#1 2020-06-26 20:07:30
[Solved] Copy putty sessions does not work
Beowulf with Mate installed in parallel to ASCII.
I selectively copied over the session settings from .putty in my ASCII home to .putty on the new Beowulf home.
Direct look into putty, log off and in again, reboot: no listing of the old sessions in the Beowulf putty. Access rights are to the user.
When reading posts from the internet a simple copy should be enough.
What else might have changed?
#2 2020-06-27 12:18:48
Re: [Solved] Copy putty sessions does not work
Solution: the settings need to go to ~/.putty/sessions and not into ~/.putty.
