#1 2020-07-10 16:21:51
Devuman
Chromium closes without user interaction
Devuan Beowulf 3.0.0 32-bit
Chromium 83.0.4103.116
All extensions are deactivated.
What could be the cause of this?
#2 2020-07-10 18:00:49
Re: Chromium closes without user interaction
Start it from a terminal and there may be some error messages.
#3 2020-07-11 12:23:13
Ogis1975
Maybe, this is related to this?
https://bugs.debian.org/cgi-bin/bugrepo … bug=963548
https://bugs.debian.org/cgi-bin/bugrepo … bug=964334
            ----+- Peter Kropotkin -+----
#4 2020-07-11 15:01:16
Devuman
Indeed, the 2nd bug report.
#5 2020-07-12 12:18:54
Ogis1975
Hi! You may launch chromium whith the -g option from a terminal: once in the debugger, you "start" and wait for a crash in the browser while you navigate the web. I suppose, the debugger in the terminal should give you a trace of the crash.
#6 2020-07-13 16:16:52
Ogis1975
It is possible that this error has now been fixed. According Debian Security Advisory DSA-4714-3
The previous update for chromium released as DSA 4714-2 contained a flaw in the service worker implementation.  This problem causes the browser to crash when a connection error occurs.  Updated chromium packages are now available that correct this issue. For the stable distribution (buster), this problem has been fixed in version 83.0.4103.116-1~deb10u3.
#7 2020-07-17 12:19:30
Devuman
fixed indeed
