But anyway NOT installing Trinity OR TeXInfo DOESN’T get me into the issue
hd_scania@hd-scania:/var/cache/apt/archives$ cat /etc/apt/sources.list.d/* /etc/apt/sources.list
deb https://pkgmaster.devuan.org/merged chimaera main contrib
deb https://pkgmaster.devuan.org/merged chimaera-proposed-updates main contrib
deb https://pkgmaster.devuan.org/merged chimaera-updates main contrib
deb-src https://pkgmaster.devuan.org/merged chimaera main contrib
deb-src https://pkgmaster.devuan.org/merged chimaera-proposed-updates main contrib
deb-src https://pkgmaster.devuan.org/merged chimaera-updates main contrib
deb https://download.opensuse.org/repositories/home:/stevenpusser/Debian_Testing/ /
deb https://mirror.ppa.trinitydesktop.org/trinity-testing bullseye main deps
deb-src https://mirror.ppa.trinitydesktop.org/trinity-testing bullseye main deps
cat: /etc/apt/sources.list: No such file or directory
hd_scania@hd-scania:/var/cache/apt/archives$ up tex-common
Hit:2 https://pkgmaster.devuan.org/merged chimaera InRelease
Hit:3 https://download.opensuse.org/repositories/home:/stevenpusser/Debian_Testing  InRelease
Hit:4 https://pkgmaster.devuan.org/merged chimaera-proposed-updates InRelease
Hit:5 https://pkgmaster.devuan.org/merged chimaera-updates InRelease
Hit:1 https://mirror.ppa.trinitydesktop.org/trinity-testing bullseye InRelease
Building dependency tree
All packages are up to date.
tex-common is already the newest version (6.15).
Calculating upgrade... Done
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "ja_JP.UTF-8",
        LC_ALL = "ja_JP.UTF-8",
        LC_TIME = "ja_JP.UTF-8",
        LC_MONETARY = "ja_JP.UTF-8",
        LC_CTYPE = "ja_JP.UTF-8",
        LC_COLLATE = "ja_JP.UTF-8",
        LC_ADDRESS = "ja_JP.UTF-8",
        LC_TELEPHONE = "ja_JP.UTF-8",
        LC_MESSAGES = "ja_JP.UTF-8",
        LC_NAME = "ja_JP.UTF-8",
        LC_MEASUREMENT = "ja_JP.UTF-8",
        LC_IDENTIFICATION = "ja_JP.UTF-8",
        LC_NUMERIC = "ja_JP.UTF-8",
        LC_PAPER = "ja_JP.UTF-8",
        LANG = "ja_JP.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up tex-common (6.15) ...
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (ja_JP.UTF-8)
Running mktexlsr. This may take some time... done.
Running updmap-sys. This may take some time... done.
Running mktexlsr /var/lib/texmf ... done.
Building format(s) --all.
fmtutil failed. Output has been stored in
/tmp/fmtutil.g5AlZEHt
Please include this file if you report a bug.
dpkg: error processing package tex-common (--configure):
 installed tex-common package post-installation script subprocess returned error exit status 1
 tex-common
W: --force-yes is deprecated, use one of the options starting with --allow instead.
hd_scania@hd-scania:/var/cache/apt/archives$Devuan-CURRENT/runit+SDDM/Plasma+Xfce
Hi
Look here https://wiki.trinitydesktop.org/Devuan_ … structions
Most ppa's expect systemd. And not having that is the sole reason behind creating Devuan. Is this maybe your problem ??
Have a  nice day
Lars H
