#1 2020-08-14 05:57:08
w3
Cherrytree and Netsurf aren't in the repository?
I just installed the new stable version of Devuan. To my surprise I can't install Netsurf and Cherrytree.
These applications are not part of the new Devuan stable version?
#2 2020-08-14 12:57:28
HevyDevy
Re: Cherrytree and Netsurf aren't in the repository?
I dont know about cherrytree but netsurf looks to be missing from stable and bumped into testing/unstable .
https://metadata.ftp-master.debian.org/ … _changelog
#3 2020-08-15 14:57:05
Vernon
Updated with Cherrytree info
First, Thanks very much for asking this question. I had never heard of Netsurf before and wow, it is fast.
Netsurf Instructions
You can build Netsurf from source.
apt-get install build-essential libgtk-3-dev
Then follow the build instruction
https://source.netsurf-browser.org/nets … k-start.md
Cherrytree Instructions
Cherrytree has become a victim of the global war on Python 2.7 but we can still build it from source.
apt-get install python2
apt-get install python-gtk2
apt-get install p7zip-full
apt-get install python-dbus
apt-get install python-enchant
apt-get install python-chardet
Click here and download the .deb file for your architecture, As root,  run dpkg -i against the .deb file you downloaded. For the i386 architecture, the command is
dpkg -i python-gtksourceview2_2.10.1-3_i386.deb
Download Cherrytree source
wget https://www.giuspen.com/software/cherrytree-0.39.4.tar.xz
Extract the source
tar -xvJf cherrytree-0.39.4.tar.xz
Run Cherrytree
cd cherrytree-0.39.4
./cherrytree
#4 2020-08-16 09:29:29
florine
netsurf is in devuan/testing:
https://packages.debian.org/search?suit … ds=netsurf
But i think compiling is a good option: if the compilation goes well it speaks for the software and you can stay on stable.
Key fingerprint = 90B5 1002 CAD8 3943 AFD9  3F91 88EF A14F 0F5A FA96
#5 2020-08-16 12:23:37
Try backporting it then: https://wiki.debian.org/SimpleBackportCreation
#6 2020-08-18 13:44:29
HevyDevy
I did this and it worked but failed at libfreetype-dev which is in testing, i dont think it is possible to even create a backport for libfreetype-dev without some form of major breakage, maybe not and maybe you know a way around it. For a standard stable beowulf install, netsurf 3.10 pulls in a lot of dependencies to get it working. I say worked as i followed the simple backport creation and it spat out a few .debs as common.deb and netsurf-3.10.deb and they installed fine and had the program up and running, it failed on this command regarding libfreetype-dev, but maybe the version of libfreetype in stable/beowulf is enough for netsurf-3.10 to run ok.
dpkg-buildpackage -us -uc
A better idea is something you mentioned in below link by way of adding MX repos to devuan beowulf which i did and it works perfectly for netsurf-gtk as MX has it already backported for buster.
http://forums.debian.net/viewtopic.php?f=16&t=146083
Edit to add: ive also been running MX19 xfce4 4.14 version over devuan stable and have had no issues.
