#1 2020-07-29 12:30:59
wingcommander1999
[HowTo] Merge videos with ffmpeg
FFmpeg is a collection of open source software intended for processing audio or video streams. Source
Be sure that you have the last version of ffmpeg:
ffmpeg -version
You will see an output of your version, in my case i have the last stable version 4.1.6.
No output??? Whaaaat!!! Don't panic on the Titanic, we need just to install the package:
sudo apt update && sudo apt upgrade -y
sudo apt install ffmpeg -y
Go to the Videos folder and we create an file like this, necessary to concat later:
file '/path_to_my_file/part1.mp4'
file '//path_to_my_file/part2.mp4'
file '/=/path_to_my_file/part3.mp4'
then save the file with a name of your choice in .txt output, in my example merge.txt.
Now we can merge our vids, the per-file main options retained are:
-f input/output with the concat option
-i input file or url
-c codec or stream output with the copy option
 ffmpeg -f concat -safe 0 -i merge.txt -c copy my_vids.mp4
After a few moments you can see your new merged video.
Enjoy! big_smile
Source
AMD Ryzen 7 3700X - Gigabyte B550 AORUS ELITE V2 - 4x8GB DDR4 - SSD 1,5TO - GTX1660TI 6GB - PSU Gigabyte 750W Gold - Zalman X3 White
Devuan / W11
