#1 2020-08-16 19:44:14
dvnUsr
Cannot search for "s6"
Searching the Forum for keyword "s6" (with or without quotes, or wildcards) returns the following:
"You have to enter at least one keyword and/or an author to search for."
Is there a trick I can use to get it to work?
#2 2020-08-16 23:00:23
Ron
Re: Cannot search for "s6"
What you can do is s6 site:dev1galaxy.org/ in your search engine of choice. Here's the results from DDG:
https://duckduckgo.com/?t=palemoon&q=s6 … %2F&ia=web
#3 2020-08-18 12:55:49
bgstack15
Very good question! Thank you Ron, for a good answer. I suspect the forum software thinks the "s6" string is too short to be usable for a valid search. So it's not biased; just s6 is an edge case.
#4 2020-08-18 18:08:23
dvnUsr
Yes, thank you Ron; your creative answer does of course work.
