#1 2020-06-14 08:22:17
fw190
Devuan and privacy
Hi!
I'm considering using Devuan on my laptop but was wondering what is your stand towards privacy?
Is the system calling home?
Are there any parts of the system that use third party tools/services that call home - like google or other to check connectivity etc?
#2 2020-06-14 08:58:27
Re: Devuan and privacy
Devuan is Debian minus systemd. The "system" will not call home except for if you configure it accordingly, e.g. for auto-update. Debian/Devuan is not like Windows 10.
Applications will call home. Firefox will call home to check for updates if configured this way, it will approach Amazon server for DNS lookup, Libreoffice the same .......
Inform yourself about privacy in browers, they are the big hole.
#3 2020-06-14 09:27:58
Marjorie
There is an /etc/cron.daily program 'popularity contest' that logs and reports weekly which packages you have/use.
It is optional (you can turn it off) and anonymous in intent.
Firefox can be configured to provide telemetry (but you can turn it off) and it can check for updates to add-ons you have installed (also optional). You can install  other browsers that promise more.
To can install programs or configure your browser to encrypt DNS queries, so you only share them with your chosen DNS provider (but you still have to trust them not to log, etc). I use dnscrypt-proxy.
#4 2020-06-14 10:07:04
fw190
I think that I have the browser well covered - uBlock in hard mode, Decentraleyes plus firefox in strict privacy and cleaning all of the data after closing it. Plus the tabs run in container tabs.
The router is configured to use cloud flare so that covers the dns for me.
For daily operations I only need KeePassXC libreoffice, Thunderbird and Gimp and I'm golden. I'm also considering antiX Linux as a no systemD alternative to Devuan.
#5 2020-06-14 10:37:28
Popcon is opt-in — the installer asks the user but the default reply is "no".
Mozilla's guide to enabling better privacy is here: https://support.mozilla.org/en-US/kb/ho … onnections
They're a bunch of deceptive bastards though because that page makes no mention of their Beacon API, disable that in about:config.
Not necessarily, Firefox are moving towards enabling DoH by default: https://support.mozilla.org/en-US/kb/fi … over-https
#6 2020-06-14 12:26:54
HevyDevy
I use ghacks user.js for Firefox, makes it a bit more private along with some addons like canvas blocker, localcdn, privacy-orientated origin policy or POOP for short, ublock origin, site-bleacher,clearurls. And searx for the search engine as it is open source and no info is given over to the goog or any search engine!
https://github.com/ghacksuserjs/ghacks-user.js/
https://github.com/ghacksuserjs/ghacks- … aintenance
