#1 2020-06-14 09:00:46
Suhrad
I botched my login
I fiddled around with unsupported packages and as a result, I am greeted upon start up with a shell and login. Even as root, I get an immediate "Login incorrect", without getting asked for a password. From searching I think the issue is something to do with pam.d, but I could not find any instructions how to "reset"/fix that. Any pointers?
beowulf / lxQT
#2 2020-06-14 10:49:45
Re: I botched my login
I put "login incorrect linux" into the search box at startpage.com and this was the top result: https://www.linuxquestions.org/question … ed-881131/
Does that help?
antifa ftw!
