#1 2020-08-08 20:00:31
cynicfm
[solved] Devuan Ceres -> Problematic debian-edu-artwork package
Hey
Whenever i try to install something or delete it seems like i am unable to do that because of that:
root@devuan:/home/filip# apt-get remove debian-edu-artwork
Building dependency tree
  debian-edu-artwork
0 upgraded, 0 newly installed, 1 to remove and 212 not upgraded.
1 not fully installed or removed.
After this operation, 73.7 kB disk space will be freed.
(Reading database ... 293192 files and directories currently installed.)
Removing debian-edu-artwork (2.11.0.2-2) ...
update-alternatives: error: no alternatives for desktop-login-background
dpkg: error processing package debian-edu-artwork (--remove):
 installed debian-edu-artwork package post-removal script subprocess returned error exit status 2
dpkg: too many errors, stopping
 debian-edu-artwork
Processing was halted because there were too many errors.
I have no idea how to fix this, anybody can help???
Using devuan ceres
Thanks
#2 2020-08-08 23:35:47
Re: [solved] Devuan Ceres -> Problematic debian-edu-artwork package
That looks like a bug with that package, but you might be able to side-step that bug by temporarily making  /usr/bin/update-alternatives be something else... something like
# mv /usr/bin/update-alternatives /usr/bin/update-alternatives.ORIG
# ln -s /bin/true /usr/bin/update-alternatives
then remove debian-edu-artwork
and then restore:
# mv /usr/bin/update-alternatives.ORIG /usr/bin/update-alternatives
#3 2020-08-09 02:30:32
cynicfm
Thanks smile
