#1 2020-09-06 08:54:58
brocashelm
Post Your Sources List
I saw this on a different forum, so I figured this thread would be interesting to see what we're all using to pull in packages and updates from.
When I installed Beowulf, I had the security, backports, and updates branches thrown in for good measure. Now that I'm predominantly on Ceres, those are no longer necessary. I also like to keep all my sources on the same file, rather than individual files per repository. It just makes things a lot simpler.
I added WineHQ's repository to get the most out of my Wine-dependent programs, and Pale Moon is the least sucky graphical browser in my opinion.
deb http://deb.devuan.org/merged ceres main contrib non-free
deb https://dl.winehq.org/wine-builds/debian/ bullseye main
deb https://download.opensuse.org/repositories/home:/stevenpusser/Debian_Unstable/ /
And, here's my permanent Systemd blacklist (just in case I decide to add MX GNU/Linux repositories for the GUI tools):
Package: systemd
Pin: release *
Pin-Priority: -1
Package: *systemd*
Pin: release *
Pin-Priority: -1
Package: systemd:amd64
Pin: release *
Pin-Priority: -1
Package: systemd:i386
Pin: release *
Pin-Priority: -1
#2 2020-09-06 09:04:44
Re: Post Your Sources List
With apologies for the off-topic post:
Note that MX apply an epoch to their GRUB packages so if you add their repositories then those will be "upgraded" to the MX versions even in a ceres system.
See http://forums.debian.net/viewtopic.php?f=16&t=146083 for a way to pin MX packages so that they are treated in the same way as backports, that will prevent any inadvertent changes.
#3 2020-09-06 10:36:34
brocashelm
Thanks for the heads-up. I remember reading the thread before, but forgot about the pinning specifics for MX GNU/Linux. Nevertheless, the Systemd pinning is crucial when including repositories such as those in.
#4 2020-09-06 18:34:23
Magnus
My personal configuration:
/etc/apt/sources.list
### deb http://auto.mirror.devuan.org/merged/ ceres main non-free contrib
deb http://deb.devuan.org/merged ceres main non-free contrib
### deb-src http://deb.devuan.org/merged ceres main non-free contrib
### deb http://se.mirror.devuan.org/merged/ ceres main non-free contrib
deb http://http.debian.net/debian experimental main non-free contrib
### deb http://http.debian.net/debian testing main non-free contrib
### deb http://deb.devuan.org/merged testing main non-free contrib
### deb http://se.mirror.devuan.org/merged/ ascii main non-free contrib
### deb http://se.mirror.devuan.org/merged/ jessie main non-free contrib
### Oomox ###
### https://github.com/themix-project/oomox/releases
### deb http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu xenial main
### deb-src http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu xenial main
deb https://apt.svtplay-dl.se/ svtplay-dl release
### deb https://www.deb-multimedia.org sid main non-free
#UBUNTU
### deb http://us.archive.ubuntu.com/ubuntu/ groovy universe restricted multiverse
### deb-src http://us.archive.ubuntu.com/ubuntu/ cosmic universe
### Dark Table
### deb http://download.opensuse.org/repositories/graphics:/darktable:/master/Debian_Unstable/ /
deb http://download.opensuse.org/repositories/graphics:/darktable/Debian_Next/ /
Have the extra, commented out, repositories in case I want or need a specific package.
/etc/apt/apt.conf.d/99myown
Acquire::AllowInsecureRepositories	"true";
/etc/apt/preferences.d/xfce4-from-experimental
Package: libxfce4panel-2.0-4
Pin: release a=experimental
Pin-Priority: 800
Package: libxfce4ui-1-0
Pin-Priority: 800
Package: libxfce4ui-2-0
Pin-Priority: 800
Package: libxfce4ui-common
Pin-Priority: 800
Package: libxfce4ui-utils
Pin-Priority: 800
Package: libxfce4util-bin
Pin-Priority: 800
Package: libxfce4util-common
Pin-Priority: 800
Package: libxfce4util7
Pin-Priority: 800
Package: libxfconf-0-3
Pin-Priority: 800
Package: xfce4-appfinder
Pin-Priority: 800
Package: xfce4-panel
Pin-Priority: 800
Package: xfce4-sensors-plugin
Pin-Priority: 800
Package: xfce4-session
Pin-Priority: 800
Package: xfce4-settings
Pin-Priority: 800
Package: xfce4-weather-plugin
Pin-Priority: 800
Package: xfconf
Pin-Priority: 800
Package: xfdesktop4
Pin-Priority: 800
Package: xfdesktop4-data
Pin-Priority: 800
Package: xfwm4
Pin-Priority: 800
#5 2020-09-07 00:08:15
sgage
My sources.list is pretty plain vanilla:
deb http://deb.devuan.org/merged beowulf main non-free contrib
#deb-src http://deb.devuan.org/merged beowulf main non-free contrib
deb http://deb.devuan.org/merged beowulf-security main non-free contrib
#deb-src http://deb.devuan.org/merged beowulf-security main non-free contrib
deb http://deb.devuan.org/merged beowulf-updates main non-free contrib
#deb-src http://deb.devuan.org/merged beowulf-updates main non-free contrib
deb http://deb.devuan.org/merged beowulf-backports main non-free contrib
[Edit: just remembered that this is in sources.list.d, for Pale Moon:]
deb http://download.opensuse.org/repositories/home:/stevenpusser/Debian_10 /
#6 2020-09-07 13:24:03
My Beowulf sources list...
# Beowulf
deb http://au.deb.devuan.org/merged/ beowulf main non-free contrib
deb http://au.deb.devuan.org/merged/ beowulf-security main non-free contrib
deb http://au.deb.devuan.org/merged/ beowulf-updates main non-free contrib
deb http://au.deb.devuan.org/merged/ beowulf-backports main non-free contrib
deb http://au.deb.devuan.org/merged/ beowulf-proposed-updates main non-free contrib
seems to be working ok. Thank you very much.
#7 2020-09-07 15:50:13
Nili
✓ nili@ ~ $ list
# Installed Date 13-08-2020 (stable)
# Upgraded Testing Date 20-08-2020 (chimaera)
# deb cdrom:[Devuan GNU/Linux 3.0 (beowulf) amd64 - netinstall 20200526]/ beowulf contrib main non-free
I started with NETINST stable then passed to testing on the specified dates. I have a single line because of testing repo.
#8 2020-09-07 21:58:14
ComputerBob
Like I'm guessing many (most?) other users, I use the standard repos, as suggested by the Devuan site.
ComputerBob - Making Geek-Speak Chic (TM)
ComputerBob.com - Nearly 6,000 Posts and over 23 Million Views since 1998
My Massive Second Stroke
Help! (off-topic)
#9 2020-09-08 06:17:26
My thinkpad x230 is on chimaera  devuan due to some issues I had with changing from openrc to runit and also like the poster, I also have the same wine repo,
But I also have jxself.org's linux-libre repo.  I will post the exacts later, I am not using that laptop right now wink
This is being typed from my x200 thinkpad. The one with Hyperbola.
#10 2020-09-08 18:58:05
xinomilo
Unknown
mixed ceres/testing(chimaera)
# devuan ceres
# devuan chimaera
## some 3rd party repos (use at your own risk):
# linux-libre freesh
deb mirror://linux-libre.fsfla.org/pub/linux-libre/freesh/mirrors.txt freesh main
# kali testing repo for some security tools
deb http://http.kali.org/kali kali-rolling main non-free contrib
# signal-desktop
deb [arch=amd64] https://updates.signal.org/desktop/apt/ xenial main
# tor project
deb https://deb.torproject.org/torproject.org/ sid main
#11 2020-09-09 05:17:39
deb http://deb.devuan.org/merged/ chimaera  main
deb-src http://deb.devuan.org/merged/ chimaera main
deb http://deb.devuan.org/merged/ chimaera-security main
deb-src http://deb.devuan.org/merged/ chimaera-security main
# beowulf-updates, previously known as 'volatile'
deb http://deb.devuan.org/merged/ chimaera-updates main
deb-src http://deb.devuan.org/merged/ chimaera-updates main
deb https://mirror.cyberbits.eu/linux-libre/freesh/ freesh main
These are my sources
However I think the testing version must not have a security repo, because chimaera-security always gives errors. hmm
aka 404 not found.
#12 2020-09-09 11:41:01
HevyDevy
Pretty standard stable stuff really.
deb http://deb.devuan.org/merged beowulf main contrib
deb http://deb.devuan.org/merged beowulf-security main contrib
deb http://deb.devuan.org/merged beowulf-updates main contrib
deb http://deb.devuan.org/merged beowulf-backports main contrib
I did try out mx linux repos to pull in xfce4 -v 4.14 to see if it could be done but that was just an experiment and not something i would keep long term.
#13 2020-09-09 16:00:03
No, there is no security repository for testing. See https://www.debian.org/security/faq#testing
Nor is there a testing-updates repository. You might want to also read https://www.debian.org/doc/manuals/debi … .html#s3.1
The links are from the Debian FAQs but the information also applies to Devuan.
#14 2020-09-09 21:43:58
Ah, okay, I wonder why i dont get errors from the testing-updates repo then... weird... very "weird"]
Although maybe I do and haven't noticed... wink
