Conky is a open source software desktop system monitor for the X Window System. It is available for Linux, FreeBSD, and OpenBSD. Source
My work are forked from Neon Cipher good tutorial => Conky System Monitor on My Desktop. How to Install and Configure It on Linux.
I add the code after the 85 line in the conky.conf file:
sudo nano ~/.config/conky/conky.conf$font${color DimGray}Debian Version $alignr ${execi 30 cat /etc/debian_version}The output:
Don't forget to adjust the config file with your material.
Here the forked config file in english:
if you encounter any inconsistencies with the amount of memory, just toggle "no_buffers" to yes in the conky.conf file, stop and start conky processu with the system monitor, open an terminal and write conky and enter to take effects.
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
And why do you use the sudo command for editing conky config in user dir?
----+- Peter Kropotkin -+----
