#1 2020-08-07 01:27:35
Vernon
package pulseaudio - audio control
Fix package pulseaudio startup
https://bugs.devuan.org/cgi/bugreport.cgi?bug=276]
As root, comment out autospawn=no in your /etc/pulse/client.conf.d/00-disable-autospawn.conf file.
Your /etc/pulse/client.conf.d/00-disable-autospawn.conf file should now look like the below.
# On linux systems, disable autospawn by default
# If you are not using systemd, comment out this line
# autospawn=no
