#1 2020-08-09 12:36:50
viverna
Amd Radeon RX 5600 XT
I have a new pc with AMD RADEON RX 5600 XT graphics card.
I installed Beowulf but don't support KMS (Kernel Mode Setting).
Should I install a new driver or Beowulf linux kernel is old for this graphics card?
#2 2020-08-09 12:49:29
Re: Amd Radeon RX 5600 XT
The 5600XT needs the kernel from beowulf-backports and the Navi firmware which can be obtained either from the ceres firmware-amd-graphics .deb package (don't add the repositories, they will break your system) or directly from https://git.kernel.org/pub/scm/linux/ke … .git/tree/ (place it under /lib/firmware/amdgpu/ and rebuild the initramfs).
#3 2020-08-09 17:46:19
viverna
I try copy files in /lib/firmware/amdgpu/ and rebuild the initramfs but doesn't work. "Ceres" support KMS for this graphics card. However I cannot install a unstable distro in my pc.
#4 2020-08-09 18:53:18
Did you also upgrade the kernel? Here's the metapackage you need: https://pkginfo.devuan.org/stage/beowul … o10+1.html
For early KMS support add this line to /etc/initramfs-tools/modules:
amdgpu
Then rebuild the initramfs again:
# update-initramfs -u -k all
#5 2020-08-11 14:43:10
viverna
Thanks for the reply, but if I install this package in the system I risk of breaking the system?
#6 2020-08-11 14:49:34
larsH
No
Do not be afraid. This is a the manual way to do this and by the way Head_on_a_Stick is a very reliable person. And it will not in any case break something that is not allready broken ;-() But more likely fix it ;-))))))))
Have a nice day
Lars H
#7 2020-08-11 15:36:09
To encourage you, please read https://dev1galaxy.org/viewtopic.php?id=3358.
#8 2020-08-13 17:42:49
viverna
Thanks to all I will try soon.
#9 2020-08-13 20:47:16
viverna
Perfect. It works. Thank you.
