#1 2020-06-16 06:32:07
bimon
Is openssh 8.3 going to be backported to buster/beowulf?
Any prediction when can it happen?
#2 2020-06-16 14:26:29
bgstack15
Re: Is openssh 8.3 going to be backported to buster/beowulf?
Beowulf is the same suite codename as Debian Buster, which only has openssh-server 7.9 https://packages.debian.org/buster/openssh-server. If Buster gets oepnssh 8.3, then Beowulf can too.
#3 2020-06-16 14:43:33
@OP: do it yourself if you're so impatient:
https://wiki.debian.org/SimpleBackportCreation
I suspect that the dependency chain is far too tangled to make this a reasonable option, hence the lack of a package in the buster-backports repositories.
antifa ftw!
#4 2020-06-16 16:02:10
HevyDevy
there is openssh-portable but you would have to build it yourself.
https://github.com/openssh/openssh-portable
