#1 2020-09-06 05:31:42
mark0x01
evolution email install
I'm having issues installing evolution email package on beowulf.
The install fails in evolution-common with:
Unpacking evolution-common (3.30.5-1.1) ...
dpkg: error processing archive /var/cache/apt/archives/evolution-common_3.30.5-1.1_all.deb (--unpack):
 unable to open '/usr/share/help/ru/evolution/import-single-files.page.dpkg-new': Operation not permitted
some of the paths referenced did not exist, and creating them progressed things further, but only until the next error
 unable to open '/usr/share/help/el/evolution/tasks-usage.page.dpkg-new': Operation not permitted
If it is run again, the failing file and sometimes path changes.
They all seem to be related to help.
I have eventually managed to remove the mess left after each attempt.
sudo apt autoremove
Building dependency tree
  bogofilter bogofilter-bdb bogofilter-common evolution-data-server evolution-data-server-common libcamel-1.2-62 libchamplain-0.12-0
  libchamplain-gtk-0.12-0 libebackend-1.2-10 libebook-1.2-19 libebook-contacts-1.2-2 libecal-1.2-19 libedata-book-1.2-25
  libedata-cal-1.2-29 libedataserver-1.2-23 libedataserverui-1.2-2 libgnome-autoar-0-0 libgnome-autoar-gtk-0-0 libphonenumber7 libpst4
  libytnef0
0 upgraded, 0 newly installed, 21 to remove and 3 not upgraded.
Can anyone suggest a solution?
I'm looking at an alternative, as my thunderbird frequently just dies when fetching mail.
Mark.
#2 2020-09-06 05:59:36
Geoff 42
Re: evolution email install
There is a discussion about which email client to use :-
https://dev1galaxy.org/viewtopic.php?id=3119
Geoff
#3 2020-09-06 09:27:28
I am using evolution on Beowulf with Mate desktop, works. Just tried on a new computer with Beowulf and Cinnamon desktop, install is fine too.
I would first of all look at at the free space on your partitions, and then possibly at user rights.
#4 2020-09-06 11:58:58
Marjorie
Likewise I have evolution for mail, running under Cinnamon (where it's been the default for a long time). Now installed in Beowulf, previously in ASCII and Mint 17.3 and Ubuntu before that.
I have the same package version as you: evolution-common 3:30.5-1.1
Looking at the installed files list there's a
/usr/share/help/ru/evolution/import-single-files.page file but not a
/usr/share/help/ru/evolution/import-single-files.page.dpkg-new.
and a
/usr/share/help/el/evolution/tasks-usage.page but not a
/usr/share/help/el/evolution/tasks-usage.page.dpkg-new.
so something seems to be going wrong in dpkg: I don't know enough about dpkg to say whether we should expect it to produce temp files with these names.
#5 2020-09-06 12:44:38
Can we see
findmnt
findmnt -s
findmnt -D
Yes, that's normal: https://raphaelhertzog.com/2011/07/18/d … -dpkg-new/
