Pages: 1
Is anybody successfully using bluetooth under Devuan? I have tried all I know but I can’t find devices and devices can’t find the computer.
If someone out there running Devuan is using bluetooth, I will keep trying.
Thank you,
would this guide help you?
https://wiki.debian.org/BluetoothUser
also you should install rfkill package (sudo apt install rfkill)
rfkill - tool for enabling and disabling wireless devices
what does below command give?
sudo rfkill listLast edited by HevyDevy (2020-06-14 16:30:37)
Yep did all that already. See results.
job@duala:~$ sudo rfkill list
[sudo] password for job:
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: dell-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
3: dell-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
4: phy0: Wireless LAN
Soft blocked: no
Hard blocked: noOffline
HevyDevy,
That Debian link helped. I am in business now.
Thank you,
good one ![]()
HevyDevy,
Just in case, this is also useful : https://wiki.debian.org/BluetoothUser/a2dp
satellite mestizo
Pages: 1
