#1 2020-08-08 20:36:39
sgage
Install grub so that EFI directory is 'devuan'
I am running Ceres (which is running very well with MATE). How can I install grub so that the EFI directory is 'devuan' instead of 'debian'. Using the '--bootloader-id=devuan' argument to grub-install still creates a 'debian' directory. My os-release file has 'ID=devuan'. I don't know what else to try. Any ideas?
TIA...
#2 2020-08-08 21:06:36
Re: Install grub so that EFI directory is 'devuan'
That will work if you don't use Secure Boot. But you still will have a debian and a devuan EFI directory.
Use the efibootmgr to boot the devuan entry. If that works, you can delete the debian entry with the file manager.
#3 2020-08-08 21:23:37
sgage
I want to have a separate devuan and debian directory. The problem is, that in Ceres (this did not happen in Beowulf), I can not get grub-install to generate a devuan directory at all. No matter what I've tried, grub-install generates a debian directory in /boot/efi/EFI. I know how to use efibootmgr to set boot order and such.
#4 2020-08-09 07:20:50
I can confirm that also Chimaera (in a VM) has the same behaviour. What easily worked under Beowulf is no more working with the testing/unstable stuff.
Needs a closer look.
#5 2020-08-09 11:24:41
Why? If it's that important to you then install GRUB from an Arch live ISO (use the --boot-directory= & --efi-directory= options to avoid the need to chroot).
I can't find a reference in the changlelog but I presume $ESP/EFI/debian is being created because of https://bugs.debian.org/cgi-bin/bugrepo … bug=925309
#6 2020-08-09 12:13:30
sgage
It's not that important. Thanks for the bug reference.
#7 2020-08-09 19:16:36
The following trick may do what you want:
1.) apt remove grub-efi-amd64-signed
2.) grub-install --bootloader-id=devuan
Worked in my Chimaera VM.
