#1 2020-07-05 21:43:24
Ron
Mate (Caja) icon problem
I have some old Real Player files, and the icons looked like the first screenshot. The top one is a .rm file, and Caja gave it the movie icon, even though it is only an audio file. The rest of the files are .ram, and Caja gave them the text file icon. So I thought that if maybe I assigned these types of files to be opened by SMPlayer (they weren't assigned to any app) that Caja would figure out to give them the same icon as other audio files (second screenshot), but it didn't. So I manually changed the four files to the eighth notes icon. My question is this: is there a way to tell Caja to assign the eighth notes icon to .rm and .ram files automatically? If I copy these files to any other location, they end up with the icons in the first screenshot. Thanks.
