#1 2020-07-17 21:23:54
Ron
[SOLVED] Just bought HP 8025, not detected
I'm at a loss, this is the first time I had trouble with an hp printer. It's an Officejet Pro 8025 and hplip isn't detecting it. I am at a loss as to what to do next. Any suggestions?
Devuan 2.1
hplip 3.16.11
cups 2.2.1-8
#2 2020-07-17 22:02:07
Debuser2018
Re: [SOLVED] Just bought HP 8025, not detected
HPLIP db shows HP 8020 Officejet series printers are supported. May be you should run hp-setup with the printer connected to the Linux PC. It will work.
#3 2020-07-17 22:40:18
Ron
Unfortunately it doesn't. Any other suggestions?
[Is 8025 considered part of the 8020 series? I can't understand why it's not being detected.]
#4 2020-07-17 23:16:47
Debuser2018
Yes. I think so. In the case of HP 2135 printer, 2130 series driver worked. Hopefully true. I will still recommend you to try running "sudo hp-setup".
Also, check that user has lpadmin as secondary group.
Another option is using CUPS. There is a gui tool system-config-printer. Try installing system-config-printer, system-config-printer-udev packages.
Meanwhile ensure that the printer USB cable is inserted properly in printer end and PC usb slot.
#5 2020-07-17 23:31:58
Ron
Much thanks, installing system-config-printer seems to have done the trick. I owe you one cold beer. smile
I will wait a day or two before marking this as solved.
#6 2020-07-18 00:15:52
+1
When (in a hurry) I purchased a M2020W, the only thing that worked almost right away (Devuan 2.0 ascii) was CUPS.
No issues since.
Cheers,
#7 2020-07-18 07:12:54
Debuser2018
Glad that it worked. It may be possible to use the proper 8020 *.ppd driver which may be part of hplip. I'm not sure how to do that.
#8 2020-07-19 02:18:17
Ron
I'll just stick to what's working. smile But I'm wondering now, can hplip be removed from my computer without affecting the printer?
