#1 2020-06-14 07:57:43
the_edge123
[stable] apt-get fails to update i386
Hello,
I noticed an error during an apt-get update:
Get:14 http://deb.devuan.org/merged stable-updates/main amd64 Packages [7,880 B]
Get:15 http://deb.devuan.org/merged stable-updates/main amd64 Contents (deb) [39.2 kB]
Get:16 http://deb.devuan.org/merged stable-updates/main i386 Contents (deb) [39.2 kB]
Err:16 http://deb.devuan.org/merged stable-updates/main i386 Contents (deb)
  Hash Sum mismatch
  Hashes of expected file:
   - Filesize:39154 [weak]
   - SHA256:a60b1f421deed145b064752844c086f579215d52ce88007bc626ddd972bb403e
  Hashes of received file:
   - SHA256:a500261de2921340df480d19e3170d81948b5e012560c4f2aa3f1b3e2f67f650
  Last modification reported: Sat, 13 Jun 2020 23:28:58 +0000
  Release file created at: Sun, 14 Jun 2020 06:28:12 +0000
Fetched 104 kB in 4s (29.2 kB/s)
E: Failed to fetch http://pkgmaster.devuan.org/merged/dists/stable-updates/main/Contents-i386.gz  Hash Sum mismatch
I know that there is a fix for that https://stackoverflow.com/questions/155 … m-mismatch
I just wanted to know what happened on the 13th of June on the repository since my machine was off that day.
Fabien
#2 2020-06-14 08:49:54
Re: [stable] apt-get fails to update i386
The link you are listing is a different topic.
In your sources you have referenced Stable which is Beowulf since June 4th or so.
The clear recommendation is only to use distro names: https://devuan.org/os/packages
Would suggest to you to only specify Beowulf and to try again. Disable all foreign repos.
#3 2020-06-14 13:32:11
thierrybo
I am on ascii an try to upgrade to beowulf today and I have the same error for all  i386 and some amd64, euther with ascii or beowulf source.list   :
Réception de:1 http://deb.devuan.org/merged beowulf InRelease [25,6 kB]
Réception de:2 http://deb.devuan.org/merged beowulf-security InRelease [25,6 kB]
Réception de:3 http://deb.devuan.org/merged beowulf-updates InRelease [25,6 kB]
Réception de:4 http://deb.devuan.org/merged beowulf/main i386 Packages [7 988 kB]
Réception de:5 http://deb.devuan.org/merged beowulf/main amd64 Packages [8 034 kB]
Réception de:6 http://deb.devuan.org/merged beowulf/main amd64 Contents (deb) [32,5 MB]
Err:6 http://deb.devuan.org/merged beowulf/main amd64 Contents (deb)
  Somme de contrôle de hachage incohérente
   - Filesize:32478354 [weak]
   - SHA256:d4e09d716600fa97bef1bfc1c70715d0f26ad85dfc5253b947a16c951517f4cb
   - SHA256:c15a5c0c3bab7159fa32e367fe690b0e37dec6a9f8ae55f22c3304695b6efed3
  Last modification reported: Sat, 13 Jun 2020 23:20:05 +0000
  Release file created at: Sun, 14 Jun 2020 06:28:02 +0000
Réception de:26 http://deb.devuan.org/merged beowulf/main i386 Contents (deb) [32,4 MB]
Err:26 http://deb.devuan.org/merged beowulf/main i386 Contents (deb)
Réception de:28 http://deb.devuan.org/merged beowulf/non-free i386 Contents (deb) [710 kB]
Err:28 http://deb.devuan.org/merged beowulf/non-free i386 Contents (deb)
Réception de:29 http://deb.devuan.org/merged beowulf/contrib i386 Contents (deb) [78,5 kB]
Err:29 http://deb.devuan.org/merged beowulf/contrib i386 Contents (deb)
Réception de:30 http://deb.devuan.org/merged beowulf-security/main i386 Contents (deb) [35 B]
Err:30 http://deb.devuan.org/merged beowulf-security/main i386 Contents (deb)
   - Filesize:35 [weak]
   - SHA256:cdcfcf174b6f4e300945368a40a3ff3b5a8a6889813034ac178ae69b4dc635b6
   - SHA256:d097beb6ea878c5cd588d3df70f52465801cb5b47d87e9d4e775209a6c8acfa7
  Last modification reported: Sat, 13 Jun 2020 23:28:14 +0000
  Release file created at: Sun, 14 Jun 2020 12:14:02 +0000
Réception de:31 http://deb.devuan.org/merged beowulf-security/contrib i386 Contents (deb) [35 B]
Err:31 http://deb.devuan.org/merged beowulf-security/contrib i386 Contents (deb)
Réception de:32 http://deb.devuan.org/merged beowulf-security/non-free i386 Contents (deb) [35 B]
Err:32 http://deb.devuan.org/merged beowulf-security/non-free i386 Contents (deb)
Réception de:33 http://deb.devuan.org/merged beowulf-updates/main i386 Contents (deb) [39,2 kB]
Err:33 http://deb.devuan.org/merged beowulf-updates/main i386 Contents (deb)
  Release file created at: Sun, 14 Jun 2020 08:32:01 +0000
Réception de:34 http://deb.devuan.org/merged beowulf-updates/contrib i386 Contents (deb) [35 B]
Err:34 http://deb.devuan.org/merged beowulf-updates/contrib i386 Contents (deb)
Réception de:35 http://deb.devuan.org/merged beowulf-updates/non-free i386 Contents (deb) [190 B]
Err:35 http://deb.devuan.org/merged beowulf-updates/non-free i386 Contents (deb)
65,8 Mo réceptionnés en 4s (14,0 Mo/s)
Lecture des listes de paquets... Fait
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf/main/Contents-amd64.gz  Somme de contrôle de hachage incohérente
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf/main/Contents-i386.gz
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf/non-free/Contents-i386.gz
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf/contrib/Contents-i386.gz
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf-security/main/Contents-i386.gz  Somme de contrôle de hachage incohérente
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf-security/contrib/Contents-i386.gz
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf-security/non-free/Contents-i386.gz
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf-updates/main/Contents-i386.gz  Somme de contrôle de hachage incohérente
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf-updates/contrib/Contents-i386.gz
E: Impossible de récupérer http://deb.devuan.org/merged/dists/beowulf-updates/non-free/Contents-i386.gz
E: Le téléchargement de quelques fichiers d'index a échoué, ils ont été ignorés, ou les anciens ont été utilisés à la place.
#4 2020-06-14 16:21:56
Well, I have updated one ASCII, two Beowulf and one Chimaera, no issues seen. Two real computer and two VMs, all amd64 with 386 packages.
Issues with proxies, mirrors or something like that?
#5 2020-06-14 22:17:58
thierrybo
solved with https://dev1galaxy.org/viewtopic.php?pid=11331#p11331
# apt-get clean
# rm -rf /var/lib/apt/lists/*
# apt-get update
#6 2020-06-21 07:42:38
the_edge123
I managed to upgrade today without any modification.
Maybe a propagation delay somewhere
