#1 2020-07-16 11:33:35
HevyDevy
[solved] before grub screen appears
this is not really an issue for devuan i think it has more to do with gnome.
Thought i would install gnome desktop to see if it works with beowulf and it does although upon booting im getting a strange screen that says the following.
error: no such device: (root encrypted uuid) # edited for the forum
error: unknown filesystem
Press any key to continue.
the drive has 3 partitions, boot, root and a spare data partition all in ext4.
as i say not really an issue because if i delete gnome desktop and all its components the error message disappears and with gnome desktop it just continues on to the correct grub boot menu and boots fine.
anyone else experience this using gnome?
#2 2020-07-16 12:47:06
Re: [solved] before grub screen appears
Have a read of https://dev1galaxy.org/viewtopic.php?id=3471. Isn't that the same kind of issue you see? Error message is slightly different, but similar.
#3 2020-07-16 13:30:04
HevyDevy
yes that is similar whereas mine should read like below, sorry i was going from memory as im not sure how to screen shot it, but took a phone cam image just now.
#4 2020-07-16 13:50:31
HevyDevy
okay so if i understand this correctly it has something to do with desktop-base and grub, not sure if it is present with or without encryption though?
if i comment the line and update grub
GRUB_THEME=/usr/share/desktop-base/grub-themes/desktop-grub-theme/theme.txt
in etc/default/grub the error does not appear on boot.
edit: as per fsmithred post here https://dev1galaxy.org/viewtopic.php?pid=21360#p21360
solved, thanks rolfie and fsmithred
#5 2020-07-16 14:19:21
Only appears with encryption, because when grub starts there is no access to /usr/share/..... yet.
#6 2020-07-16 14:44:40
HevyDevy
i see, i wonder how they could be accessed before encryption? Not that it matters really, i would rather not see grub unless i need it and you can edit in parameters in case grub should be seen.
https://wiki.archlinux.org/index.php/GR … idden_menu
#7 2020-07-16 14:57:12
You move the themes folder to /boot/grub and specify that in /etc/default/grub. From my notes:
# mkdir /boot/grub/themes
# cp -r /usr/share/desktop-base/grub-themes/cinnabar-grub /boot/grub/themes/
# nano /etc/default/grub
        Change entry to:
        GRUB_THEME=/boot/grub/themes/cinnabar-grub/theme.txt
# update-grub
That fixes the error and brings the new cinnabar theme to grub. If you do not want that you can copy the default theme.
