#1 2020-09-03 19:30:15
orbanbalage
Wifi disabled on boot – wlan soft blocked, how to determine why?
Installed Beowulf with XFCE.
Enabled Wifi adapter in wicd, connected to network and set to always connect.
However after reboot the wireless adapter is always disabled. I am able to turn it on in wicd, or remove the soft block with rfkill; but how to troubleshoot the reason?
I've tried removing the ath10k_pci kernel module, but that way there is no replacement, so no wifi. Not sure what to do.
[    0.000000] Linux version 4.19.0-10-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.132-1 (2020-07-24)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-4.19.0-10-amd64 root=/dev/mapper/devuan--S145--vg-root ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040400000-0x00000000736fefff] usable
[    0.000000] BIOS-e820: [mem 0x00000000736ff000-0x00000000736fffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000073700000-0x0000000073700fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000073701000-0x0000000075387fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000075388000-0x0000000075c87fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000075c88000-0x000000008be9dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000008be9e000-0x000000008c09dfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008c09e000-0x000000008c88dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008c88e000-0x000000008cf7dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008cf7e000-0x000000008cffdfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008cffe000-0x000000008cffefff] usable
[    0.000000] BIOS-e820: [mem 0x000000008cfff000-0x000000008fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fe7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffa10000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000026effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.50 by INSYDE Corp.
[    0.000000] efi:  ACPI 2.0=0x8cffd014  SMBIOS=0x8c102000  SMBIOS 3.0=0x8c100000  ESRT=0x8c0fea58
[    0.000000] secureboot: Secure boot could not be determined (mode 0)
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: LENOVO 81VD/LNVNB161216, BIOS CSCN09WW 07/25/2019
[    0.000000] tsc: Detected 2300.000 MHz processor
[    0.000000] tsc: Detected 2304.000 MHz TSC
[    0.000000] [Firmware Bug]: TSC ADJUST: CPU0: -1881674994 force to 0
[    0.000808] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000809] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000818] last_pfn = 0x26f000 max_arch_pfn = 0x400000000
[    0.000822] MTRR default type: write-back
[    0.000823] MTRR fixed ranges enabled:
[    0.000824]   00000-9FFFF write-back
[    0.000825]   A0000-BFFFF uncachable
[    0.000826]   C0000-FFFFF write-protect
[    0.000827] MTRR variable ranges enabled:
[    0.000828]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.000829]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.000830]   2 base 0090000000 mask 7FF0000000 uncachable
[    0.000831]   3 base 008E000000 mask 7FFE000000 uncachable
[    0.000832]   4 base 008D800000 mask 7FFF800000 uncachable
[    0.000832]   5 disabled
[    0.000832]   6 disabled
[    0.000833]   7 disabled
[    0.000833]   8 disabled
[    0.000834]   9 disabled
[    0.001938] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002142] last_pfn = 0x8cfff max_arch_pfn = 0x400000000
[    0.011166] esrt: Reserving ESRT space from 0x000000008c0fea58 to 0x000000008c0feab8.
[    0.011175] Using GB pages for direct mapping
[    0.011430] RAMDISK: [mem 0x34953000-0x364a0fff]
[    0.011439] ACPI: Early table checksum verification disabled
[    0.011442] ACPI: RSDP 0x000000008CFFD014 000024 (v02 LENOVO)
[    0.011446] ACPI: XSDT 0x000000008CFC4188 000114 (v01 LENOVO CB-01    00000001      01000013)
[    0.011451] ACPI: FACP 0x000000008CFEE000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011455] ACPI: DSDT 0x000000008CFCA000 020498 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011458] ACPI: FACS 0x000000008CF57000 000040
[    0.011460] ACPI: UEFI 0x000000008CFFC000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011462] ACPI: UEFI 0x000000008CFFB000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011465] ACPI: POAT 0x000000008CFFA000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011467] ACPI: SSDT 0x000000008CFF9000 0004C3 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011469] ACPI: SSDT 0x000000008CFF8000 000046 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011471] ACPI: TPM2 0x000000008CFF7000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011474] ACPI: SSDT 0x000000008CFF3000 003104 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011476] ACPI: ASF! 0x000000008CFF2000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011478] ACPI: ASPT 0x000000008CFF1000 000034 (v07 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011481] ACPI: BOOT 0x000000008CFF0000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011483] ACPI: DBGP 0x000000008CFEF000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011485] ACPI: HPET 0x000000008CFED000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011487] ACPI: APIC 0x000000008CFEC000 00012C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011490] ACPI: MCFG 0x000000008CFEB000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011492] ACPI: LPIT 0x000000008CFC9000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011494] ACPI: WSMT 0x000000008CFC8000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011496] ACPI: SSDT 0x000000008CFC7000 00029F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011499] ACPI: SSDT 0x000000008CFC6000 000346 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011501] ACPI: SSDT 0x000000008CFC5000 000E41 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011503] ACPI: SSDT 0x000000008CFC3000 0002E9 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011506] ACPI: SSDT 0x000000008CFC2000 00051E (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011508] ACPI: DBGP 0x000000008CFC1000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011510] ACPI: DBG2 0x000000008CFC0000 000054 (v00 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011513] ACPI: SSDT 0x000000008CFBE000 0012E6 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011515] ACPI: SSDT 0x000000008CFBC000 0017AE (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011517] ACPI: SSDT 0x000000008CFB8000 003B4F (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011519] ACPI: DMAR 0x000000008CFB7000 0000A8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011522] ACPI: FPDT 0x000000008CFB6000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011524] ACPI: BGRT 0x000000008CFB5000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.011531] ACPI: Local APIC address 0xfee00000
[    0.011714] No NUMA configuration found
[    0.011715] Faking a node at [mem 0x0000000000000000-0x000000026effffff]
[    0.011719] NODE_DATA(0) allocated [mem 0x26effb000-0x26effffff]
[    0.011743] Zone ranges:
[    0.011743]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.011745]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.011745]   Normal   [mem 0x0000000100000000-0x000000026effffff]
[    0.011746]   Device   empty
[    0.011747] Movable zone start for each node
[    0.011748] Early memory node ranges
[    0.011749]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.011749]   node   0: [mem 0x0000000000059000-0x000000000009dfff]
[    0.011750]   node   0: [mem 0x0000000000100000-0x000000003fffffff]
[    0.011751]   node   0: [mem 0x0000000040400000-0x00000000736fefff]
[    0.011751]   node   0: [mem 0x0000000073701000-0x0000000075387fff]
[    0.011752]   node   0: [mem 0x0000000075c88000-0x000000008be9dfff]
[    0.011752]   node   0: [mem 0x000000008cffe000-0x000000008cffefff]
[    0.011753]   node   0: [mem 0x0000000100000000-0x000000026effffff]
[    0.012153] Zeroed struct page in unavailable ranges: 24263 pages
[    0.012154] Initmem setup node 0 [mem 0x0000000000001000-0x000000026effffff]
[    0.012155] On node 0 totalpages: 2072889
[    0.012157]   DMA zone: 64 pages used for memmap
[    0.012157]   DMA zone: 22 pages reserved
[    0.012158]   DMA zone: 3996 pages, LIFO batch:0
[    0.012262]   DMA32 zone: 8839 pages used for memmap
[    0.012263]   DMA32 zone: 565661 pages, LIFO batch:63
[    0.027015]   Normal zone: 23488 pages used for memmap
[    0.027016]   Normal zone: 1503232 pages, LIFO batch:63
[    0.061107] Reserving Intel graphics memory at [mem 0x8e000000-0x8fffffff]
[    0.061432] ACPI: PM-Timer IO Port: 0x1808
[    0.061433] ACPI: Local APIC address 0xfee00000
[    0.061439] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.061440] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.061441] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.061441] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.061442] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.061442] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.061443] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.061443] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.061444] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.061444] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.061445] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.061445] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.061446] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.061446] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.061447] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.061448] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.061478] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.061480] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.061482] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.061483] ACPI: IRQ0 used by override.
[    0.061484] ACPI: IRQ9 used by override.
[    0.061485] Using ACPI (MADT) for SMP configuration information
[    0.061487] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.061495] e820: update [mem 0x7c787000-0x7c87afff] usable ==> reserved
[    0.061505] TSC deadline timer available
[    0.061506] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.061530] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.061532] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.061533] PM: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.061535] PM: Registered nosave memory: [mem 0x40000000-0x403fffff]
[    0.061536] PM: Registered nosave memory: [mem 0x736ff000-0x736fffff]
[    0.061537] PM: Registered nosave memory: [mem 0x73700000-0x73700fff]
[    0.061538] PM: Registered nosave memory: [mem 0x75388000-0x75c87fff]
[    0.061539] PM: Registered nosave memory: [mem 0x7c787000-0x7c87afff]
[    0.061541] PM: Registered nosave memory: [mem 0x8be9e000-0x8c09dfff]
[    0.061542] PM: Registered nosave memory: [mem 0x8c09e000-0x8c88dfff]
[    0.061542] PM: Registered nosave memory: [mem 0x8c88e000-0x8cf7dfff]
[    0.061543] PM: Registered nosave memory: [mem 0x8cf7e000-0x8cffdfff]
[    0.061544] PM: Registered nosave memory: [mem 0x8cfff000-0x8fffffff]
[    0.061545] PM: Registered nosave memory: [mem 0x90000000-0xdfffffff]
[    0.061545] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.061546] PM: Registered nosave memory: [mem 0xf0000000-0xfcffffff]
[    0.061546] PM: Registered nosave memory: [mem 0xfd000000-0xfe7fffff]
[    0.061547] PM: Registered nosave memory: [mem 0xfe800000-0xfebfffff]
[    0.061547] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.061548] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.061548] PM: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.061549] PM: Registered nosave memory: [mem 0xfed01000-0xfed0ffff]
[    0.061549] PM: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.061550] PM: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[    0.061550] PM: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[    0.061551] PM: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[    0.061551] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.061552] PM: Registered nosave memory: [mem 0xfee01000-0xffa0ffff]
[    0.061552] PM: Registered nosave memory: [mem 0xffa10000-0xffffffff]
[    0.061554] [mem 0x90000000-0xdfffffff] available for PCI devices
[    0.061555] Booting paravirtualized kernel on bare hardware
[    0.061558] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.163539] random: get_random_bytes called from start_kernel+0x93/0x52f with crng_init=0
[    0.163548] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.163719] percpu: Embedded 45 pages/cpu s144408 r8192 d31720 u524288
[    0.163727] pcpu-alloc: s144408 r8192 d31720 u524288 alloc=1*2097152
[    0.163728] pcpu-alloc: [0] 0 1 2 3
[    0.163751] Built 1 zonelists, mobility grouping on.  Total pages: 2040476
[    0.163752] Policy zone: Normal
[    0.163753] Kernel command line: BOOT_IMAGE=/vmlinuz-4.19.0-10-amd64 root=/dev/mapper/devuan--S145--vg-root ro quiet
[    0.167456] Calgary: detecting Calgary via BIOS EBDA area
[    0.167457] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.188675] Memory: 7978056K/8291556K available (10252K kernel code, 1241K rwdata, 3316K rodata, 1592K init, 2272K bss, 313500K reserved, 0K cma-reserved)
[    0.188752] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.188774] Kernel/User page tables isolation: enabled
[    0.196265] ftrace: allocating 31900 entries in 125 pages
[    0.209649] rcu: Hierarchical RCU implementation.
[    0.209650] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.209651] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.212690] NR_IRQS: 33024, nr_irqs: 1024, preallocated irqs: 16
[    0.213009] Console: colour dummy device 80x25
[    0.213013] console [tty0] enabled
[    0.213033] ACPI: Core revision 20180810
[    0.213440] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.213472] hpet clockevent registered
[    0.213533] APIC: Switch to symmetric I/O mode setup
[    0.213535] DMAR: Host address width 39
[    0.213536] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.213543] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.213544] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.213548] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.213549] DMAR: RMRR base: 0x0000008c775000 end: 0x0000008c794fff
[    0.213550] DMAR: RMRR base: 0x0000008d800000 end: 0x0000008fffffff
[    0.213551] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.213552] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.213553] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.215152] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.215154] x2apic enabled
[    0.215168] Switched APIC routing to cluster x2apic.
[    0.219138] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.237486] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[    0.237500] Calibrating delay loop (skipped), value calculated using timer frequency.. 4608.00 BogoMIPS (lpj=9216000)
[    0.237502] pid_max: default: 32768 minimum: 301
[    0.238914] Security Framework initialized
[    0.238917] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.238936] AppArmor: AppArmor initialized
[    0.239997] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.240546] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.240572] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.240604] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.240817] CPU0: Thermal monitoring enabled (TM1)
[    0.240834] process: using mwait in idle threads
[    0.240836] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.240837] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.240838] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.240839] Spectre V2 : Mitigation: Full generic retpoline
[    0.240840] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.240840] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.240848] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.240848] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.240849] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.240874] SRBDS: Vulnerable: No microcode
[    0.240875] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[    0.244605] Freeing SMP alternatives memory: 24K
[    0.254477] smpboot: CPU0: Intel(R) Core(TM) i3-7020U CPU @ 2.30GHz (family: 0x6, model: 0x8e, stepping: 0x9)
[    0.254558] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.254591] ... version:                4
[    0.254592] ... bit width:              48
[    0.254592] ... generic registers:      4
[    0.254593] ... value mask:             0000ffffffffffff
[    0.254593] ... max period:             00007fffffffffff
[    0.254594] ... fixed-purpose events:   3
[    0.254594] ... event mask:             000000070000000f
[    0.254633] rcu: Hierarchical SRCU implementation.
[    0.255034] random: crng done (trusting CPU's manufacturer)
[    0.255329] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.255366] smp: Bringing up secondary CPUs ...
[    0.255431] x86: Booting SMP configuration:
[    0.255432] .... node  #0, CPUs:      #1
[    0.004499] [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
[    0.255883]  #2
[    0.255883] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.255883]  #3
[    0.255883] smp: Brought up 1 node, 4 CPUs
[    0.255883] smpboot: Max logical packages: 1
[    0.255883] smpboot: Total of 4 processors activated (18432.00 BogoMIPS)
[    0.257771] devtmpfs: initialized
[    0.257771] x86/mm: Memory block size: 128MB
[    0.258230] PM: Registering ACPI NVS region [mem 0x736ff000-0x736fffff] (4096 bytes)
[    0.258230] PM: Registering ACPI NVS region [mem 0x8c88e000-0x8cf7dfff] (7274496 bytes)
[    0.258230] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.258230] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.258230] pinctrl core: initialized pinctrl subsystem
[    0.258230] NET: Registered protocol family 16
[    0.258230] audit: initializing netlink subsys (disabled)
[    0.258230] audit: type=2000 audit(1599160767.044:1): state=initialized audit_enabled=0 res=1
[    0.258230] cpuidle: using governor ladder
[    0.258230] cpuidle: using governor menu
[    0.258230] Simple Boot Flag at 0x44 set to 0x1
[    0.258230] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.258230] ACPI: bus type PCI registered
[    0.258230] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.258230] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.258230] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.258230] PCI: Using configuration type 1 for base access
[    0.258230] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.258230] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.258230] ACPI: Added _OSI(Module Device)
[    0.258230] ACPI: Added _OSI(Processor Device)
[    0.258230] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.258230] ACPI: Added _OSI(Processor Aggregator Device)
[    0.258230] ACPI: Added _OSI(Linux-Dell-Video)
[    0.258230] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.294691] ACPI: 12 ACPI AML tables successfully acquired and loaded
[    0.297781] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.301507] ACPI: Dynamic OEM Table Load:
[    0.301522] ACPI: SSDT 0xFFFF8C7E24C35000 00060F (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.301949] ACPI: \_PR_.PR00: _OSC native thermal LVT Acked
[    0.302817] ACPI: Dynamic OEM Table Load:
[    0.302825] ACPI: SSDT 0xFFFF8C7E24C68000 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.303233] ACPI: Dynamic OEM Table Load:
[    0.303239] ACPI: SSDT 0xFFFF8C7E24CF8B40 0000BA (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
[    0.303555] ACPI: Dynamic OEM Table Load:
[    0.303561] ACPI: SSDT 0xFFFF8C7E24C34000 000628 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
[    0.304195] ACPI: Dynamic OEM Table Load:
[    0.304204] ACPI: SSDT 0xFFFF8C7E26520000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.305104] ACPI: Dynamic OEM Table Load:
[    0.305110] ACPI: SSDT 0xFFFF8C7E24C6AC00 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
[    0.305530] ACPI: Dynamic OEM Table Load:
[    0.305536] ACPI: SSDT 0xFFFF8C7E24C68400 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.307066] ACPI: EC: EC started
[    0.307066] ACPI: EC: interrupt blocked
[    0.307324] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
[    0.307325] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x4f, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.307327] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
[    0.307327] ACPI: Interpreter enabled
[    0.307383] ACPI: (supports S0 S3 S4 S5)
[    0.307384] ACPI: Using IOAPIC for interrupt routing
[    0.307423] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.307963] ACPI: Enabled 6 GPEs in block 00 to 7F
[    0.314372] ACPI: Power Resource [WRST] (on)
[    0.326122] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.326127] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.329117] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.329118] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.331187] PCI host bridge to bus 0000:00
[    0.331189] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.331190] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.331191] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.331192] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.331193] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.331194] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.331194] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.331195] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.331196] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.331197] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.331198] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.331199] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[    0.331200] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.331201] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.331210] pci 0000:00:00.0: [8086:5904] type 00 class 0x060000
[    0.332012] pci 0000:00:02.0: [8086:5916] type 00 class 0x030000
[    0.332025] pci 0000:00:02.0: reg 0x10: [mem 0xb0000000-0xb0ffffff 64bit]
[    0.332031] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.332036] pci 0000:00:02.0: reg 0x20: [io  0x3000-0x303f]
[    0.332053] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.332856] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.332871] pci 0000:00:04.0: reg 0x10: [mem 0xb1320000-0xb1327fff 64bit]
[    0.333758] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[    0.333781] pci 0000:00:14.0: reg 0x10: [mem 0xb1310000-0xb131ffff 64bit]
[    0.333851] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.334732] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[    0.334761] pci 0000:00:15.0: reg 0x10: [mem 0xb1332000-0xb1332fff 64bit]
[    0.335666] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[    0.335693] pci 0000:00:16.0: reg 0x10: [mem 0xb1333000-0xb1333fff 64bit]
[    0.335770] pci 0000:00:16.0: PME# supported from D3hot
[    0.336627] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[    0.336647] pci 0000:00:17.0: reg 0x10: [mem 0xb1330000-0xb1331fff]
[    0.336655] pci 0000:00:17.0: reg 0x14: [mem 0xb1336000-0xb13360ff]
[    0.336665] pci 0000:00:17.0: reg 0x18: [io  0x3080-0x3087]
[    0.336674] pci 0000:00:17.0: reg 0x1c: [io  0x3088-0x308b]
[    0.336683] pci 0000:00:17.0: reg 0x20: [io  0x3060-0x307f]
[    0.336692] pci 0000:00:17.0: reg 0x24: [mem 0xb1334000-0xb13347ff]
[    0.336738] pci 0000:00:17.0: PME# supported from D3hot
[    0.337555] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[    0.337640] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.338473] pci 0000:00:1c.4: [8086:9d14] type 01 class 0x060400
[    0.338552] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.339396] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400
[    0.339478] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.340333] pci 0000:00:1f.0: [8086:9d4e] type 00 class 0x060100
[    0.341234] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[    0.341250] pci 0000:00:1f.2: reg 0x10: [mem 0xb132c000-0xb132ffff]
[    0.342100] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040300
[    0.342129] pci 0000:00:1f.3: reg 0x10: [mem 0xb1328000-0xb132bfff 64bit]
[    0.342162] pci 0000:00:1f.3: reg 0x20: [mem 0xb1300000-0xb130ffff 64bit]
[    0.342216] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.343110] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[    0.343170] pci 0000:00:1f.4: reg 0x10: [mem 0xb1335000-0xb13350ff 64bit]
[    0.343239] pci 0000:00:1f.4: reg 0x20: [io  0x3040-0x305f]
[    0.344148] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.344315] pci 0000:02:00.0: [168c:0042] type 00 class 0x028000
[    0.344504] pci 0000:02:00.0: reg 0x10: [mem 0xb1000000-0xb11fffff 64bit]
[    0.345249] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.345827] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.345831] pci 0000:00:1c.4:   bridge window [mem 0xb1000000-0xb11fffff]
[    0.346031] pci 0000:03:00.0: [144d:a809] type 00 class 0x010802
[    0.346061] pci 0000:03:00.0: reg 0x10: [mem 0xb1200000-0xb1203fff 64bit]
[    0.346274] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    0.346278] pci 0000:00:1d.0:   bridge window [mem 0xb1200000-0xb12fffff]
[    0.347512] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.347568] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.347622] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.347675] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.347728] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.347780] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.347832] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.347885] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.348463] ACPI: EC: interrupt unblocked
[    0.348486] ACPI: EC: event unblocked
[    0.348498] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x4f, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.348499] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
[    0.348584] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.348584] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.348584] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.348584] vgaarb: loaded
[    0.348584] pps_core: LinuxPPS API ver. 1 registered
[    0.348584] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.348584] PTP clock support registered
[    0.348584] EDAC MC: Ver: 3.0.0
[    0.348584] Registered efivars operations
[    0.348584] PCI: Using ACPI for IRQ routing
[    0.373076] PCI: pci_cache_line_size set to 64 bytes
[    0.373499] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.373500] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.373501] e820: reserve RAM buffer [mem 0x736ff000-0x73ffffff]
[    0.373502] e820: reserve RAM buffer [mem 0x75388000-0x77ffffff]
[    0.373503] e820: reserve RAM buffer [mem 0x7c787000-0x7fffffff]
[    0.373503] e820: reserve RAM buffer [mem 0x8be9e000-0x8bffffff]
[    0.373504] e820: reserve RAM buffer [mem 0x8cfff000-0x8fffffff]
[    0.373505] e820: reserve RAM buffer [mem 0x26f000000-0x26fffffff]
[    0.377557] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.377560] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.379606] clocksource: Switched to clocksource tsc-early
[    0.386085] VFS: Disk quotas dquot_6.6.0
[    0.386098] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.386189] AppArmor: AppArmor Filesystem Enabled
[    0.386205] pnp: PnP ACPI init
[    0.386298] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[    0.386302] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.386385] system 00:01: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.386386] system 00:01: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.386387] system 00:01: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.386388] system 00:01: [mem 0xfe000000-0xfe01ffff] has been reserved
[    0.386390] system 00:01: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.386391] system 00:01: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.386392] system 00:01: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.386394] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.386697] system 00:02: [io  0x2000-0x20fe] has been reserved
[    0.386699] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.386921] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.386922] system 00:03: [io  0xffff] has been reserved
[    0.386923] system 00:03: [io  0xffff] has been reserved
[    0.386924] system 00:03: [io  0xffff] has been reserved
[    0.386925] system 00:03: [io  0x1800-0x18fe] has been reserved
[    0.386926] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.386929] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.387028] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.387060] system 00:05: [io  0x1854-0x1857] has been reserved
[    0.387063] system 00:05: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.387094] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active)
[    0.388257] system 00:07: [mem 0xfe029000-0xfe029fff] has been reserved
[    0.388258] system 00:07: [mem 0xfe028000-0xfe028fff] has been reserved
[    0.388259] system 00:07: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.388260] system 00:07: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.388261] system 00:07: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.388264] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.388777] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.388778] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.388779] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.388780] system 00:08: [mem 0xe0000000-0xefffffff] has been reserved
[    0.388781] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.388782] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.388784] system 00:08: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.388785] system 00:08: [mem 0xff000000-0xffffffff] could not be reserved
[    0.388786] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.388787] system 00:08: [mem 0x90000000-0x9001ffff] has been reserved
[    0.388790] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.389101] pnp: PnP ACPI: found 9 devices
[    0.394661] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.394678] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    0.394680] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    0.394682] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[    0.394710] pci 0000:00:1c.0: BAR 14: assigned [mem 0x90100000-0x902fffff]
[    0.394717] pci 0000:00:1c.0: BAR 15: assigned [mem 0x90300000-0x904fffff 64bit pref]
[    0.394720] pci 0000:00:1c.0: BAR 13: assigned [io  0x4000-0x4fff]
[    0.394722] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.394729] pci 0000:00:1c.0:   bridge window [io  0x4000-0x4fff]
[    0.394733] pci 0000:00:1c.0:   bridge window [mem 0x90100000-0x902fffff]
[    0.394735] pci 0000:00:1c.0:   bridge window [mem 0x90300000-0x904fffff 64bit pref]
[    0.394740] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.394744] pci 0000:00:1c.4:   bridge window [mem 0xb1000000-0xb11fffff]
[    0.394749] pci 0000:00:1d.0: PCI bridge to [bus 03]
[    0.394760] pci 0000:00:1d.0:   bridge window [mem 0xb1200000-0xb12fffff]
[    0.394767] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.394768] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.394769] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.394770] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.394771] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.394772] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.394773] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.394774] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.394775] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.394776] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.394776] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.394777] pci_bus 0000:00: resource 15 [mem 0x90000000-0xdfffffff window]
[    0.394778] pci_bus 0000:00: resource 16 [mem 0xfd000000-0xfe7fffff window]
[    0.394780] pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
[    0.394780] pci_bus 0000:01: resource 1 [mem 0x90100000-0x902fffff]
[    0.394781] pci_bus 0000:01: resource 2 [mem 0x90300000-0x904fffff 64bit pref]
[    0.394782] pci_bus 0000:02: resource 1 [mem 0xb1000000-0xb11fffff]
[    0.394784] pci_bus 0000:03: resource 1 [mem 0xb1200000-0xb12fffff]
[    0.394905] NET: Registered protocol family 2
[    0.395061] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[    0.395088] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.395180] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.395294] TCP: Hash tables configured (established 65536 bind 65536)
[    0.395321] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.395343] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.395391] NET: Registered protocol family 1
[    0.395395] NET: Registered protocol family 44
[    0.395406] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.397296] PCI: CLS 64 bytes, default 64
[    0.397346] Unpacking initramfs...
[    0.870908] Freeing initrd memory: 27960K
[    0.889543] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.889550] software IO TLB: mapped [mem 0x878f4000-0x8b8f4000] (64MB)
[    0.889620] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[    0.889631] clocksource: Switched to clocksource tsc
[    0.890246] Initialise system trusted keyrings
[    0.890253] Key type blacklist registered
[    0.890296] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[    0.891329] zbud: loaded
[    1.035411] Key type asymmetric registered
[    1.035411] Asymmetric key parser 'x509' registered
[    1.035419] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.035446] io scheduler noop registered
[    1.035447] io scheduler deadline registered
[    1.035472] io scheduler cfq registered (default)
[    1.035473] io scheduler mq-deadline registered
[    1.035837] pcieport 0000:00:1c.0: Signaling PME with IRQ 122
[    1.035868] pciehp 0000:00:1c.0:pcie004: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[    1.036107] pcieport 0000:00:1c.4: Signaling PME with IRQ 123
[    1.036332] pcieport 0000:00:1d.0: Signaling PME with IRQ 124
[    1.036401] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    1.036414] efifb: probing for efifb
[    1.036428] efifb: framebuffer at 0xa0000000, using 8128k, total 8128k
[    1.036429] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    1.036429] efifb: scrolling: redraw
[    1.036430] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    1.040369] Console: switching to colour frame buffer device 240x67
[    1.044217] fb0: EFI VGA frame buffer device
[    1.044225] intel_idle: MWAIT substates: 0x11142120
[    1.044226] intel_idle: v0.4.1 model 0x8E
[    1.044398] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.045090] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.045523] Linux agpgart interface v0.103
[    1.045568] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.045568] AMD IOMMUv2 functionality not available on this system
[    1.045870] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    1.045871] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.054193] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.054430] mousedev: PS/2 mouse device common for all mice
[    1.054950] rtc_cmos 00:04: RTC can wake from S4
[    1.055484] rtc_cmos 00:04: registered as rtc0
[    1.055499] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    1.055508] intel_pstate: Intel P-state driver initializing
[    1.055867] intel_pstate: HWP enabled
[    1.055892] ledtrig-cpu: registered to indicate activity on CPUs
[    1.056297] NET: Registered protocol family 10
[    1.062889] Segment Routing with IPv6
[    1.062911] mip6: Mobile IPv6
[    1.062913] NET: Registered protocol family 17
[    1.063014] mpls_gso: MPLS GSO support
[    1.063370] mce: Using 8 MCE banks
[    1.063401] microcode: sig=0x806e9, pf=0x80, revision=0x8e
[    1.063525] microcode: Microcode Update Driver: v2.2.
[    1.063535] sched_clock: Marking stable (1063021929, 499421)->(1069181010, -5659660)
[    1.063727] registered taskstats version 1
[    1.063727] Loading compiled-in X.509 certificates
[    1.069321] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    1.097269] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.097283] Loaded X.509 cert 'Debian Secure Boot Signer 2020: 00b55eb3b9'
[    1.098623] zswap: loaded using pool lzo/zbud
[    1.098748] AppArmor: AppArmor sha1 policy hashing enabled
[    1.099800] rtc_cmos 00:04: setting system clock to 2020-09-03 19:19:28 UTC (1599160768)
[    1.328162] Freeing unused kernel image memory: 1592K
[    1.349849] Write protecting the kernel read-only data: 16384k
[    1.351007] Freeing unused kernel image memory: 2028K
[    1.351215] Freeing unused kernel image memory: 780K
[    1.358583] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.358584] x86/mm: Checking user space page tables
[    1.365766] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.365768] Run /init as init process
[    1.435728] udevd[104]: starting version 3.2.7
[    1.436918] udevd[105]: starting eudev-3.2.7
[    1.461676] hidraw: raw HID events driver (C) Jiri Kosina
[    1.466941] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    1.466983] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    1.470124] cryptd: max_cpu_qlen set to 1000
[    1.480251] SCSI subsystem initialized
[    1.483875] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    1.484623] ACPI: bus type USB registered
[    1.484647] usbcore: registered new interface driver usbfs
[    1.484658] usbcore: registered new interface driver hub
[    1.484682] usbcore: registered new device driver usb
[    1.491783] AVX2 version of gcm_enc/dec engaged.
[    1.491784] AES CTR mode by8 optimization enabled
[    1.498607] nvme nvme0: pci function 0000:03:00.0
[    1.503899] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.503908] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.504979] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    1.505366] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.505595] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.505597] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.505599] usb usb1: Product: xHCI Host Controller
[    1.505600] usb usb1: Manufacturer: Linux 4.19.0-10-amd64 xhci-hcd
[    1.505601] usb usb1: SerialNumber: 0000:00:14.0
[    1.505773] hub 1-0:1.0: USB hub found
[    1.505791] hub 1-0:1.0: 12 ports detected
[    1.506253] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.506256] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.506259] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.506294] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.506295] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.506296] usb usb2: Product: xHCI Host Controller
[    1.506297] usb usb2: Manufacturer: Linux 4.19.0-10-amd64 xhci-hcd
[    1.506297] usb usb2: SerialNumber: 0000:00:14.0
[    1.506395] hub 2-0:1.0: USB hub found
[    1.506408] hub 2-0:1.0: 6 ports detected
[    1.506514] usb: port power management may be unreliable
[    1.510323] libata version 3.00 loaded.
[    1.514933] ahci 0000:00:17.0: version 3.0
[    1.515234] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    1.515237] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    1.515482] scsi host0: ahci
[    1.515594] ata1: SATA max UDMA/133 abar m2048@0xb1334000 port 0xb1334100 irq 127
[    1.524156] i2c_hid i2c-SYNA2B5F:00: i2c-SYNA2B5F:00 supply vdd not found, using dummy regulator
[    1.524171] i2c_hid i2c-SYNA2B5F:00: Linked as a consumer to regulator.0
[    1.524173] i2c_hid i2c-SYNA2B5F:00: i2c-SYNA2B5F:00 supply vddl not found, using dummy regulator
[    1.529178] alg: No test for pcbc(aes) (pcbc-aes-aesni)
[    1.537793] input: SYNA2B5F:00 06CB:8254 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-SYNA2B5F:00/0018:06CB:8254.0001/input/input1
[    1.537851] hid-generic 0018:06CB:8254.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA2B5F:00 06CB:8254] on i2c-SYNA2B5F:00
[    1.638036] rmi4_f01 rmi4-00.fn01: found RMI device, manufacturer: Synaptics, product: TM3336-004, fw id: 2820786
[    1.715939] nvme nvme0: Shutdown timeout set to 8 seconds
[    1.728410] nvme nvme0: allocated 64 MiB host memory buffer.
[    1.729899] input: Synaptics TM3336-004 as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-SYNA2B5F:00/0018:06CB:8254.0001/input/input3
[    1.729993] hid-rmi 0018:06CB:8254.0001: input,hidraw0: I2C HID v1.00 Mouse [SYNA2B5F:00 06CB:8254] on i2c-SYNA2B5F:00
[    1.791990]  nvme0n1: p1 p2 p3
[    1.830268] ata1: SATA link down (SStatus 4 SControl 300)
[    1.841524] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[    1.992822] usb 1-4: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=22.01
[    1.992825] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.992827] usb 1-4: Product: USB Receiver
[    1.992829] usb 1-4: Manufacturer: Logitech
[    2.002032] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046D:C52F.0002/input/input4
[    2.002185] hid-generic 0003:046D:C52F.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-4/input0
[    2.003637] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52F.0003/input/input5
[    2.031572] device-mapper: uevent: version 1.0.3
[    2.031814] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[    2.062038] hid-generic 0003:046D:C52F.0003: input,hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4/input1
[    2.062096] usbcore: registered new interface driver usbhid
[    2.062097] usbhid: USB HID core driver
[    2.121815] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[    2.272097] usb 1-7: New USB device found, idVendor=0cf3, idProduct=e500, bcdDevice= 0.01
[    2.272101] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.401962] usb 1-8: new high-speed USB device number 4 using xhci_hcd
[    2.572440] usb 1-8: New USB device found, idVendor=13d3, idProduct=5a08, bcdDevice=17.05
[    2.572445] usb 1-8: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.572448] usb 1-8: Product: Integrated Camera
[    2.572450] usb 1-8: Manufacturer: Azurewave
[    2.572452] usb 1-8: SerialNumber: 0x0001
[   90.232618] NET: Registered protocol family 38
[   90.546687] PM: Image not found (code -22)
[   90.701195] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   90.891638] udevd[543]: starting version 3.2.7
[   90.900211] udevd[543]: specified group 'kvm' unknown
[   90.920855] udevd[543]: starting eudev-3.2.7
[   90.974789] ACPI: AC Adapter [ADP0] (on-line)
[   91.130441] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input8
[   91.130450] ACPI: Lid Switch [LID0]
[   91.130509] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input9
[   91.130519] ACPI: Power Button [PWRB]
[   91.145938] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   91.157687] battery: ACPI: Battery Slot [BAT0] (battery present)
[   91.162632] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input10
[   91.184409] media: Linux media interface: v0.10
[   91.194299] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   91.199203] videodev: Linux video capture interface: v2.00
[   91.275137] Bluetooth: Core ver 2.22
[   91.275150] NET: Registered protocol family 31
[   91.275151] Bluetooth: HCI device and connection manager initialized
[   91.275155] Bluetooth: HCI socket layer initialized
[   91.275157] Bluetooth: L2CAP socket layer initialized
[   91.275162] Bluetooth: SCO socket layer initialized
[   91.278890] uvcvideo: Found UVC 1.00 device Integrated Camera (13d3:5a08)
[   91.282413] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[   91.282434] uvcvideo 1-8:1.0: Entity type for entity Extension 4 was not initialized!
[   91.282436] uvcvideo 1-8:1.0: Entity type for entity Processing 2 was not initialized!
[   91.282438] uvcvideo 1-8:1.0: Entity type for entity Camera 1 was not initialized!
[   91.283802] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input11
[   91.283877] usbcore: registered new interface driver uvcvideo
[   91.283878] USB Video Class driver (1.1.1)
[   91.288378] usbcore: registered new interface driver btusb
[   91.320521] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   91.344172] iTCO_vendor_support: vendor-support=0
[   91.369484] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   91.369620] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[   91.369738] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   91.373669] checking generic (a0000000 7f0000) vs hw (a0000000 10000000)
[   91.373671] fb: switching to inteldrmfb from EFI VGA
[   91.373701] Console: switching to colour dummy device 80x25
[   91.373822] [drm] Replacing VGA console driver
[   91.381874] input: PC Speaker as /devices/platform/pcspkr/input/input12
[   91.384424] EFI Variables Facility v0.08 2004-May-17
[   91.385305] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   91.385306] [drm] Driver supports precise vblank timestamp query.
[   91.386040] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   91.388650] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[   91.388656] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[   91.388661] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_04.bin failed with error -2
[   91.388664] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[   91.388666] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[   91.413537] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[   91.431991] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   91.432237] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
[   91.434139] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[   91.434141] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   91.434142] RAPL PMU: hw unit of domain package 2^-14 Joules
[   91.434142] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   91.434143] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   91.434144] RAPL PMU: hw unit of domain psys 2^-14 Joules
[   91.453290] fbcon: inteldrmfb (fb0) is primary device
[   91.531950] pstore: Using compression: deflate
[   91.531967] pstore: Registered efi as persistent store backend
[   91.549726] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   91.684280] intel_rapl: Found RAPL domain package
[   91.684281] intel_rapl: Found RAPL domain core
[   91.684282] intel_rapl: Found RAPL domain uncore
[   91.684284] intel_rapl: Found RAPL domain dram
[   91.827250] ath10k_pci 0000:02:00.0: firmware: failed to load ath10k/pre-cal-pci-0000:02:00.0.bin (-2)
[   91.827258] ath10k_pci 0000:02:00.0: firmware: failed to load ath10k/cal-pci-0000:02:00.0.bin (-2)
[   91.829626] ath10k_pci 0000:02:00.0: firmware: direct-loading firmware ath10k/QCA9377/hw1.0/firmware-6.bin
[   91.829632] ath10k_pci 0000:02:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 17aa:0901
[   91.829634] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 0 tracing 0 dfs 0 testmode 0
[   91.830228] ath10k_pci 0000:02:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[   91.894004] ath10k_pci 0000:02:00.0: firmware: direct-loading firmware ath10k/QCA9377/hw1.0/board-2.bin
[   91.894249] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[   92.488271] ath10k_pci 0000:02:00.0: Unknown eventid: 118809
[   92.491210] ath10k_pci 0000:02:00.0: Unknown eventid: 90118
[   92.492161] ath10k_pci 0000:02:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[   92.494061] ath: EEPROM regdomain: 0x6c
[   92.494062] ath: EEPROM indicates we should expect a direct regpair map
[   92.494063] ath: Country alpha2 being used: 00
[   92.494063] ath: Regpair used: 0x6c
[   92.669227] Console: switching to colour frame buffer device 240x67
[   92.669341] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   92.690060] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   92.699379] snd_hda_codec_generic hdaudioC0D0: autoconfig for Generic: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   92.699380] snd_hda_codec_generic hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   92.699381] snd_hda_codec_generic hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   92.699382] snd_hda_codec_generic hdaudioC0D0:    mono: mono_out=0x0
[   92.699383] snd_hda_codec_generic hdaudioC0D0:    inputs:
[   92.699384] snd_hda_codec_generic hdaudioC0D0:      Mic=0x19
[   92.699385] snd_hda_codec_generic hdaudioC0D0:      Internal Mic=0x12
[   92.716052] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[   92.717034] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   92.717103] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[   92.717161] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[   92.717216] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[   92.717276] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[   92.717335] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[   92.913623] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[   93.063741] lp: driver loaded but no devices found
[   93.072522] ppdev: user-space parallel port driver
[   93.275341] EXT4-fs (nvme0n1p2): mounting ext2 file system using the ext4 subsystem
[   93.277046] EXT4-fs (nvme0n1p2): mounted filesystem without journal. Opts: (null)
[   93.295119] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Opts: (null)
[   93.319204] Adding 8290300k swap on /dev/mapper/devuan--S145--vg-swap_1.  Priority:-2 extents:1 across:8290300k SSFS
[   93.405405] audit: type=1400 audit(1599160860.428:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1377 comm="apparmor_parser"
[   93.405830] audit: type=1400 audit(1599160860.432:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1375 comm="apparmor_parser"
[   93.405832] audit: type=1400 audit(1599160860.432:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1375 comm="apparmor_parser"
[   93.407492] audit: type=1400 audit(1599160860.432:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1378 comm="apparmor_parser"
[   93.408303] audit: type=1400 audit(1599160860.432:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1379 comm="apparmor_parser"
[   93.408305] audit: type=1400 audit(1599160860.432:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1379 comm="apparmor_parser"
[   93.408306] audit: type=1400 audit(1599160860.432:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1379 comm="apparmor_parser"
[   93.408981] audit: type=1400 audit(1599160860.432:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1380 comm="apparmor_parser"
[   93.409708] audit: type=1400 audit(1599160860.436:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1382 comm="apparmor_parser"
[   93.409746] audit: type=1400 audit(1599160860.436:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1376 comm="apparmor_parser"
[   93.925443] elogind-daemon[1919]: New seat seat0.
[   94.132506] broken atomic modeset userspace detected, disabling atomic
[   95.228414] NET: Registered protocol family 3
[   95.236108] NET: Registered protocol family 5
[   95.913647] elogind-daemon[1919]: New session 1 of user janos.
[  101.281976] usb 1-1: new high-speed USB device number 5 using xhci_hcd
[  101.436402] usb 1-1: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
[  101.436407] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  101.436410] usb 1-1: Product: Flash Disk
[  101.436413] usb 1-1: Manufacturer: USB
[  101.436415] usb 1-1: SerialNumber: AAGUL7G384ZLD78L
[  101.457077] usb-storage 1-1:1.0: USB Mass Storage device detected
[  101.457292] usb-storage 1-1:1.0: Quirks match for vid 090c pid 1000: 400
[  101.457314] scsi host1: usb-storage 1-1:1.0
[  101.457408] usbcore: registered new interface driver usb-storage
[  101.460035] usbcore: registered new interface driver uas
[  102.762059] scsi 1:0:0:0: Direct-Access     USB      Flash Disk       1100 PQ: 0 ANSI: 6
[  102.773075] sd 1:0:0:0: [sda] 60868608 512-byte logical blocks: (31.2 GB/29.0 GiB)
[  102.773673] sd 1:0:0:0: [sda] Write Protect is off
[  102.773674] sd 1:0:0:0: [sda] Mode Sense: 43 00 00 00
[  102.774319] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  102.814099]  sda: sda1 sda2
[  102.816432] sd 1:0:0:0: [sda] Attached SCSI removable disk
[  102.821304] sd 1:0:0:0: Attached scsi generic sg0 type 0
[  113.357721] fuse init (API version 7.27)
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Skylake Processor Thermal Subsystem (rev 02)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Intel(R) 100 Series Chipset Family LPC Controller/eSPI Controller - 9D4E (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
02:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a809
	Subsystem: Lenovo QCA9377 802.11ac Wireless Network Adapter
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 140
	Region 0: Memory at b1000000 (64-bit, non-prefetchable) [size=2M]
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable+ Count=1/8 Maskable+ 64bit-
		Address: fee00398  Data: 0000
		Masking: 000000fe  Pending: 00000000
	Capabilities: [70] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10.000W
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 256 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
			ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR+, OBFF Via message
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr+ BadTLP- BadDLLP+ Rollover- Timeout- NonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
	Capabilities: [148 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
		Arb:	Fixed- WRR32- WRR64- WRR128-
		Ctrl:	ArbSelect=Fixed
		Status:	InProgress-
		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
			Status:	NegoPending- InProgress-
	Capabilities: [168 v1] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [178 v1] Latency Tolerance Reporting
		Max snoop latency: 3145728ns
		Max no snoop latency: 3145728ns
	Capabilities: [180 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=50us PortTPowerOnTime=10us
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
			   T_CommonMode=0us LTR1.2_Threshold=0ns
		L1SubCtl2: T_PwrOn=44us
	Kernel driver in use: ath10k_pci
	Kernel modules: ath10k_pci
filename:       /lib/modules/4.19.0-10-amd64/kernel/drivers/net/wireless/ath/ath10k/ath10k_pci.ko
firmware:       ath10k/QCA9377/hw1.0/board.bin
firmware:       ath10k/QCA9377/hw1.0/firmware-5.bin
firmware:       ath10k/QCA9377/hw1.0/firmware-6.bin
firmware:       ath10k/QCA6174/hw3.0/board-2.bin
firmware:       ath10k/QCA6174/hw3.0/board.bin
firmware:       ath10k/QCA6174/hw3.0/firmware-6.bin
firmware:       ath10k/QCA6174/hw3.0/firmware-5.bin
firmware:       ath10k/QCA6174/hw3.0/firmware-4.bin
firmware:       ath10k/QCA6174/hw2.1/board-2.bin
firmware:       ath10k/QCA6174/hw2.1/board.bin
firmware:       ath10k/QCA6174/hw2.1/firmware-5.bin
firmware:       ath10k/QCA6174/hw2.1/firmware-4.bin
firmware:       ath10k/QCA9887/hw1.0/board-2.bin
firmware:       ath10k/QCA9887/hw1.0/board.bin
firmware:       ath10k/QCA9887/hw1.0/firmware-5.bin
firmware:       ath10k/QCA988X/hw2.0/board-2.bin
firmware:       ath10k/QCA988X/hw2.0/board.bin
firmware:       ath10k/QCA988X/hw2.0/firmware-5.bin
firmware:       ath10k/QCA988X/hw2.0/firmware-4.bin
firmware:       ath10k/QCA988X/hw2.0/firmware-3.bin
firmware:       ath10k/QCA988X/hw2.0/firmware-2.bin
license:        Dual BSD/GPL
description:    Driver support for Qualcomm Atheros 802.11ac WLAN PCIe/AHB devices
author:         Qualcomm Atheros
alias:          pci:v0000168Cd00000050sv*sd*bc*sc*i*
alias:          pci:v0000168Cd00000042sv*sd*bc*sc*i*
alias:          pci:v0000168Cd00000046sv*sd*bc*sc*i*
alias:          pci:v0000168Cd00000056sv*sd*bc*sc*i*
alias:          pci:v0000168Cd00000040sv*sd*bc*sc*i*
alias:          pci:v0000168Cd0000003Esv*sd*bc*sc*i*
alias:          pci:v0000168Cd00000041sv*sd*bc*sc*i*
alias:          pci:v0000168Cd0000003Csv*sd*bc*sc*i*
alias:          pci:v00000777d000011ACsv*sd*bc*sc*i*
depends:        ath10k_core
retpoline:      Y
intree:         Y
vermagic:       4.19.0-10-amd64 SMP mod_unload modversions
sig_id:         PKCS#7
signer:         Debian Secure Boot CA
sig_key:        B5:5E:B3:B9
sig_hashalgo:   sha256
signature:      65:9D:F8:72:3F:ED:80:53:A8:78:16:0C:DA:F2:AB:95:0A:6D:C8:96:
		5A:A9:E6:99:50:5F:75:FE:F3:6A:16:1F:48:24:C5:01:82:5D:3B:6E:
		F1:C7:77:BB:05:9C:46:CE:20:E7:AD:37:87:63:2F:35:BB:02:7D:45:
		9F:87:27:89:50:61:84:CD:12:31:2A:EE:FF:AA:91:04:53:B3:59:E1:
		A3:E6:D7:86:A5:64:66:1C:A2:4C:8D:34:B8:CE:7D:5A:D2:C2:71:11:
		B4:CD:AC:19:26:04:DF:50:CA:66:A5:03:83:2F:0B:52:71:1B:1F:2E:
		4C:78:E9:A9:36:6E:03:4A:2E:45:A6:61:88:8F:9B:84:81:28:4A:16:
		59:9E:1C:E8:BA:1A:22:6E:32:74:CD:24:4B:A0:45:AF:A3:96:4F:77:
		81:5C:BB:BE:D0:ED:69:67:2F:32:AB:E4:5F:F3:E4:DB:5D:B0:A4:18:
		63:C0:A3:08:7F:03:A2:8F:7E:73:14:05:E0:25:55:7B:F4:48:EF:36:
		94:60:CD:01:41:4C:48:5D:04:CA:D6:FE:E4:A9:2B:A1:18:3F:31:00:
		E8:12:EB:D6:72:36:58:8F:94:D7:85:73:93:AE:66:3C:0A:E8:0F:DF:
		BA:5E:E5:CD:0F:09:26:56:08:10:EF:FE:9B:04:C4:FF
parm:           irq_mode:0: auto, 1: legacy, 2: msi (default: 0) (uint)
parm:           reset_mode:0: auto, 1: warm only (default: 0) (uint)
ID TYPE      DEVICE               SOFT      HARD
 0 wlan      ideapad_wlan      blocked unblocked
 1 bluetooth ideapad_bluetooth blocked unblocked
 2 bluetooth hci0              blocked unblocked
 3 wlan      phy0              blocked unblocked
wicd is running.
#2 2020-09-03 20:27:41
Re: Wifi disabled on boot – wlan soft blocked, how to determine why?
orbanbalage wrote:
Not sure what to do
# echo '/usr/sbin/rfkill unblock all' >> /etc/rc.local
See also https://www.freedesktop.org/software/sy … rvice.html
Black Lives Matter
#3 2020-09-03 21:13:30
orbanbalage
orbanbalage wrote:
Not sure what to do
Thanks, but this is a workaround, isn't it? Or it is the default state (soft block) in Debian/Devuan?
I've tried Ubuntu live and the wifi wasn't soft blocked – from there the assumption that this is an issue.
#4 2020-09-03 22:16:41
Vernon
orbanbalage wrote:
Installed Beowulf with XFCE.
Enabled Wifi adapter in wicd, connected to network and set to always connect.
However after reboot the wireless adapter is always disabled. I am able to turn it on in wicd, or remove the soft block with rfkill; but how to troubleshoot the reason?
When I installed Beowulf with LXQt, connman was installed. I was having the same issue as you until I ran apt-get purge connman as root.
#5 2020-09-04 11:42:20
HevyDevy
why would you remove the ath10k_pci kernel module ? what was the need for that measure?
Maybe try reinstalling non-free package firmware-atheros and update the initramfs then reboot.
#6 2020-09-04 16:23:24
orbanbalage
I didn't have connman installed. Thanks for the tip though!
#7 2020-09-04 16:32:43
orbanbalage
Because I don't really understand what it does, and I was trying everything possible from this thread: https://askubuntu.com/questions/98702/h … -in-rfkill
Some people suggested similar measures.
Tried, didn't work. Thanks for the suggestions!
#8 2020-09-04 18:08:07
Yes, it most certainly is.
I'm working on the assumption that it's a bug in the Atheros driver but that's just a guess.
If you still have the Ubuntu live image then I would be interested to see the journal entries for systemd-rfkill.service:
journalctl --unit systemd-rfkill.service
It could be that systemd is applying the same workaround.
EDIT: actually I had one of those cards in my ThinkPad E485, it was utter crap (used to overheat and drop out) but it was never soft-blocked under Debian buster.
Black Lives Matter
#9 2020-09-04 20:05:15
orbanbalage
seems not:
ubuntu@ubuntu:~$ journalctl --unit systemd-rfkill.service
-- Logs begin at Fri 2020-09-04 19:27:46 UTC, end at Fri 2020-09-04 19:53:05 UT>
Sep 04 19:27:47 ubuntu systemd[1]: Starting Load/Save RF Kill Switch Status...
Sep 04 19:27:47 ubuntu systemd[1]: Started Load/Save RF Kill Switch Status.
Sep 04 19:27:56 ubuntu systemd[1]: systemd-rfkill.service: Succeeded.
ubuntu@ubuntu:~$
also:
ubuntu@ubuntu:/var/lib/systemd/rfkill$ cat *wlan*
0
0
"0" does not restore the rfkill settings on boot
#10 2020-09-05 10:16:01
Well it is from the live environment so there is no stored setting.
I've just found this which suggests that soft-blocks can occur due to conflicting networking services so you should check which ones are enabled for your system:
# apt install sysv-rc-conf
# sysv-rc-conf
Make sure only one service is enabled. I would recommend /etc/init.d/networking (ie, ifupdown, which is configured via /etc/network/interfaces and documented in interfaces(5)) rather than wicd because it's lighter and (much) less buggy and it has fewer dependencies.
Black Lives Matter
#11 2020-09-08 08:03:49
orbanbalage
Thanks, that makes sense.
sysv-rc-conf shows networking as "S" and wicd as "2,3,4,5".
I guess I would need to remove that "S" from networking to stay with wicd, or do the reverse to ditch wicd as you suggested.
I tried Cinnamonon (instead of XFCE), and the problem is not present there – I'm assuming because there is no wicd. There is network-m$. networking is set to "S" as well; so that might not be the problem after all.
I've also encountered some audio issues, so temporarily I switched to another distro (the machine is needed only for browsing, I'm doing it for a family member).
#12 2020-09-09 15:52:21
Actually it's probably best to keep /etc/init.d/networking enabled to ensure that the loopback interface is correctly configured (systemd would do that in Debian but I'm not sure about sysvinit). Just remove any stanzas in /etc/network/interfaces that refer to your ethernet or wireless devices if you don't want ifupdown to manage them.
And to disable any given $service it's probably best to use
# sysv-rc-conf $service off
Black Lives Matter
