#1 2020-07-01 08:23:38
zerrax
PnP USB Audio Device doesn't work
I bought a FSF certified USB audio dongle, and yesterday I received it, but when I tested it
I still didn't have sound on my Devuan Beowulf computer
The dongle is of the brand: "Sabrent" type: AU-MMSA
I also tried other USB Audio Adapters from other brand, but still no audio device detected
I think it's a software config problem, not hardware
Can anybody help me?
#2 2020-07-01 08:32:23
PedroReina
Re: PnP USB Audio Device doesn't work
Please share whit us your dmesg after inserting USB device and lsusb
#3 2020-07-01 08:48:25
zerrax
speaker-test -c 2 -D hw:Device -r 48000 -t sine -f 440
When I type this command I do hear sound, but in Devuan there is no audio device visible....
"lsusb" command gives:
Bus 002 Device 004: ID 0d8c:0139 C-Media Electronics, Inc. Multimedia Headset [Gigaware by Ignition L.P.]
(I'm testing now, not the FSF certified one, but the "SWEEX" one (looks similar) type: SC010V2)
#4 2020-07-01 09:08:46
zerrax
root@devuan:/home/user# dmesg
[    0.000000] microcode: microcode updated early to revision 0x27, date = 2019-02-26
[    0.000000] Linux version 4.19.0-9-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.118-2+deb10u1 (2020-06-07)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-9-amd64 root=UUID=3d1fe700-9bfb-4f92-9b3f-2f050a6d76d4 ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000d1ebffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d1ec0000-0x00000000d1ec6fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000d1ec7000-0x00000000d22f5fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d22f6000-0x00000000d270afff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d270b000-0x00000000d7ee4fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d7ee5000-0x00000000d7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d8000000-0x00000000d875efff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d875f000-0x00000000d87fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000d8800000-0x00000000d8fadfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000d8fae000-0x00000000d8ffffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000d9000000-0x00000000da71bfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000da71c000-0x00000000da7fffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000da800000-0x00000000db836fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db837000-0x00000000dbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dd000000-0x00000000df1fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021fdfffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Dell Inc. OptiPlex 3020/0VHWTR, BIOS A02 01/07/2014
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3392.441 MHz processor
[    0.001509] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001510] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001516] last_pfn = 0x21fe00 max_arch_pfn = 0x400000000
[    0.001518] MTRR default type: uncachable
[    0.001519] MTRR fixed ranges enabled:
[    0.001520]   00000-9FFFF write-back
[    0.001520]   A0000-BFFFF uncachable
[    0.001521]   C0000-D3FFF write-protect
[    0.001521]   D4000-E7FFF uncachable
[    0.001522]   E8000-FFFFF write-protect
[    0.001522] MTRR variable ranges enabled:
[    0.001523]   0 base 0000000000 mask 7E00000000 write-back
[    0.001524]   1 base 0200000000 mask 7FE0000000 write-back
[    0.001524]   2 base 00E0000000 mask 7FE0000000 uncachable
[    0.001525]   3 base 00DE000000 mask 7FFE000000 uncachable
[    0.001525]   4 base 00DD000000 mask 7FFF000000 uncachable
[    0.001526]   5 base 021FE00000 mask 7FFFE00000 uncachable
[    0.001526]   6 disabled
[    0.001526]   7 disabled
[    0.001527]   8 disabled
[    0.001527]   9 disabled
[    0.002128] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002233] e820: update [mem 0xdd000000-0xffffffff] usable ==> reserved
[    0.002236] last_pfn = 0xdb837 max_arch_pfn = 0x400000000
[    0.008062] found SMP MP-table at [mem 0x000fd900-0x000fd90f]
[    0.013343] Using GB pages for direct mapping
[    0.013345] BRK [0x27601000, 0x27601fff] PGTABLE
[    0.013346] BRK [0x27602000, 0x27602fff] PGTABLE
[    0.013346] BRK [0x27603000, 0x27603fff] PGTABLE
[    0.013360] BRK [0x27604000, 0x27604fff] PGTABLE
[    0.013361] BRK [0x27605000, 0x27605fff] PGTABLE
[    0.013505] BRK [0x27606000, 0x27606fff] PGTABLE
[    0.013539] BRK [0x27607000, 0x27607fff] PGTABLE
[    0.013579] BRK [0x27608000, 0x27608fff] PGTABLE
[    0.013630] BRK [0x27609000, 0x27609fff] PGTABLE
[    0.013676] BRK [0x2760a000, 0x2760afff] PGTABLE
[    0.013718] BRK [0x2760b000, 0x2760bfff] PGTABLE
[    0.013766] BRK [0x2760c000, 0x2760cfff] PGTABLE
[    0.013811] RAMDISK: [mem 0x34755000-0x363a1fff]
[    0.013817] ACPI: Early table checksum verification disabled
[    0.015539] ACPI: RSDP 0x00000000000F0490 000024 (v02 DELL  )
[    0.015542] ACPI: XSDT 0x00000000D8FEE088 00008C (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.015545] ACPI: FACP 0x00000000D8FFA470 00010C (v05 DELL   CBX3     01072009 AMI  00010013)
[    0.015549] ACPI: DSDT 0x00000000D8FEE1A0 00C2CA (v02 DELL   CBX3     00000014 INTL 20091112)
[    0.015551] ACPI: FACS 0x00000000DA7FE080 000040
[    0.015552] ACPI: APIC 0x00000000D8FFA580 000072 (v03 DELL   CBX3     01072009 AMI  00010013)
[    0.015554] ACPI: FPDT 0x00000000D8FFA5F8 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
[    0.015555] ACPI: SLIC 0x00000000D8FFA640 000176 (v03 DELL   CBX3     01072009 MSFT 00010013)
[    0.015557] ACPI: LPIT 0x00000000D8FFA7B8 00005C (v01 DELL   CBX3     00000000 AMI. 00000005)
[    0.015559] ACPI: SSDT 0x00000000D8FFA818 000539 (v01 PmRef  Cpu0Ist  00003000 INTL 20120711)
[    0.015560] ACPI: SSDT 0x00000000D8FFAD58 000AD8 (v01 PmRef  CpuPm    00003000 INTL 20120711)
[    0.015562] ACPI: SSDT 0x00000000D8FFB830 0001C7 (v01 PmRef  LakeTiny 00003000 INTL 20120711)
[    0.015564] ACPI: HPET 0x00000000D8FFB9F8 000038 (v01 DELL   CBX3     01072009 AMI. 00000005)
[    0.015566] ACPI: SSDT 0x00000000D8FFBA30 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[    0.015567] ACPI: MCFG 0x00000000D8FFBDA0 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
[    0.015569] ACPI: SSDT 0x00000000D8FFBDE0 0034E1 (v01 SaSsdt SaSsdt   00003000 INTL 20091112)
[    0.015571] ACPI: MSDM 0x00000000D8FFF2C8 000055 (v03 DELL   CBX3     06222004 AMI  00010013)
[    0.015576] ACPI: Local APIC address 0xfee00000
[    0.015636] No NUMA configuration found
[    0.015636] Faking a node at [mem 0x0000000000000000-0x000000021fdfffff]
[    0.015639] NODE_DATA(0) allocated [mem 0x21fdf9000-0x21fdfdfff]
[    0.015657] Zone ranges:
[    0.015657]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.015658]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.015659]   Normal   [mem 0x0000000100000000-0x000000021fdfffff]
[    0.015659]   Device   empty
[    0.015660] Movable zone start for each node
[    0.015660] Early memory node ranges
[    0.015661]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
[    0.015661]   node   0: [mem 0x0000000000100000-0x00000000d1ebffff]
[    0.015662]   node   0: [mem 0x00000000d1ec7000-0x00000000d22f5fff]
[    0.015662]   node   0: [mem 0x00000000d270b000-0x00000000d7ee4fff]
[    0.015662]   node   0: [mem 0x00000000d8000000-0x00000000d875efff]
[    0.015663]   node   0: [mem 0x00000000d8800000-0x00000000d8fadfff]
[    0.015663]   node   0: [mem 0x00000000d9000000-0x00000000da71bfff]
[    0.015664]   node   0: [mem 0x00000000da800000-0x00000000db836fff]
[    0.015664]   node   0: [mem 0x0000000100000000-0x000000021fdfffff]
[    0.015889] Zeroed struct page in unavailable ranges: 20795 pages
[    0.015890] Initmem setup node 0 [mem 0x0000000000001000-0x000000021fdfffff]
[    0.015891] On node 0 totalpages: 2076357
[    0.015892]   DMA zone: 64 pages used for memmap
[    0.015892]   DMA zone: 21 pages reserved
[    0.015893]   DMA zone: 3996 pages, LIFO batch:0
[    0.015957]   DMA32 zone: 13957 pages used for memmap
[    0.015957]   DMA32 zone: 893225 pages, LIFO batch:63
[    0.030426]   Normal zone: 18424 pages used for memmap
[    0.030427]   Normal zone: 1179136 pages, LIFO batch:63
[    0.048523] Reserving Intel graphics memory at [mem 0xdd200000-0xdf1fffff]
[    0.048587] ACPI: PM-Timer IO Port: 0x1808
[    0.048588] ACPI: Local APIC address 0xfee00000
[    0.048593] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.048602] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.048603] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.048604] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.048605] ACPI: IRQ0 used by override.
[    0.048606] ACPI: IRQ9 used by override.
[    0.048607] Using ACPI (MADT) for SMP configuration information
[    0.048608] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.048612] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.048627] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.048628] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[    0.048629] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.048629] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.048629] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.048631] PM: Registered nosave memory: [mem 0xd1ec0000-0xd1ec6fff]
[    0.048632] PM: Registered nosave memory: [mem 0xd22f6000-0xd270afff]
[    0.048632] PM: Registered nosave memory: [mem 0xd7ee5000-0xd7ffffff]
[    0.048633] PM: Registered nosave memory: [mem 0xd875f000-0xd87fffff]
[    0.048634] PM: Registered nosave memory: [mem 0xd8fae000-0xd8ffffff]
[    0.048635] PM: Registered nosave memory: [mem 0xda71c000-0xda7fffff]
[    0.048636] PM: Registered nosave memory: [mem 0xdb837000-0xdbffffff]
[    0.048637] PM: Registered nosave memory: [mem 0xdc000000-0xdcffffff]
[    0.048637] PM: Registered nosave memory: [mem 0xdd000000-0xdf1fffff]
[    0.048638] PM: Registered nosave memory: [mem 0xdf200000-0xf7ffffff]
[    0.048638] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.048638] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.048639] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.048639] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.048639] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.048640] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.048640] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.048640] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.048641] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.048641] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.048641] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.048643] [mem 0xdf200000-0xf7ffffff] available for PCI devices
[    0.048643] Booting paravirtualized kernel on bare hardware
[    0.048645] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.117767] random: get_random_bytes called from start_kernel+0x93/0x52c with crng_init=0
[    0.117773] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[    0.117940] percpu: Embedded 45 pages/cpu s144408 r8192 d31720 u524288
[    0.117945] pcpu-alloc: s144408 r8192 d31720 u524288 alloc=1*2097152
[    0.117946] pcpu-alloc: [0] 0 1 2 3
[    0.117962] Built 1 zonelists, mobility grouping on.  Total pages: 2043891
[    0.117963] Policy zone: Normal
[    0.117964] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-9-amd64 root=UUID=3d1fe700-9bfb-4f92-9b3f-2f050a6d76d4 ro quiet
[    0.121382] Calgary: detecting Calgary via BIOS EBDA area
[    0.121383] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.140024] Memory: 8053828K/8305428K available (10252K kernel code, 1241K rwdata, 3316K rodata, 1588K init, 2276K bss, 251600K reserved, 0K cma-reserved)
[    0.140087] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.140092] Kernel/User page tables isolation: enabled
[    0.140119] ftrace: allocating 31883 entries in 125 pages
[    0.149214] rcu: Hierarchical RCU implementation.
[    0.149215] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.149216] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.151304] NR_IRQS: 33024, nr_irqs: 456, preallocated irqs: 16
[    0.151491] spurious 8259A interrupt: IRQ7.
[    0.153178] Console: colour VGA+ 80x25
[    0.153183] console [tty0] enabled
[    0.153194] ACPI: Core revision 20180810
[    0.153335] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.153343] hpet clockevent registered
[    0.153347] APIC: Switch to symmetric I/O mode setup
[    0.153684] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[    0.173346] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x30e66a44ee8, max_idle_ns: 440795328438 ns
[    0.173355] Calibrating delay loop (skipped), value calculated using timer frequency.. 6784.88 BogoMIPS (lpj=13569764)
[    0.173357] pid_max: default: 32768 minimum: 301
[    0.173376] Security Framework initialized
[    0.173376] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.173389] AppArmor: AppArmor initialized
[    0.174349] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.174841] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.174865] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.174883] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.175033] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.175033] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.175045] CPU0: Thermal monitoring enabled (TM1)
[    0.175052] process: using mwait in idle threads
[    0.175054] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[    0.175055] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[    0.175056] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.175056] Spectre V2 : Mitigation: Full generic retpoline
[    0.175057] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.175057] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.175062] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.175062] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.175063] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.175080] SRBDS: Vulnerable: No microcode
[    0.175080] MDS: Mitigation: Clear CPU buffers
[    0.175217] Freeing SMP alternatives memory: 24K
[    0.176616] TSC deadline timer enabled
[    0.176619] smpboot: CPU0: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[    0.176679] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.176714] ... version:                3
[    0.176714] ... bit width:              48
[    0.176714] ... generic registers:      4
[    0.176715] ... value mask:             0000ffffffffffff
[    0.176715] ... max period:             00007fffffffffff
[    0.176715] ... fixed-purpose events:   3
[    0.176716] ... event mask:             000000070000000f
[    0.176742] rcu: Hierarchical SRCU implementation.
[    0.177011] random: crng done (trusting CPU's manufacturer)
[    0.177217] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.177249] smp: Bringing up secondary CPUs ...
[    0.177295] x86: Booting SMP configuration:
[    0.177295] .... node  #0, CPUs:      #1 #2
[    0.177347] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.177347]  #3
[    0.177347] smp: Brought up 1 node, 4 CPUs
[    0.177347] smpboot: Max logical packages: 1
[    0.177347] smpboot: Total of 4 processors activated (27139.52 BogoMIPS)
[    0.177545] devtmpfs: initialized
[    0.177545] x86/mm: Memory block size: 128MB
[    0.177858] PM: Registering ACPI NVS region [mem 0xd1ec0000-0xd1ec6fff] (28672 bytes)
[    0.177858] PM: Registering ACPI NVS region [mem 0xda71c000-0xda7fffff] (933888 bytes)
[    0.177858] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.177858] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.177858] pinctrl core: initialized pinctrl subsystem
[    0.177858] NET: Registered protocol family 16
[    0.177858] audit: initializing netlink subsys (disabled)
[    0.177858] audit: type=2000 audit(1593589430.024:1): state=initialized audit_enabled=0 res=1
[    0.177858] cpuidle: using governor ladder
[    0.177858] cpuidle: using governor menu
[    0.177858] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.177858] ACPI: bus type PCI registered
[    0.177858] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.177858] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.177858] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.177858] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.177858] PCI: Using configuration type 1 for base access
[    0.177858] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[    0.177858] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.177858] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.177858] ACPI: Added _OSI(Module Device)
[    0.177858] ACPI: Added _OSI(Processor Device)
[    0.177858] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.177858] ACPI: Added _OSI(Processor Aggregator Device)
[    0.177858] ACPI: Added _OSI(Linux-Dell-Video)
[    0.177858] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.185559] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.186647] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.187168] ACPI: Dynamic OEM Table Load:
[    0.187172] ACPI: SSDT 0xFFFF96F3D61B5800 0003D3 (v01 PmRef  Cpu0Cst  00003001 INTL 20120711)
[    0.187442] ACPI: Dynamic OEM Table Load:
[    0.187445] ACPI: SSDT 0xFFFF96F3D60E9800 0005AA (v01 PmRef  ApIst    00003000 INTL 20120711)
[    0.187730] ACPI: Dynamic OEM Table Load:
[    0.187732] ACPI: SSDT 0xFFFF96F3D614CC00 000119 (v01 PmRef  ApCst    00003000 INTL 20120711)
[    0.188309] ACPI: Interpreter enabled
[    0.188331] ACPI: (supports S0 S3 S4 S5)
[    0.188331] ACPI: Using IOAPIC for interrupt routing
[    0.188349] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.188508] ACPI: Enabled 9 GPEs in block 00 to 3F
[    0.194860] ACPI: Power Resource [FN00] (off)
[    0.194905] ACPI: Power Resource [FN01] (off)
[    0.194946] ACPI: Power Resource [FN02] (off)
[    0.194986] ACPI: Power Resource [FN03] (off)
[    0.195027] ACPI: Power Resource [FN04] (off)
[    0.195486] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.195489] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.197628] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.197629] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.197888] PCI host bridge to bus 0000:00
[    0.197890] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.197890] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.197891] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.197892] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.197892] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.197893] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.197894] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.197894] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.197895] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff window]
[    0.197896] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.197901] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[    0.197963] pci 0000:00:02.0: [8086:041e] type 00 class 0x030000
[    0.197970] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[    0.197974] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.197977] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.198030] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[    0.198037] pci 0000:00:03.0: reg 0x10: [mem 0xf7d10000-0xf7d13fff 64bit]
[    0.198108] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[    0.198126] pci 0000:00:14.0: reg 0x10: [mem 0xf7d00000-0xf7d0ffff 64bit]
[    0.198174] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.198223] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[    0.198240] pci 0000:00:16.0: reg 0x10: [mem 0xf7d1a000-0xf7d1a00f 64bit]
[    0.198292] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.198347] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[    0.198364] pci 0000:00:1a.0: reg 0x10: [mem 0xf7d18000-0xf7d183ff]
[    0.198433] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.198484] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[    0.198546] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.198626] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[    0.198686] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.198764] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[    0.198783] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d17000-0xf7d173ff]
[    0.198853] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.198906] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[    0.199040] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[    0.199053] pci 0000:00:1f.2: reg 0x10: [io  0xf0b0-0xf0b7]
[    0.199059] pci 0000:00:1f.2: reg 0x14: [io  0xf0a0-0xf0a3]
[    0.199064] pci 0000:00:1f.2: reg 0x18: [io  0xf090-0xf097]
[    0.199070] pci 0000:00:1f.2: reg 0x1c: [io  0xf080-0xf083]
[    0.199076] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[    0.199082] pci 0000:00:1f.2: reg 0x24: [mem 0xf7d16000-0xf7d167ff]
[    0.199110] pci 0000:00:1f.2: PME# supported from D3hot
[    0.199154] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[    0.199168] pci 0000:00:1f.3: reg 0x10: [mem 0xf7d15000-0xf7d150ff 64bit]
[    0.199184] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[    0.199278] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.199336] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.199363] pci 0000:02:00.0: reg 0x10: [io  0xe000-0xe0ff]
[    0.199389] pci 0000:02:00.0: reg 0x18: [mem 0xf7c00000-0xf7c00fff 64bit]
[    0.199405] pci 0000:02:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[    0.199495] pci 0000:02:00.0: supports D1 D2
[    0.199496] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.199596] pci 0000:00:1c.3: PCI bridge to [bus 02]
[    0.199599] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[    0.199601] pci 0000:00:1c.3:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.199606] pci 0000:00:1c.3:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.200083] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.200114] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.200143] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.200172] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.200200] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.200229] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.200257] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.200286] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.200535] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.200535] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.200535] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.200535] vgaarb: loaded
[    0.200535] pps_core: LinuxPPS API ver. 1 registered
[    0.200535] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.200535] PTP clock support registered
[    0.200535] EDAC MC: Ver: 3.0.0
[    0.200535] PCI: Using ACPI for IRQ routing
[    0.201869] PCI: pci_cache_line_size set to 64 bytes
[    0.201899] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[    0.201900] e820: reserve RAM buffer [mem 0xd1ec0000-0xd3ffffff]
[    0.201901] e820: reserve RAM buffer [mem 0xd22f6000-0xd3ffffff]
[    0.201901] e820: reserve RAM buffer [mem 0xd7ee5000-0xd7ffffff]
[    0.201902] e820: reserve RAM buffer [mem 0xd875f000-0xdbffffff]
[    0.201902] e820: reserve RAM buffer [mem 0xd8fae000-0xdbffffff]
[    0.201903] e820: reserve RAM buffer [mem 0xda71c000-0xdbffffff]
[    0.201904] e820: reserve RAM buffer [mem 0xdb837000-0xdbffffff]
[    0.201904] e820: reserve RAM buffer [mem 0x21fe00000-0x21fffffff]
[    0.201966] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.201966] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.203725] clocksource: Switched to clocksource tsc-early
[    0.206350] VFS: Disk quotas dquot_6.6.0
[    0.206350] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.206350] AppArmor: AppArmor Filesystem Enabled
[    0.206350] pnp: PnP ACPI init
[    0.206350] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.206350] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.206350] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.206350] system 00:01: [io  0xffff] has been reserved
[    0.206350] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[    0.206350] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[    0.206350] system 00:01: [io  0x1e00-0x1efe] has been reserved
[    0.206350] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[    0.206350] system 00:01: [io  0x1800-0x18fe] has been reserved
[    0.206350] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.206350] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.206350] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.206350] system 00:03: [io  0x1854-0x1857] has been reserved
[    0.206350] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.206350] system 00:04: [io  0x0a00-0x0a0f] has been reserved
[    0.206350] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.206350] system 00:05: [io  0x04d0-0x04d1] has been reserved
[    0.206350] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.206350] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.206350] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.206350] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.206350] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.206350] system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.206350] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.206350] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.206350] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.206350] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.206350] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.206350] system 00:06: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[    0.206350] system 00:06: [mem 0xf7fe0000-0xf7feffff] has been reserved
[    0.206350] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.206350] pnp: PnP ACPI: found 7 devices
[    0.214186] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.214197] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    0.214198] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    0.214199] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[    0.214210] pci 0000:00:1c.0: BAR 14: assigned [mem 0xdf200000-0xdf3fffff]
[    0.214214] pci 0000:00:1c.0: BAR 15: assigned [mem 0xdf400000-0xdf5fffff 64bit pref]
[    0.214215] pci 0000:00:1c.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.214217] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.214219] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.214222] pci 0000:00:1c.0:   bridge window [mem 0xdf200000-0xdf3fffff]
[    0.214225] pci 0000:00:1c.0:   bridge window [mem 0xdf400000-0xdf5fffff 64bit pref]
[    0.214230] pci 0000:00:1c.3: PCI bridge to [bus 02]
[    0.214232] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[    0.214236] pci 0000:00:1c.3:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.214238] pci 0000:00:1c.3:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.214243] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.214244] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.214244] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.214245] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff window]
[    0.214246] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff window]
[    0.214246] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff window]
[    0.214247] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000e3fff window]
[    0.214248] pci_bus 0000:00: resource 11 [mem 0x000e4000-0x000e7fff window]
[    0.214248] pci_bus 0000:00: resource 12 [mem 0xdf200000-0xfeafffff window]
[    0.214249] pci_bus 0000:01: resource 0 [io  0x2000-0x2fff]
[    0.214250] pci_bus 0000:01: resource 1 [mem 0xdf200000-0xdf3fffff]
[    0.214250] pci_bus 0000:01: resource 2 [mem 0xdf400000-0xdf5fffff 64bit pref]
[    0.214251] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.214252] pci_bus 0000:02: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.214252] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.214317] NET: Registered protocol family 2
[    0.214411] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
[    0.214430] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.214502] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.214603] TCP: Hash tables configured (established 65536 bind 65536)
[    0.214621] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.214638] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.214674] NET: Registered protocol family 1
[    0.214677] NET: Registered protocol family 44
[    0.214683] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.241414] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x6c1 took 23490 usecs
[    0.261410] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x6c1 took 19518 usecs
[    0.261422] PCI: CLS 64 bytes, default 64
[    0.261448] Unpacking initramfs...
[    0.552327] Freeing initrd memory: 28980K
[    0.552378] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.552379] software IO TLB: mapped [mem 0xd3ee5000-0xd7ee5000] (64MB)
[    0.552842] Initialise system trusted keyrings
[    0.552849] Key type blacklist registered
[    0.552887] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[    0.553645] zbud: loaded
[    0.664448] Key type asymmetric registered
[    0.664450] Asymmetric key parser 'x509' registered
[    0.664456] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.664475] io scheduler noop registered
[    0.664476] io scheduler deadline registered
[    0.664494] io scheduler cfq registered (default)
[    0.664495] io scheduler mq-deadline registered
[    0.664707] pcieport 0000:00:1c.0: Signaling PME with IRQ 24
[    0.664724] pciehp 0000:00:1c.0:pcie004: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[    0.664868] pcieport 0000:00:1c.3: Signaling PME with IRQ 25
[    0.664907] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.664915] intel_idle: MWAIT substates: 0x42120
[    0.664915] intel_idle: v0.4.1 model 0x3C
[    0.665012] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.665175] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.665460] Linux agpgart interface v0.103
[    0.665486] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.665486] AMD IOMMUv2 functionality not available on this system
[    0.665652] i8042: PNP: No PS/2 controller found.
[    0.665684] mousedev: PS/2 mouse device common for all mice
[    0.665704] rtc_cmos 00:02: RTC can wake from S4
[    0.665821] rtc_cmos 00:02: registered as rtc0
[    0.665831] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.665837] intel_pstate: Intel P-state driver initializing
[    0.666015] ledtrig-cpu: registered to indicate activity on CPUs
[    0.667175] NET: Registered protocol family 10
[    0.682169] Segment Routing with IPv6
[    0.682185] mip6: Mobile IPv6
[    0.682187] NET: Registered protocol family 17
[    0.682212] mpls_gso: MPLS GSO support
[    0.682357] mce: Using 7 MCE banks
[    0.682398] microcode: sig=0x306c3, pf=0x2, revision=0x27
[    0.682453] microcode: Microcode Update Driver: v2.2.
[    0.682461] sched_clock: Marking stable (680579297, 1871200)->(1656762462, -974311965)
[    0.682588] registered taskstats version 1
[    0.682588] Loading compiled-in X.509 certificates
[    0.709860] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    0.709872] Loaded X.509 cert 'Debian Secure Boot Signer: 00a7468def'
[    0.709886] zswap: loaded using pool lzo/zbud
[    0.709952] AppArmor: AppArmor sha1 policy hashing enabled
[    0.710295] rtc_cmos 00:02: setting system clock to 2020-07-01 07:43:52 UTC (1593589432)
[    0.711131] Freeing unused kernel image memory: 1588K
[    0.745433] Write protecting the kernel read-only data: 16384k
[    0.746165] Freeing unused kernel image memory: 2028K
[    0.746424] Freeing unused kernel image memory: 780K
[    0.756688] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.756689] x86/mm: Checking user space page tables
[    0.763179] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.763181] Run /init as init process
[    0.774860] udevd[99]: starting version 3.2.7
[    0.775623] udevd[100]: starting eudev-3.2.7
[    0.797771] thermal LNXTHERM:00: registered as thermal_zone0
[    0.797772] ACPI: Thermal Zone [TZ00] (28 C)
[    0.798007] thermal LNXTHERM:01: registered as thermal_zone1
[    0.798008] ACPI: Thermal Zone [TZ01] (30 C)
[    0.803385] ACPI: bus type USB registered
[    0.803405] usbcore: registered new interface driver usbfs
[    0.803413] usbcore: registered new interface driver hub
[    0.803435] usbcore: registered new device driver usb
[    0.808175] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.808908] ehci-pci: EHCI PCI platform driver
[    0.809045] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.809051] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.809062] ehci-pci 0000:00:1a.0: debug port 2
[    0.809305] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20180810/utaddress-213)
[    0.809309] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.809311] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[    0.809313] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.809313] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[    0.809315] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[    0.809316] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.809316] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20180810/utaddress-213)
[    0.809318] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20180810/utaddress-213)
[    0.809319] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.809319] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    0.811176] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[    0.811205] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    0.811515] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    0.812966] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.812977] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7d18000
[    0.818185] cryptd: max_cpu_qlen set to 1000
[    0.818254] SCSI subsystem initialized
[    0.829876] AVX2 version of gcm_enc/dec engaged.
[    0.829877] AES CTR mode by8 optimization enabled
[    0.832634] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.832677] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.832678] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.832680] usb usb1: Product: EHCI Host Controller
[    0.832681] usb usb1: Manufacturer: Linux 4.19.0-9-amd64 ehci_hcd
[    0.832682] usb usb1: SerialNumber: 0000:00:1a.0
[    0.833559] libata version 3.00 loaded.
[    0.834521] hub 1-0:1.0: USB hub found
[    0.834528] hub 1-0:1.0: 2 ports detected
[    0.834786] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.834792] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.835851] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
[    0.835857] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.836019] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.836020] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.836021] usb usb2: Product: xHCI Host Controller
[    0.836023] usb usb2: Manufacturer: Linux 4.19.0-9-amd64 xhci-hcd
[    0.836024] usb usb2: SerialNumber: 0000:00:14.0
[    0.836119] hub 2-0:1.0: USB hub found
[    0.836128] hub 2-0:1.0: 10 ports detected
[    0.837674] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.837678] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    0.837682] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    0.837718] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.837719] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.837720] usb usb3: Product: xHCI Host Controller
[    0.837722] usb usb3: Manufacturer: Linux 4.19.0-9-amd64 xhci-hcd
[    0.837723] usb usb3: SerialNumber: 0000:00:14.0
[    0.837738] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.837817] hub 3-0:1.0: USB hub found
[    0.837826] hub 3-0:1.0: 2 ports detected
[    0.838117] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[    0.838128] ehci-pci 0000:00:1d.0: debug port 2
[    0.838260] ahci 0000:00:1f.2: version 3.0
[    0.838419] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x3 impl SATA mode
[    0.838421] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems
[    0.842049] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.842065] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7d17000
[    0.847356] libphy: r8169: probed
[    0.847594] r8169 0000:02:00.0 eth0: RTL8168g/8111g, f8:bc:12:68:60:c1, XID 4c000800, IRQ 28
[    0.847596] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    0.849709] scsi host0: ahci
[    0.849880] scsi host1: ahci
[    0.849959] scsi host2: ahci
[    0.850035] scsi host3: ahci
[    0.850084] ata1: SATA max UDMA/133 abar m2048@0xf7d16000 port 0xf7d16100 irq 27
[    0.850086] ata2: SATA max UDMA/133 abar m2048@0xf7d16000 port 0xf7d16180 irq 27
[    0.850087] ata3: DUMMY
[    0.850088] ata4: DUMMY
[    0.857361] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.857438] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.857440] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.857442] usb usb4: Product: EHCI Host Controller
[    0.857443] usb usb4: Manufacturer: Linux 4.19.0-9-amd64 ehci_hcd
[    0.857444] usb usb4: SerialNumber: 0000:00:1d.0
[    0.857585] hub 4-0:1.0: USB hub found
[    0.857592] hub 4-0:1.0: 2 ports detected
[    1.165452] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    1.165488] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.166911] ata2.00: ATA-8: WDC WD5000AADS-00S9B0, 01.00A01, max UDMA/133
[    1.166917] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.168488] ata2.00: configured for UDMA/133
[    1.168772] ata1.00: ATAPI: PLDS DVD+/-RW DH-16AES, 3D11, max UDMA/100
[    1.169414] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.170036] ata1.00: configured for UDMA/100
[    1.172530] scsi 0:0:0:0: CD-ROM            PLDS     DVD+-RW DH-16AES 3D11 PQ: 0 ANSI: 5
[    1.173454] usb 3-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.193424] usb 4-1: new high-speed USB device number 2 using ehci-pci
[    1.195004] usb 3-1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[    1.195008] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.195011] usb 3-1: Product: DataTraveler 3.0
[    1.195014] usb 3-1: Manufacturer: Kingston
[    1.195017] usb 3-1: SerialNumber: 08606E6D3FDEB0A1E827E93B
[    1.201341] scsi 1:0:0:0: Direct-Access     ATA      WDC WD5000AADS-0 0A01 PQ: 0 ANSI: 5
[    1.209163] usb-storage 3-1:1.0: USB Mass Storage device detected
[    1.209307] scsi host4: usb-storage 3-1:1.0
[    1.209392] usbcore: registered new interface driver usb-storage
[    1.209819] sd 1:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    1.209824] sd 1:0:0:0: [sda] Write Protect is off
[    1.209825] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.209833] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.210619] usbcore: registered new interface driver uas
[    1.250927] sr 0:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.250930] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.251198] sr 0:0:0:0: Attached scsi CD-ROM sr0
[    1.253654] sr 0:0:0:0: Attached scsi generic sg0 type 5
[    1.253785] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    1.264770]  sda: sda1 sda2 < sda5 >
[    1.265054] sd 1:0:0:0: [sda] Attached SCSI disk
[    1.321445] usb 2-3: new low-speed USB device number 2 using xhci_hcd
[    1.326019] usb 1-1: New USB device found, idVendor=8087, idProduct=8008, bcdDevice= 0.04
[    1.326024] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.326424] hub 1-1:1.0: USB hub found
[    1.326489] hub 1-1:1.0: 4 ports detected
[    1.349788] usb 4-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.04
[    1.349792] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.350647] hub 4-1:1.0: USB hub found
[    1.351007] hub 4-1:1.0: 6 ports detected
[    1.478369] usb 2-3: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.78
[    1.478371] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.478372] usb 2-3: Product: Dell USB Entry Keyboard
[    1.478373] usb 2-3: Manufacturer: DELL
[    1.482875] hidraw: raw HID events driver (C) Jiri Kosina
[    1.488271] usbcore: registered new interface driver usbhid
[    1.488271] usbhid: USB HID core driver
[    1.489513] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:413C:2107.0001/input/input0
[    1.549462] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.10 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:14.0-3/input0
[    1.561357] tsc: Refined TSC clocksource calibration: 3392.145 MHz
[    1.561361] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x30e55212bb0, max_idle_ns: 440795241820 ns
[    1.561369] clocksource: Switched to clocksource tsc
[    1.605421] usb 2-4: new low-speed USB device number 3 using xhci_hcd
[    1.757535] usb 2-4: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00
[    1.757539] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.757541] usb 2-4: Product: Dell MS116 USB Optical Mouse
[    1.757543] usb 2-4: Manufacturer: PixArt
[    1.760462] input: PixArt Dell MS116 USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/0003:413C:301A.0002/input/input1
[    1.760626] hid-generic 0003:413C:301A.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-0000:00:14.0-4/input0
[    1.772139] PM: Image not found (code -22)
[    1.885429] usb 2-10: new full-speed USB device number 4 using xhci_hcd
[    2.034950] usb 2-10: New USB device found, idVendor=0d8c, idProduct=0139, bcdDevice= 1.00
[    2.034952] usb 2-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.034954] usb 2-10: Product: USB PnP Sound Device
[    2.034955] usb 2-10: Manufacturer: C-Media Electronics Inc.
[    2.036716] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.3/0003:0D8C:0139.0003/input/input2
[    2.052583] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    2.093642] hid-generic 0003:0D8C:0139.0003: input,hidraw2: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-0000:00:14.0-10/input3
[    2.235241] scsi 4:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[    2.235499] sd 4:0:0:0: Attached scsi generic sg2 type 0
[    2.236418] sd 4:0:0:0: [sdb] 30277632 512-byte logical blocks: (15.5 GB/14.4 GiB)
[    2.236921] sd 4:0:0:0: [sdb] Write Protect is off
[    2.236922] sd 4:0:0:0: [sdb] Mode Sense: 45 00 00 00
[    2.237073] sd 4:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    2.240050]  sdb: sdb1
[    2.241399] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[    4.272940] udevd[433]: starting version 3.2.7
[    4.573997] udevd[433]: specified group 'kvm' unknown
[    5.120922] udevd[433]: starting eudev-3.2.7
[    5.458013] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[    5.458029] ACPI: Power Button [PWRB]
[    5.458082] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[    5.458101] ACPI: Power Button [PWRF]
[    5.836751] iTCO_vendor_support: vendor-support=0
[    5.839042] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    5.839113] iTCO_wdt: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
[    5.839294] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    5.850301] input: PC Speaker as /devices/platform/pcspkr/input/input5
[    6.048950] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    6.048952] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    6.048952] RAPL PMU: hw unit of domain package 2^-14 Joules
[    6.048953] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    6.048953] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    6.489688] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    6.893440] [drm] PipeC fused off
[    6.893451] [drm] Replacing VGA console driver
[    6.894467] Console: switching to colour dummy device 80x25
[    6.895004] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    6.895005] [drm] Driver supports precise vblank timestamp query.
[    6.895174] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    7.065886] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[    7.066764] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    7.066939] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[    7.067026] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    7.090917] fbcon: inteldrmfb (fb0) is primary device
[    7.164832] Console: switching to colour frame buffer device 200x56
[    7.183437] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    7.239043] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input7
[    7.239074] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input8
[    7.239101] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input9
[    7.566366] usbcore: registered new interface driver snd-usb-audio
[    8.015877] intel_rapl: Found RAPL domain package
[    8.015878] intel_rapl: Found RAPL domain core
[    8.015878] intel_rapl: Found RAPL domain uncore
[    8.015879] intel_rapl: Found RAPL domain dram
[    8.015880] intel_rapl: RAPL package 0 domain package locked by BIOS
[    8.015884] intel_rapl: RAPL package 0 domain dram locked by BIOS
[   11.312649] Adding 8303612k swap on /dev/sda5.  Priority:-2 extents:1 across:8303612k FS
[   11.383696] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   11.978655] lp: driver loaded but no devices found
[   11.993111] ppdev: user-space parallel port driver
[   12.917295] audit: type=1400 audit(1593589444.203:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=1199 comm="apparmor_parser"
[   12.918218] audit: type=1400 audit(1593589444.207:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1202 comm="apparmor_parser"
[   12.918220] audit: type=1400 audit(1593589444.207:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1202 comm="apparmor_parser"
[   12.948456] audit: type=1400 audit(1593589444.235:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1201 comm="apparmor_parser"
[   12.948459] audit: type=1400 audit(1593589444.235:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=1201 comm="apparmor_parser"
[   12.948460] audit: type=1400 audit(1593589444.235:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=1201 comm="apparmor_parser"
[   12.990698] audit: type=1400 audit(1593589444.279:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1204 comm="apparmor_parser"
[   12.990700] audit: type=1400 audit(1593589444.279:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1204 comm="apparmor_parser"
[   12.990701] audit: type=1400 audit(1593589444.279:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1204 comm="apparmor_parser"
[   13.000576] audit: type=1400 audit(1593589444.287:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1205 comm="apparmor_parser"
[   19.360482] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.441249] r8169 0000:02:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[   19.441456] Generic PHY r8169-200:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[   19.542305] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   19.575705] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   19.576226] r8169 0000:02:00.0 eth0: Link is Down
[   19.837260] Bluetooth: Core ver 2.22
[   19.837271] NET: Registered protocol family 31
[   19.837271] Bluetooth: HCI device and connection manager initialized
[   19.837274] Bluetooth: HCI socket layer initialized
[   19.837275] Bluetooth: L2CAP socket layer initialized
[   19.837278] Bluetooth: SCO socket layer initialized
[   20.651627] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.651630] Bluetooth: BNEP filters: protocol multicast
[   20.651637] Bluetooth: BNEP socket layer initialized
[   22.344891] r8169 0000:02:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   22.344900] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   22.415040] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
[   22.964141] elogind[1886]: New seat seat0.
[   23.020353] elogind[1886]: Watching system buttons on /dev/input/event4 (Power Button)
[   23.053579] elogind[1886]: Watching system buttons on /dev/input/event3 (Power Button)
[   23.241589] elogind[1886]: Watching system buttons on /dev/input/event0 (DELL Dell USB Entry Keyboard)
[   24.875906] kauditd_printk_skb: 7 callbacks suppressed
[   24.875908] audit: type=1400 audit(1593589456.163:19): apparmor="DENIED" operation="mknod" profile="/usr/sbin/haveged" name="/run/haveged.pid" pid=2203 comm="haveged" requested_mask="c" denied_mask="c" fsuid=0 ouid=0
[   30.256406] elogind[1886]: New session 1 of user user.
[   36.548687] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=555597 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[   36.548698] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=565763 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[   36.558901] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=555597 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[   36.558917] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=565763 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[   38.668906] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:55:e0:13:08:00 SRC=10.85.5.23 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=33211 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   38.668951] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:4e:26:91:08:00 SRC=10.85.5.18 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=29275 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   38.668974] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:8d:c6:08:00 SRC=10.85.5.16 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=24088 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   38.668993] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:7d:8d:08:00 SRC=10.85.5.25 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=913 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   38.669020] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:c8:d9:d2:c9:22:71:08:00 SRC=10.85.5.24 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=40577 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   39.669074] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:55:e0:13:08:00 SRC=10.85.5.23 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=33706 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   39.669090] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:4e:26:91:08:00 SRC=10.85.5.18 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=30120 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   39.669101] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:8d:c6:08:00 SRC=10.85.5.16 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=24796 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   39.669112] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:c8:d9:d2:c9:22:71:08:00 SRC=10.85.5.24 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=41094 PROTO=UDP SPT=161 DPT=34067 LEN=194
[   39.669123] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:7d:8d:08:00 SRC=10.85.5.25 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=1017 PROTO=UDP SPT=161 DPT=34067 LEN=194
[  197.387762] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:4c:4e:35:44:05:32:08:00 SRC=58.32.64.168 DST=10.85.2.30 LEN=86 TOS=0x00 PREC=0x00 TTL=51 ID=46294 DF PROTO=UDP SPT=51413 DPT=8999 LEN=66
[  272.252794] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:4c:4e:35:44:05:32:08:00 SRC=86.139.12.151 DST=10.85.2.30 LEN=129 TOS=0x00 PREC=0x00 TTL=54 ID=46063 DF PROTO=UDP SPT=6881 DPT=8999 LEN=109
[  462.798348] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:1c:23:df:aa:22:08:00 SRC=10.85.2.12 DST=239.255.255.250 LEN=666 TOS=0x00 PREC=0x00 TTL=1 ID=1266 PROTO=UDP SPT=55636 DPT=3702 LEN=646
[  462.798406] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:1c:23:df:aa:22:08:00 SRC=10.85.2.12 DST=239.255.255.250 LEN=684 TOS=0x00 PREC=0x00 TTL=1 ID=1265 PROTO=UDP SPT=55638 DPT=3702 LEN=664
[  462.859724] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:1c:23:df:aa:22:08:00 SRC=10.85.2.12 DST=239.255.255.250 LEN=666 TOS=0x00 PREC=0x00 TTL=1 ID=1267 PROTO=UDP SPT=55636 DPT=3702 LEN=646
[  462.968836] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:1c:23:df:aa:22:08:00 SRC=10.85.2.12 DST=239.255.255.250 LEN=684 TOS=0x00 PREC=0x00 TTL=1 ID=1270 PROTO=UDP SPT=55638 DPT=3702 LEN=664
[ 2544.343520] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:50:56:82:46:f6:08:00 SRC=10.85.2.65 DST=239.255.255.250 LEN=1026 TOS=0x00 PREC=0x00 TTL=1 ID=22404 PROTO=UDP SPT=53172 DPT=3702 LEN=1006
[ 2544.444104] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:50:56:82:46:f6:08:00 SRC=10.85.2.65 DST=239.255.255.250 LEN=1026 TOS=0x00 PREC=0x00 TTL=1 ID=22405 PROTO=UDP SPT=53172 DPT=3702 LEN=1006
[ 3437.923129] fuse init (API version 7.27)
[ 3925.764870] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:4c:4e:35:44:05:32:08:00 SRC=79.69.158.144 DST=10.85.2.30 LEN=132 TOS=0x00 PREC=0x00 TTL=56 ID=31167 DF PROTO=UDP SPT=6881 DPT=8999 LEN=112
[ 4331.325344] [UFW BLOCK] IN=eth0 OUT= MAC=01:00:5e:7f:ff:fa:00:50:56:82:46:f6:08:00 SRC=10.85.2.65 DST=239.255.255.250 LEN=806 TOS=0x00 PREC=0x00 TTL=1 ID=22670 PROTO=UDP SPT=53172 DPT=3702 LEN=786
[ 4350.319843] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:4c:4e:35:44:05:32:08:00 SRC=42.2.127.147 DST=10.85.2.30 LEN=129 TOS=0x00 PREC=0x00 TTL=53 ID=39183 DF PROTO=UDP SPT=6881 DPT=8999 LEN=109
[ 4487.416203] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:4c:4e:35:44:05:32:08:00 SRC=86.139.12.151 DST=10.85.2.30 LEN=129 TOS=0x00 PREC=0x00 TTL=54 ID=58154 DF PROTO=UDP SPT=6881 DPT=8999 LEN=109
[ 4601.583261] usb 2-10: USB disconnect, device number 4
[ 4601.608567] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=555597 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 4601.608577] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=565763 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 4601.619450] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=555597 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 4601.619477] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=565763 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 4602.152310] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:55:e0:13:08:00 SRC=10.85.5.23 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=55609 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4602.152496] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:8d:c6:08:00 SRC=10.85.5.16 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=25484 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4602.152674] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:c8:d9:d2:c9:22:71:08:00 SRC=10.85.5.24 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=47920 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4602.153026] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:4e:26:91:08:00 SRC=10.85.5.18 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=46044 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4602.153215] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:7d:8d:08:00 SRC=10.85.5.25 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=52732 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4603.142170] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:4e:26:91:08:00 SRC=10.85.5.18 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=47001 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4603.142208] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:c8:d9:d2:c9:22:71:08:00 SRC=10.85.5.24 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=48051 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4603.142235] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:8d:c6:08:00 SRC=10.85.5.16 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=26042 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4603.142261] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:ec:8e:b5:c0:7d:8d:08:00 SRC=10.85.5.25 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=53430 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4603.142286] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:55:e0:13:08:00 SRC=10.85.5.23 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=56184 PROTO=UDP SPT=161 DPT=52970 LEN=194
[ 4627.805260] usb 2-10: new full-speed USB device number 5 using xhci_hcd
[ 4627.954609] usb 2-10: New USB device found, idVendor=0d8c, idProduct=0139, bcdDevice= 1.00
[ 4627.954615] usb 2-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4627.954618] usb 2-10: Product: USB PnP Sound Device
[ 4627.954621] usb 2-10: Manufacturer: C-Media Electronics Inc.
[ 4627.961818] input: C-Media Electronics Inc.       USB PnP Sound Device as /devices/pci0000:00/0000:00:14.0/usb2/2-10/2-10:1.3/0003:0D8C:0139.0004/input/input10
[ 4628.021569] hid-generic 0003:0D8C:0139.0004: input,hidraw2: USB HID v1.00 Device [C-Media Electronics Inc.       USB PnP Sound Device] on usb-0000:00:14.0-10/input3
[ 4628.051995] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=555597 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 4628.052005] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=565763 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 4628.062120] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=555597 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 4628.062133] [UFW BLOCK] IN=eth0 OUT= MAC= SRC=fe80:0000:0000:0000:fabc:12ff:fe68:60c1 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=565763 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 4628.584744] [UFW BLOCK] IN=eth0 OUT= MAC=f8:bc:12:68:60:c1:84:a9:3e:55:e0:13:08:00 SRC=10.85.5.23 DST=10.85.2.30 LEN=214 TOS=0x00 PREC=0x00 TTL=64 ID=65095 PROTO=UDP SPT=161 DPT=43843 LEN=194
#5 2020-07-01 09:49:43
larsH
Re: PnP USB Audio Device doesn't work
Hi
Does your audio work. Try using alsamixer in a terminal. With that you can choose device and set the volume. Pulseaudio is not the default in Devuan. But if alsa works install volumeicon-alsa and add it to your desktop and your done. It works
Have a nice day
Lars H
#6 2020-07-01 10:00:46
zerrax
When I type:
lspci |grep "Audio"
I get:
root@devuan:/home/user# lspci |grep "Audio"
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
(note: I have disabled onboard audio in bios, because I want only the USB Audio Device to work)
#7 2020-07-01 10:05:59
larsH
Hi again
That's is just fine. But in many cases the volume is muted so you cant hear anything. This is because most programs defaults to pulseaudio. You can try what i suggested above, or read in the relesenotes howto enable pulseaudio.
Have a nice day
Lars H
#8 2020-07-01 10:26:17
zerrax
Hi Lars, thank you for you tips, I tried Alsa Mixer in termina, and selected first the USB Sound Adapter, and then increased the volume, but still no sound
and within Devuan: Multimedia - Audio Volume - Configure the Audio Volume - Devices - "Outputs: No Output Devices Available"
┌───── Sound Card ──────┐        │
│        │-  (default)           │        │
│        │0  HDA Intel HDMI      │        │
│        │1  USB PnP Sound Device│        │
│        │   enter device name...│        │
#9 2020-07-01 10:28:17
zerrax
Card: USB PnP Sound Device        F1:  Help               │
│ Chip: USB Mixer        F2:  System information │
│ View: F3:[Playback] F4: Capture  F5: All        F6:  Select sound card  │
│ Item: PCM [dB gain: -12.06, -12.06]        Esc: Exit               │
│        │OO│               │OO│        │
│        44<>44        │
│        <       PCM        >Auto Gain Control
#10 2020-07-01 11:32:39
larsH
Hi
What does "aplay -l" say ???  And as well "cat /proc/asound/cards" ?? For me it looks like, enabled or not, that linux sees your intel device.
Have you tried with pulseaudio enabled (see devuan release notes for howto enable it).
Have a nice day
#11 2020-07-01 11:42:17
zerrax
I go it "working" by re-installing pulseaudio, but the sound quality is very disappointing.....
almost not usable for normal use...
thank you everybody for the tips, I'm going to look for a better UAC2 compatible DAC and use that as soundcard....
#12 2020-07-01 19:30:23
zerrax
larsH wrote:
Hi
Have a nice day
You were right, Linux did see my Intel HD soundcard, I checked and it was not disabled in bios (as I tought I did in the first place ;-)
it started to work when I installed via "apper" additional alsa  compoments like alsa mixer....
it doesn't show up in sound manager icon, but when I move the intel sound card to the top, (in the multimedia - sound - "advanced" menu) it works! no need for using an inferior USB sound dongle anymore.
Advise to make Devuan better for mainstream (newbie) users:
I think it would help a lot of new Devuan users as the soundcard works "out of the box" and not like this that you have install additional (standard?) packages and configure difficult things to get a soundcard working that is detected by Linux in the firstplace....
But Rome wasn't build in one day :-) I'm very happy, this post can be closed
#13 2020-07-01 20:59:03
larsH
Hi
Happy that you got things sorted out (sort of). The developers knows about the audio problem but they cannot fix everything debian is doing in a bad manner. But all you needed to know is stated in the release notes. The easy way to deal with pure alsa in a gui is as have said many times to install volumicon-alsa and add it to your desktop startup.
Have a nice day
Lars H
