel: [ 4525.454740]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Sep 10 09:45:11 rh050 kernel: [ 4525.454742] RIP: 0033:0x7fc5e6f6f427
Sep 10 09:45:11 rh050 kernel: [ 4525.454744] Code: 00 00 90 48 8b 05 69 aa 0c 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 39 aa 0c 00 f7 d8 64 89 01 48
Sep 10 09:45:11 rh050 kernel: [ 4525.454745] RSP: 002b:00007ffe16824678 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Sep 10 09:45:11 rh050 kernel: [ 4525.454747] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007fc5e6f6f427
Sep 10 09:45:11 rh050 kernel: [ 4525.454748] RDX: 00007ffe168246c0 RSI: 00000000c0286448 RDI: 000000000000000e
Sep 10 09:45:11 rh050 kernel: [ 4525.454749] RBP: 00007ffe168246c0 R08: 0000000107600000 R09: 000000000000000e
Sep 10 09:45:11 rh050 kernel: [ 4525.454750] R10: 0000000000000044 R11: 0000000000000246 R12: 00000000c0286448
Sep 10 09:45:11 rh050 kernel: [ 4525.454751] R13: 000000000000000e R14: 0000000000000002 R15: 000056228fa96960
Sep 10 09:45:11 rh050 kernel: [ 4525.454753] Modules linked in: rpcsec_gss_krb5 nfsv4 dns_resolver bnep bluetooth drbg ansi_cprng ecdh_generic ecc vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) parport_pc ppdev lp parport nfsd auth_rpcgss nfs_acl nfs lockd grace fscache sunrpc efivarfs fuse nls_ascii nls_cp437 vfat fat pktcdvd snd_hda_codec_realtek edac_mce_amd amdgpu snd_hda_codec_generic ledtrig_audio gpu_sched snd_hda_codec_hdmi kvm_amd ttm snd_hda_intel drm_kms_helper snd_intel_dspcfg ftdi_sio joydev eeepc_wmi cec asus_wmi kvm usbserial evdev snd_hda_codec drm battery snd_hda_core sparse_keymap irqbypass rfkill snd_hwdep video snd_pcm wmi_bmof efi_pstore pcspkr snd_timer efivars ccp snd sp5100_tco mxm_wmi k10temp watchdog mfd_core soundcore rng_core button acpi_cpufreq ext4 crc16 mbcache jbd2 crc32c_generic algif_skcipher af_alg dm_crypt dm_mod sr_mod cdrom uas usb_storage sg hid_generic usbhid hid sd_mod crc32_pclmul crc32c_intel ghash_clmulni_intel ohci_pci aesni_intel ahci libaes libahci xhci_pci crypto_simd xhci_hcd
Sep 10 09:45:11 rh050 kernel: [ 4525.454790]  ohci_hcd ehci_pci libata ehci_hcd igb cryptd glue_helper scsi_mod nvme i2c_piix4 usbcore i2c_algo_bit nvme_core dca ptp pps_core t10_pi crc_t10dif crct10dif_generic crct10dif_pclmul usb_common crct10dif_common wmi gpio_amdpt gpio_generic
Sep 10 09:45:11 rh050 kernel: [ 4525.454802] CR2: 0000000000000008
Sep 10 09:45:11 rh050 kernel: [ 4525.454804] ---[ end trace f9443a0822a20086 ]---
Sep 10 09:45:11 rh050 kernel: [ 4525.676451] RIP: 0010:amdgpu_vm_sdma_commit+0x50/0x1f0 [amdgpu]
Sep 10 09:45:11 rh050 kernel: [ 4525.676455] Code: 8b 47 20 80 7f 10 00 48 8b a8 88 01 00 00 48 8b 47 08 4c 8d a0 e0 00 00 00 75 07 4c 8d a0 98 01 00 00 49 8b 44 24 10 8b 55 08 <48> 8b 40 08 48 8d 78 88 85 d2 0f 84 42 01 00 00 48 8b 40 90 48 89
Sep 10 09:45:11 rh050 kernel: [ 4525.676456] RSP: 0018:ffffaeb301cebb50 EFLAGS: 00010246
Sep 10 09:45:11 rh050 kernel: [ 4525.676458] RAX: 0000000000000000 RBX: ffffaeb301cebba0 RCX: 0000000000108000
Sep 10 09:45:11 rh050 kernel: [ 4525.676459] RDX: 0000000000000080 RSI: ffffaeb301cebc48 RDI: ffffaeb301cebba0
Sep 10 09:45:11 rh050 kernel: [ 4525.676460] RBP: ffff9da25c513de8 R08: ffff9da22b80e6c8 R09: 0000000000000000
Sep 10 09:45:11 rh050 kernel: [ 4525.676461] R10: 000000000000007d R11: 0000000000000000 R12: ffff9da2727d8198
Sep 10 09:45:11 rh050 kernel: [ 4525.676462] R13: ffffaeb301cebc48 R14: 0000000000107600 R15: 0000000000000002
Sep 10 09:45:11 rh050 kernel: [ 4525.676464] FS:  00007fc5e6855a80(0000) GS:ffff9da27ea40000(0000) knlGS:0000000000000000
Sep 10 09:45:11 rh050 kernel: [ 4525.676465] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 10 09:45:11 rh050 kernel: [ 4525.676466] CR2: 0000000000000008 CR3: 00000007f5370000 CR4: 00000000003406e0
Sep 10 09:45:13 rh050 hddtemp[4090]: /dev/sda: CT500MX500SSD1: 33 C
Sep 10 09:45:13 rh050 hddtemp[4090]: /dev/sdb: Crucial_CT1050MX300SSD1: 26 C
Sep 10 09:45:13 rh050 hddtemp[4090]: /dev/sdc: Crucial_CT512MX100SSD1: 31 C
Sep 10 09:45:13 rh050 hddtemp[4090]: /dev/sde: CT2000MX500SSD1: 33 C
Sep 10 09:45:13 rh050 hddtemp[4090]: /dev/sdf: WDC WD4001FFSX-68JNUN0: 39 C
Sep 10 09:45:21 rh050 kernel: [ 4535.701511] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:45:21 rh050 kernel: [ 4535.701602] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=34671, emitted seq=34671
Sep 10 09:45:21 rh050 kernel: [ 4535.701692] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process  pid 0 thread  pid 0
Sep 10 09:45:21 rh050 kernel: [ 4535.701783] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:45:21 rh050 kernel: [ 4535.701784] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:45:21 rh050 kernel: [ 4535.701790] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:45:31 rh050 kernel: [ 4535.701792] [drm] Bailing on TDR for s_job:4cd, as another already in progress
Sep 10 09:45:31 rh050 kernel: [ 4545.941531] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:45:31 rh050 kernel: [ 4545.941622] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:45:31 rh050 kernel: [ 4545.941630] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:45:42 rh050 kernel: [ 4545.941632] [drm] Bailing on TDR for s_job:4ce, as another already in progress
Sep 10 09:45:42 rh050 kernel: [ 4556.181492] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:45:42 rh050 kernel: [ 4556.181583] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:45:42 rh050 kernel: [ 4556.181591] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:45:52 rh050 kernel: [ 4556.181594] [drm] Bailing on TDR for s_job:4cf, as another already in progress
Sep 10 09:45:52 rh050 kernel: [ 4566.421393] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:45:52 rh050 kernel: [ 4566.421485] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:45:52 rh050 kernel: [ 4566.421493] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:46:02 rh050 kernel: [ 4566.421495] [drm] Bailing on TDR for s_job:4d0, as another already in progress
Sep 10 09:46:02 rh050 kernel: [ 4576.661299] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:46:02 rh050 kernel: [ 4576.661390] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:46:02 rh050 kernel: [ 4576.661398] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:46:12 rh050 kernel: [ 4576.661401] [drm] Bailing on TDR for s_job:4d1, as another already in progress
Sep 10 09:46:12 rh050 kernel: [ 4586.901180] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:46:12 rh050 kernel: [ 4586.901272] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:46:12 rh050 kernel: [ 4586.901280] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:46:23 rh050 kernel: [ 4586.901283] [drm] Bailing on TDR for s_job:4d2, as another already in progress
Sep 10 09:46:23 rh050 kernel: [ 4597.141105] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:46:23 rh050 kernel: [ 4597.141197] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:46:23 rh050 kernel: [ 4597.141204] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:46:33 rh050 kernel: [ 4597.141207] [drm] Bailing on TDR for s_job:4d3, as another already in progress
Sep 10 09:46:33 rh050 kernel: [ 4607.381004] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:46:33 rh050 kernel: [ 4607.381097] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:46:33 rh050 kernel: [ 4607.381104] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:46:43 rh050 kernel: [ 4607.381106] [drm] Bailing on TDR for s_job:4d4, as another already in progress
Sep 10 09:46:43 rh050 kernel: [ 4617.620748] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:46:43 rh050 kernel: [ 4617.620840] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:46:43 rh050 kernel: [ 4617.620847] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 09:46:53 rh050 kernel: [ 4617.620850] [drm] Bailing on TDR for s_job:4d5, as another already in progress
Sep 10 09:46:53 rh050 kernel: [ 4627.860707] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma1 timeout, signaled seq=1643, emitted seq=1643
Sep 10 09:46:53 rh050 kernel: [ 4627.860799] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process Xorg pid 4151 thread Xorg:cs0 pid 4375
Sep 10 09:46:53 rh050 kernel: [ 4627.860807] amdgpu 0000:0c:00.0: GPU reset begin!
Sep 10 10:00:13 rh050 hddtemp[4090]: /dev/sda: CT500MX500SSD1: 33 C
Sep 10 10:00:13 rh050 hddtemp[4090]: /dev/sdb: Crucial_CT1050MX300SSD1: 26 C
Sep 10 10:00:13 rh050 hddtemp[4090]: /dev/sdc: Crucial_CT512MX100SSD1: 39 C
Sep 10 10:00:13 rh050 hddtemp[4090]: /dev/sde: CT2000MX500SSD1: 33 C
Sep 10 10:00:13 rh050 hddtemp[4090]: /dev/sdf: WDC WD4001FFSX-68JNUN0: 39 C
Same issue before with ASCII. Does not happen every day, more once a month, but its not nice. Looks like the underground processes like hddtemp still are working, but the computer isn't usable any more, no reaction to mouse and keyboard.
I don't blame Beowulf, its a HW problem.
#6 2020-09-11 07:13:48
larsH
Hi
Have you tried with the backports kernel and drivers. It is quite wellknown that kernel 4.19 is a bit to old to support Ryzen 2700X. And there have been reported numerous problems with that should be solved by now.
Have a nice day
Lars H
#7 2020-09-11 17:21:42
# inxi -F
System:    Host: rh050 Kernel: 5.7.0-0.bpo.2-amd64 x86_64 bits: 64 Desktop: MATE 1.20.4 Distro: Devuan GNU/Linux 3 (beowulf)
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x serial: 180529428800462 UEFI: American Megatrends
           v: 5406 date: 11/13/2019
CPU:       Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP L2 cache: 4096 KiB
           Speed: 1915 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 1883 2: 1890 3: 2094 4: 2080 5: 2088 6: 2106 7: 2096
           8: 2187 9: 1889 10: 1887 11: 1884 12: 1889 13: 1890 14: 1956 15: 2126 16: 2088
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480] driver: amdgpu v: kernel
           Display: server: X.Org 1.20.4 driver: amdgpu,ati unloaded: fbdev,modesetting,vesa resolution: 2560x1440~60Hz
           OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.37.0 5.7.0-0.bpo.2-amd64 LLVM 7.0.1) v: 4.5 Mesa 18.3.6
Also refer to https://dev1galaxy.org/viewtopic.php?id=3616
#8 2020-09-11 19:50:45
The only time I had problems with devuan beowulf so far is when i switch from openrc to runit... hmm
#9 2020-09-11 22:05:17
I'm using backports kernel, and the newest nVidia drivers in the .run package from nVidia's website.
glenn@GamesBox ~ $ inxi -F
System:    Host: GamesBox Kernel: 5.7.0-0.bpo.2-amd64 x86_64 bits: 64 Desktop: KDE Plasma 5.14.5
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG STRIX X470-F GAMING v: Rev X.0x serial: <root required>
           UEFI [Legacy]: American Megatrends v: 5406 date: 11/13/2019
           Speed: 1913 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 1990 2: 1979 3: 2001 4: 2055 5: 1895 6: 1937 7: 2193
           8: 2078 9: 1964 10: 1912 11: 2032 12: 1912 13: 2190 14: 2139 15: 2045 16: 2188
Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 450.57
           Display: x11 server: X.Org 1.20.4 driver: nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 450.57
Audio:     Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
           Device-2: Roland EDIROL UA-25EX type: USB driver: snd-usb-audio
           Sound Server: ALSA v: k5.7.0-0.bpo.2-amd64
Network:   Device-1: Intel Wireless-AC 9260 driver: iwlwifi
I get occasional lockups in my web-browser Palemoon when using facebook.
I suspect facebook is sucking the life out of me and my computer, but I digress.
#10 2020-09-12 02:56:05
I have only installed proprietary drivers two times on computers, on one it was an hp laptop. Debian and devuan, didn't matter, it was so buggy that even a wifi adapter usb doesn't help. Thus that particular laptop is stuck with ethernet only wifi. Why bother with a wifi blob if it only works for the first 15 mins of being booted after all... smile
The other time though I used the blob was on an old desktop pc, for booting it up.  And there were no issues
Does your laptop function without nvidia, if so, I recommend it. proprietary blobs have unknown consequences. Security/privacy and who knows what else.
That's just me though, I am sure you are aware of this though.
I just wondered why anyone would take that risk.  Then again I use a thinkpad x200 libreboot (Hyperbola) on the daily for certain things.
For gaming, such as wine, I use x230 thinkpad (devuan)
But that all being said, if you don't need it, I would avoid it.
I hope you figure out what to do.... smile
I suppose you could try testing version.
Just don't use ceres. wink  that would be really, really dumb.
#11 2020-09-12 17:32:17
Have you installed the CPU µcode package?
https://pkginfo.devuan.org/stage/beowul … 128.1.html
https://pkginfo.devuan.org/stage/beowul … b10u1.html
#12 2020-09-13 23:09:42
zapper...
This post is about my desktop system, I play OTTD and CounterStrike Source. The Graphics driver helps with CS:S, but it's so old the other drivers work fine, I find it easier to manage kernel and nVidia updates manually.
The desktop system is my entertainment system, constant music (streaming 4zzz radio, and my enormous cd collection), videos, games and web-browsing.
My laptop runs the same OS, but I don't bother with the graphics modules as I only use it in emergencies and occasional couch surfing.
It has an intel onboard and a nVidia card, I think it's able to switch on loading... but that maybe a m$Win thing, it had win7 and 10 on it at first.
Wireless was the main reason I went to backports, to tether off my iPhone :-) (Thanks to this site I got a "reliable" connection happening)
Anyhow, I haven't seen any security probs with the nVidia .run installs, it seems simpler to me (than dkms)... But I keep my eyes open and never stop learning about our operating systems and desktops.
Thanks for everything, Your mileage, of course may vary.
Best regards, Glenn
#13 2020-09-14 11:45:30
F_Sauce
I run the proprietary NVIDIA driver without any issues on Beowulf, no lock-ups on my two computers I run this OS on (NVIDIA 970 and 760, respectively); I use the NVIDIA packages from the repo.
One thing though, if one has enabled the «backports» repo when installing the NVIDIA driver packages one might come into package conflicts; at least that was my experience a couple of times in ASCII. If this is the case, one might try removing all NVIDIA packages, disable «backports» and try again.
Just a suggestion.
Cheers,
Olav
I'm on Devuan with KDE
#14 2020-09-15 07:23:25
GlennW wrote:
zapper...
Best regards, Glenn
Ah, okay...   Well,  if it works for ya, good.  I don't trust blobs myself, if I think they are related to network or have a remote weakness.  But if its fine for you, by all means. That's just my view. heh...
